Toyota 'Red' Long Life Coolant...
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Mar 10, 2010.
  1. May 14, 2013 at 12:16 PM
    #41
    swdockter
    swdockter Well-Known Member
    Northwest Burbs, IL
    2" lift, 5100s, AAL, K&N, Deck Plate, 375K and counting
    not too expensive at all. just not readily available. What does a guy do when you overheat in the middle of nowhere.....I'm not going to flush my system in the middle of nowhere or run all water until i find the pink stuff.
    If my water pump goes....who gives a rats a$$. It owes me nothing Dave. I have 237K miles on it :eek:. I worry about a lot of other things before I worry about runnning the pink stuff 100,000 miles. I don't run anything that long anyways. You guys should be more worried about what oil your running and changing frequently if you want to keep you taco for 3-400,000 mies.....lol
    Dave....do you sell the pink stuff for a living :D
  2. May 22, 2013 at 9:32 AM
    #42
    Yamaha Dave
    Yamaha Dave Well-Known Member
    ^ I don't, but since I'm good at it I'll look into it and get back with you. Hell if I'm become a distributor I'll even send you a free a jug. :)
  3. May 22, 2013 at 4:16 PM
    #43
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I've only used the red coolant in mine since '00
    Still, the water pump began to leak around 100K
    replaced the entire W pump for added measure.
    Found out... the problem with leaking water pumps on the 1st gen Tacoma
    is more related to the lousy paper gasket that is used, then the pump itself.
    From my understanding...
    all new replacement water pumps for the 1st gen...
    now come with newly designed metal gaskets.
    If one insists on reusing their current water pump...
    I recommend using rtv instead of the paper gasket.
    ^ that or try to locate the newer designed metal gasket.
  4. May 22, 2013 at 4:36 PM
    #44
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Interesting. My 1st gen started leaking around 130 but I'm pretty sure it was from the weep hole under the bearing - or maybe I don't remember it correctly at all:rolleyes:
  5. May 22, 2013 at 5:04 PM
    #45
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    Mine never technically leaked (hit the ground)
    just seeped and created a crusty build up at the lower edges of the WP
  6. May 22, 2013 at 5:06 PM
    #46
    george3
    New Jersey
    Thanks.
  7. Aug 5, 2014 at 4:45 PM
    #47
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Bilstein 5100's . Add-a-Leaf. Interior LED's. Husky floor mats. Thule rack. Various little things...
    Hopefully somebody still has this sub'd. IS there anything wrong with just draining the radiator and refilling with the 50/50 premix? Do I REALLY need to flush the block? Be easy, im new.
  8. Aug 5, 2014 at 6:12 PM
    #48
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Drain the radiator, fill with red and the rest with distilled water.
  9. Aug 5, 2014 at 9:47 PM
    #49
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Took mine in for a flush a few months ago at one of the local dealers. My fluid is green. That's strange if the fluid they use is pink or red...
  10. Aug 5, 2014 at 10:01 PM
    #50
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Wouldn't be that strange if they drained it and green was in their before. I had green in mine recently drained and flushed with pink coolant now though
