Toyota "Red" Antifreeze coolant aftermarket selection
Discussion in '1st Gen. Tacomas (1995-2004)' started by bawilson21, Oct 31, 2013.
  1. Jun 12, 2015 at 12:08 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Car-quest sells the toyota coolant around here for about half as much as toyota does.
    davidstacoma likes this.
  2. Jun 12, 2015 at 12:15 PM
    bawilson21
    bawilson21 [OP] Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Just checked out Carquest and they have it for about $28 by me, but good to know. It looks like they are also cheapest on coolant for my honda. Thanks for suggesting!
  3. Jun 12, 2015 at 12:21 PM
    slander
    Hickory, NC
    No problem, i had to do a double take when i saw it there!!
  4. Jun 12, 2015 at 4:58 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I just buy a case of Toyota Red when I remember it is not like it is not going to get used.
    The gallons . we get here is full strength
    It is nice to find a case I forgot I had.
  5. Jun 13, 2015 at 7:52 AM
    Jarlaxle
    Jarlaxle Well-Known Member
    New England
    Not a Tacoma yet...
    Ye gods...I truly miss the days of just about everything using the same coolant! :annoyed:
    Having said that...I watched a fleet of livery cars wind up gigantic miles (400K+). They got nothing but whatever "universal" coolant was available the cheapest by the drum! I drove a Town Car that had over 580,000 miles and the original radiator...the original water pump went over 250K, the replacement also went over 250K. (AFAIK, the car was only on its second WP when scrapped with 640,000 miles.)
  6. Jun 13, 2015 at 7:59 AM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This is where I got my last coolant from. Buy the Toyota coolant for less here.
  7. Jun 20, 2015 at 7:15 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    There are so many different coolants on the market these days that it's not worth taking the chance of getting the wrong one for your engine. You can head over to the "Bob Is The Oil Guy" forum and find out all about them. There's "HOAT", "OAT", Silicate, low silicate. I believe my 2004 requires "Hoat" which will ruin other engines. It's mind boggling.
    I won't take the chance and just fork over the money for the Toyota stuff when the time comes unless I'm am absolutely, positively sure that whatever aftermarket brand I buy will actually replace the factory stuff and as we have all probably heard with the problems general Motors had with their coolants years ago there are times when you just can't trust what even the freakin' factory says.
    I will say though that the Japs are a little more on the ball and we can thank the EPA for the confusion.
  8. Dec 11, 2016 at 10:02 PM
    kabir909
    kabir909 New Member
    Sacramento, Ca
    2003 Black PreRunner
    O'Reilly carries a HOAT chemistry formula from the Zerex brand for $14.99+CaTax=$16.23 OTD
    Seems to be the same pink stuff that Toyota sells.
    1997tacomav6 and opteron like this.
  9. Aug 8, 2021 at 1:47 PM
    Gdiger#181
    Gdiger#181 Well-Known Member
    Rob
    2003 TRD Tacoma
    Just picked up 3 gallons of the Toyota 50/50 super long life Antifreeze/Coolant for $50. On sale at a local dealer.
  10. Aug 9, 2021 at 5:10 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  11. Aug 9, 2021 at 9:46 AM
    1997tacomav6
    Denver
    X2
