Toyota recalling 228,000 Tacoma's due to oil leaks and possible loss of control of vehicle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1ChrisRuck, Apr 27, 2017.
  1. Jun 7, 2017 at 8:26 PM
    #1721
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    We will probably see the recall extend to all trucks buy the summers end. It very well could be bad gaskets and not torque.
  2. Jun 8, 2017 at 3:09 AM
    #1722
    BBurgDave
    BBurgDave Well-Known Member
    Dave
    Blacksburg, VA
    2017 Tacoma SR5 Access Cab
    That's true, although only GM is positioned to do it right now (with the Colorado and Canyon pair of trucks). Ford has no entry until next year when the Ranger returns and Nissan's Frontier truck is dated and not going to do that. So, Toyota does have the good fortune of timing ...
  3. Jun 8, 2017 at 6:08 AM
    #1723
    xlucidx
    xlucidx Well-Known Member
    2017 TRD Off Road DBCB SB
    I think this is accurate.
    I suspect what has happen is Toyota has noticed the problem and only started recalling certain models because
    1. They dont want to publicly say EVERY new taco
    2. They dont even have the parts to fix the ones that are being held right now
    Like Baron said, once parts get flowing out and they start fixing trucks im sure the recall will be expanded to the other trucks as well.
  4. Jun 8, 2017 at 6:16 AM
    #1724
    Hunter#23
    Hunter#23 Well-Known Member
    2016 White TRD Sport LB
    I was told "a remedy will be out by end of the month. My dealer didn't know what the repair will be, or the availability of the parts". Not holding my breath.
  5. Jun 8, 2017 at 6:38 AM
    #1725
    HdToys
    HdToys Well-Known Member
    Milo, Maine
    2017 Toyota Tacoma
    Stock all the way
    Do you have any update on your Pro diff?
  6. Jun 8, 2017 at 7:11 AM
    #1726
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
    Dealer is inspecting today...
  7. Jun 8, 2017 at 9:08 AM
    #1727
    Nelson69
    Nelson69 Well-Known Member
    Tacoma TRD Sport 2016
    How long did the dealership take to inspect your rear axle diff leak ? , how come I'm still waiting, it's been 34 days without my truck, just sitting at the lot, I'm starting to think that there might be other repairs issues that the dealership is not telling me about, they only said that my truck was on the recall list and proceeded to take my truck , by the way do we have other recall issues aside from the rear axle leak that I'm not aware of ?
    08sprsnke and scottalot like this.
  8. Jun 8, 2017 at 9:29 AM
    #1728
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    It takes less than 10 minutes to do the basic inspection. Are you sure the dealer didn't inspect it?
  9. Jun 8, 2017 at 10:10 AM
    #1729
    BBurgDave
    Dave
    Blacksburg, VA
    My truck has been done. They combined the inspection, and bolt retorquing, with the 6 mo/5K mile service (which included tire rotation) and the entire thing took about 2 hrs. I am guessing the inspection itself was probably very fast (since it was not, visibly, weeping).
  10. Jun 8, 2017 at 11:06 AM
    #1730
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    CPS on recall for some VIN's. No official "remedy" yet.
    G.
  11. Jun 8, 2017 at 11:13 AM
    #1731
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Now they're probably holding your truck for the CPS Recall. It is also a major safety concern.
    scottalot likes this.
  12. Jun 8, 2017 at 11:14 AM
    #1732
    BBurgDave
    Dave
    Blacksburg, VA
    CPS recall? This is different than the weeping differential issue?
  13. Jun 8, 2017 at 11:20 AM
    #1733
    smitty99
    Scottsdale
  14. Jun 8, 2017 at 11:21 AM
    #1734
    BBurgDave
    Dave
    Blacksburg, VA
  15. Jun 8, 2017 at 11:54 AM
    #1735
    RobPaul
    RobPaul Choose Goodness. Have Discretion.
    Rob
    Northern California
    2016 TRD Sport
    My 2016 Sport has been at my Toyota dealership since May 24th. And NOW I see the CPS recall! And I also have them performing the Intermittent Trip Odometer TSB at the same time, better have them replace the crank sensor. At least I have a 2017 Limited as a loaner!
  16. Jun 8, 2017 at 12:00 PM
    #1736
    Jes
    Knoxville
    Pro on the lift with 3 guys looking...
    mikestaco17 and SilverII like this.
  17. Jun 8, 2017 at 12:02 PM
    #1737
    BBurgDave
    Dave
    Blacksburg, VA
    At least they're not wearing rain gear!
    doublethebass likes this.
  18. Jun 8, 2017 at 12:06 PM
    #1738
    MG63
    MG63 Active Member
    Lucky! I've been in a RAV4 for over a month now..
  19. Jun 8, 2017 at 12:26 PM
    #1739
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    I would be willing to bet it isnt a supply of nuts or gasket shortage issue but a paperwork issue.
    Toyota will have to build a repair kit with little bags of nuts, a bagged Gasket, labels and part numbers on everything. Then compile a proper tech instructions sheet and have QC buy off on it and several department managers buy off on it and then get all of this approved stuff in their computer systems and have dealer information packets and training. They will probably have to build sign off and and survey documentations. Then legal will be all over this and until every duck is lined up and stamped off this will be going nowhere.
    This is assuming it is only a few quarts of gear oil, 10 interplanetary space nuts and a gasket. There may be new seals and gaskets at each axle end and maybe a redesigned vent if needed. Now with the trucks that have no or low oil issues requiring differential work there will have to be a resolution process to relieve those problems and getting their ducks in order. This is not as simple as just tighten some bolts and shove trucks out the door.
    Big companies have big processes and financial responsibilities and documentation that is required to make it all work.
  20. Jun 8, 2017 at 12:48 PM
    #1740
    baron55
    This is exactly it!
