Toyota 'Red' Long Life Coolant...
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Mar 10, 2010.
  1. Mar 10, 2010 at 10:48 AM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Where can I buy this online at? All I see now is 'Pink' coolant for the Toyota. I don't want to drain mine as its been prolly a year but I need some to fill up my reservior. I called the stealership and they said oh we have a huge supply left for the older Toyota...dare I ask how much? $25 a gallon :eek:.
  2. Mar 10, 2010 at 10:56 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I just put in some of the pink GM stuff from autozone (prestone in the silver bottle). so far so good.
    but that was when I did the timing belt so the rad was drained.
  3. Mar 10, 2010 at 10:58 AM
    sirsaechao
    Tim
    CA
    I was thinking about just adding some deionized water to the reservior tank and call it good. Tho is may dilute the 50/50 a bit.
  4. Mar 10, 2010 at 10:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    Dealership is the best bet because the shipping for an online order will drive the prive above what the dealership wants.
    Steve o, any ill affects? Color change?
  5. Mar 10, 2010 at 11:03 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    The stuff that we drained out of the rad looked like perfect cherry koolaid so the old coolant was probably pretty new. So far everything is fine; nice and clean with no ill effects.:thumbsup:
  6. Mar 10, 2010 at 11:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Oh, you drained it. Good stuff.
  7. Mar 10, 2010 at 11:36 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Dexcool is not Toyota LLC. Read the bottle chemistries. These should not be mixed. Dexcool is also not the same chemistry of the new SLLC Toyota chemistry. Just to make the point, if a GM engine with Dexcool has been contaminated with standard AF, GM has an elaborate flush procedure to follow to get it all out of the system.
    The new coolants are OAT (organic acid technology) or HOAT (hybrid organic acid technology)
    The chemistry of a cooling system is designed to work not only with the metals in the engine, but also with the plastics, seals and gaskets as well. The original LLC (red) was a high grade of traditional anti freeze. It worked very well in those cars that used it. One gallon will make 8 quarts at standard mix and will fill a V6 Tacoma unless you were able to drain it bone dry, then you will be half a quart short. $25 does not seem like a bad price.
    If you do not have a dealer close by, a local CarQuest should either have it in stock or be able to get it through WorldPac. Price should be comparable to dealer or a little less. It is actual OE fluid supply. They can get the new SLLC for newer vehicles too.
  8. Mar 10, 2010 at 12:45 PM
    sirsaechao
    Tim
    CA
    I just grabbed some at the stealership and filled my reservoir up with 50/50 'Red' and deionized water. Thanks.
  9. Mar 10, 2010 at 9:36 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Yes, do not mix Dexcool and Toyota LLC. Dexcool is only for GM vehicles. Dexcool is a crappy coolant even in GM vehicles, IMHO it's the worst specialty coolant of all the car manufacturers. Dexcool as it ages lines the inside of the cooling system with a mud-like substance and it is impossible to clean out without major flushing. $25 is about the going price, as it is a high quality coolant.
  10. Mar 11, 2010 at 1:21 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    Spend $25 and buy a gallon from your dealership. It's not that much money over the course of a coolant cycle, so don't go cheap. I really don't know if it's better or not, but that's what's recommended. If there is no difference, "Oh well", but wouldn't if suck if you put cheap stuff in and if screwed up you water pump, seals, etc.?? How much did your truck cost you??? Don't go cheap!
  11. Mar 24, 2010 at 7:06 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I called the dealer and the parts rep said the coolant they sell is already 50/50. My Camry takes a bit over 6 quarts which means I have to buy 2 gallons at a steep $19.99. Does anyone know if it comes straight, no 50/50 mix?
  12. Mar 24, 2010 at 7:08 AM
    sirsaechao
    Tim
    CA
    If it is the red like I require since I have a older Tacoma, it shouldn't come mixed. If it is the new pink stuff for the new Toyota then they come pre-mixed. Just make sure.
  13. Apr 16, 2013 at 8:55 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Super Long Life is 50/50(pink) and Long Life is just coolant (red).
  14. Apr 16, 2013 at 10:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    fyi, still running strong with 45k miles on the GM red stuff :thumbsup:
  15. Apr 22, 2013 at 11:37 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    GM has red stuff? I thouht it was orange?
    I know there is aftermarket "pink" toyota coolant out there but I forget who makes it. It's half the price of the $20-25 a dealership charge but keep in mind that it's nothing something you replace all the time. Every two years supposedly so I don't think it's that much to use OEM stuff when you consider replacement interval.
  16. Apr 22, 2013 at 4:58 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Some guy was changing his fluid in his tacoma 1st gen this past weekend. He was using red generic IMPORT fluid. I should've asked where he got it...
  17. Apr 22, 2013 at 7:04 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    On our GM work trucks we switched over to the amsoil coolant, way better than the GM crap. I think that you could run the amsoil stuff in the toyota as well.
  18. Apr 23, 2013 at 7:01 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    sometimes it is false savings to use the cheaper green stuff. I know that in the case of the older Mercedes, you stick to their mix. It was formulated for the metals in the engine block etc...don't know if this is the case with Toyota, but let's look at it this way....you only change antifreeze every two years or so...so it's cheap insurance to use what it came with.
    I mean, the difference between $8/gallon and $20/gallon is not that much when you consider how long it lasts.
  19. Apr 23, 2013 at 7:14 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Zerex makes the jap compatible stuff but hard to find at local parts place. I paid $40 a gallon at dealership for toy longlife.
  20. Apr 23, 2013 at 7:16 AM
    Hansel
    Glenn
    Arizona
    base
    $40 a gallon...no wonder its called the stealership....
