Toyota 'Red' Long Life Coolant...
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Mar 10, 2010.
  1. Apr 23, 2013 at 7:19 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Toyota Red can be found at Carquest sometimes for $26.
  2. Apr 23, 2013 at 8:19 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Could have said it any better. Why on earth would you some of you guys risk putting that cheap green garbage in your Tacoma just to save $20? I don't get it... Just drive to the dealership (I've never paid more than $27 at my local Toyota) and buy it and be done with it. It's not that hard really.
  3. Apr 23, 2013 at 8:35 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    ^^^^This^^^^Not like changing oil, you only have to do it every couple years. You only need one gallon, and 5 gallons distilled water. 4 for the flush and one to mix 50/50 for the final refill. The jug says the heater core and block hold 50% but that cant be. The whole system only holds 10 quarts for 5vz 4x4 per my manual. I probaly ended up 60% water, 40% coolant. You will have just enough to fill the resivor.
  4. Apr 23, 2013 at 8:02 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    I work at a auto parts store and I must say the Toyota antifreeze is on of the best on the market. It's real easy on parts compared to the other antifreezes. And we have a whole variety of them from American cars to European. Toyota antifreeze is one of most expensive and we have a lot of it on the shelf. Simply put no one comes in for it because there are hardly any problems. We can't seem to keep dexcool and European antifreeze in stock. Go figure.lol
  5. Apr 24, 2013 at 5:17 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    Dam I just looked and I have the green coolant that the previous owner put in.
  6. May 5, 2013 at 3:39 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I just bought and use Zerex 675130 Asian Vehicle Antifreeze / Coolant - Gallon for $15 at the local auto parts store. Stealership parts dept closed Sunday. Wonder if it's just as good as the $40 a gallon stuff you got ?
  7. May 6, 2013 at 6:32 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
  8. May 6, 2013 at 6:37 AM
    Hansel
    Glenn
    Arizona
    base
  9. May 6, 2013 at 6:46 AM
    Hansel
    Glenn
    Arizona
    base
    To clarify my post above. If you drain the radiator and engine block completely, you should be able to get close to the 50/50 ratio. There is always a little fluid left in the system, but not enough to make a big difference.
    I usually flush the whole system with distilled water and dont drain the engine block...in my case I add a certain amount of 100% coolant in order to arrive at the percentage mix I prefer.
  10. May 6, 2013 at 10:05 AM
    george3
    New Jersey
  11. May 6, 2013 at 12:16 PM
    Yamaha Dave
    In summary this is what it says:
    "Toyota recommends Genuine Toyota Long Life Antifreeze Coolant (factory red fluid) as the first choice when maintaining your vehicle. Toyota coolant was developed to meet the specific requirements of our engines and provides maximum protection without the use of harmful silicates. Silicates, a main ingredient in the vast majority of antifreeze coolants, can actually damage the water pump seal, causing leakage. Our coolant is a high-performance, non-silicate coolant that provides better protection for metals without deterioration of the water pump seal."
    In other words, phosphates are used and Toyota water pumps are not compatible with silicates.
  12. May 6, 2013 at 3:37 PM
    george3
    New Jersey
    Thanks. The Asian says phosphated HOAT technology - silicate and borate free
  13. May 6, 2013 at 6:48 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Hey guys, my coolant is yellow. Is this some kind of special stuff or is it just a generic kind?
  14. May 6, 2013 at 6:55 PM
    george3
    New Jersey
    :eek::eek:
  15. May 7, 2013 at 9:05 PM
    #35
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Amsoil advertises "neutral yellow" color on their website.
    Also, read Zerex for Asian vehicles is sappose to be yellow too.
  16. May 8, 2013 at 10:03 AM
    #36
    Yamaha Dave
    Thankfully when I bought my truck used, the owner never put anything other than Toyota Red long life coolant. Honestly and as drastic as it sounds, had there of been anything green in that radiator I would of walked away from buying the truck.
  17. May 13, 2013 at 1:30 PM
    #37
    swdockter
    swdockter Well-Known Member
    Northwest Burbs, IL
    2" lift, 5100s, AAL, K&N, Deck Plate, 375K and counting
    I have 237,000 on my 2.7 taco. Been running Peek for years. I switch it ever 3-4 years. When I flushed my pink stuff out, I used
    Vinegar and distilled water. Rinsed it many times until the water no longer smelled of vinegar. Not sure why some are so nervous about the green stuff. I’ve replaced a lot of parts but never anything related to coolant….exactly what should I be worried about.
  18. May 13, 2013 at 4:28 PM
    #38
    george3
    New Jersey
    And I was worried about using Asian to replace the OEM stuff - LOL
  19. May 13, 2013 at 8:01 PM
    #39
    swdockter
    Northwest Burbs, IL
    ya, I'll let you know how the green stuff is doing when I put another 100,000 miles on my 01....:jerkoff:
    I swap out my tranny fluid and radiator fluids often. Change oil often and these little 2.7s will last forever. They have to be the toughest SOBs on the planet.
  20. May 14, 2013 at 9:11 AM
    #40
    Yamaha Dave
    By using "green" coolant, we don't doubt your engine will last another 200k, but your water pump seals may be leaking so good luck with that, all cause a whopping $26 gallon of Toyota Red coolant was considered "too expensive."
