Toyota recommends no syn oil for 4.0?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Amo-cat3, Jul 25, 2013.
  1. Oct 6, 2013 at 8:58 PM
    #81
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Both have dual VVT-i and cartridge filters.
    It is a different engine from the Tacoma.
  2. Oct 6, 2013 at 9:07 PM
    #82
    TacomaSportLB
    TacomaSportLB Well-Known Member
    Dad
    Chambersburg, PA
    2012 Toyota Tacoma TRD Sport DCLB MGM 4x4
    YWM, Front 5100's @ 2.5", Rear 5100's, 1.25" Spidertrax Wheel Spacers, Safety Rack, Fog Light Anytime, DRL Switch, Differential Breather Mod, UWS TBSD63ALPB ToolBox, AMP Research BedStep, Bedrug Tailgate Mat, aFe Air Filter, Dee Zee Heavyweight Bed Mat, Pop & Lock Power Tailgate Lock, Auto Ventshade In-Channel Ventvisors, Stant Locking Fuel Cap, Plasti Dipped Badges
    Yeah I asked the dealer about this when I 1st got my truck and was told no syn. oil, changes every 5k, reason I asked is our sienna got syn and changed every 10k...I do what they say, you'd think they would know.
  3. Oct 6, 2013 at 9:13 PM
    #83
    Rich91710
    Rich
    Los Angeles
    08 Base
    And yet we have members here with over 100k trouble-free running 10w30 in their 2.7s in cold climates... "Because that's what they've always used"
    Going by that, I'd still be using Castrol GTX or Valvoline 20w50 on any engine with over 100k on it.
    But my 2.7 gets M1 5w20.
    Wife's '04 Rav4 gets 5w30.
  4. Oct 6, 2013 at 9:38 PM
    #84
    Rich91710
    Rich
    Los Angeles
    08 Base
    Spout?
    Bahh.... That was pop-top era.
    When I learned to change oil, we used the same churchkey that we used to open our Canada Dry cola!
  5. Oct 6, 2013 at 10:42 PM
    #85
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  6. Oct 6, 2013 at 10:58 PM
    #86
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Not even worth reading!
  7. Oct 6, 2013 at 11:18 PM
    #87
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  8. Oct 6, 2013 at 11:29 PM
    #88
    Robnik
    Rob
    Greenacres, Florida
  9. Oct 7, 2013 at 8:53 AM
    #89
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I use to cuss a little myself. Fortunately I did not have to put up with them for long. I found a pull tab off a beer can on a ranch 2 years ago.
  10. Oct 7, 2013 at 9:54 AM
    #90
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Before switching to synthetic i asked both the dealership service manager and corperate Toyota... they both said absolutly no problem as long as it's the same grade and rateing.
  11. Oct 7, 2013 at 8:21 PM
    #91
    Rich91710
    Rich
    Los Angeles
    08 Base
    Replacing my furnace filter, I caught a glimmer of something between the 1st and 2nd floor.
    An unopened pull-tab Dr. Pepper.
    Also found a flattened Pepsi can in the bathroom...
    The flattened can was covering a gap in the ply flooring behind the waste line. I found it when I ripped up the carpet ( :eek: ) and the linoleum to lay tile.
    Don't let anybody tell you that today's construction is worse than the early 70s.
  12. Oct 8, 2013 at 9:01 AM
    #92
    bueller
    bueller Well-Known Member
    AZ
    I just checked the toyota owners site and realized the dealer is putting 5w20 in my 4.0L despite the manual stating 5w30 or 10w30. Wouldn't matter if it was winter or I lived in a cooler climate, but in AZ, in the summer. WTF?
