Toyota replaced passenger airbag, sensor lit again. Truck has middle airbag?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jwa538, May 19, 2023.
  1. May 19, 2023 at 2:24 PM
    Jwa538
    Jwa538 [OP] Member
    Jimmy
    Macon, GA
    2003 Tacoma Extended Cab V-6
    Reinforced front bumper and side bar step
    About a year ago my airbag sensor lit up and Toyota replaced the passenger side airbag at a cost of $1200. 6 weeks later the sensor lit up again and Toyota says it’s the middle air bag. My truck is an extended cab but I didn’t know it had a middle airbag. Is this true or are they pulling a swift one on me?
    Thanks.
  2. May 19, 2023 at 2:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Sensors are out front behind the bumper.
    Brain is likely in cab, behind dash, in the middle.
    Are you sure the bag was what was changed the last time? That seems very unusual to me.
    What year is your truck? Your profile is bare and you didn't mention that.
    @Dm93 ?
    tcBob likes this.
  3. May 19, 2023 at 3:02 PM
    Jwa538
    Jwa538 [OP] Member
    Jimmy
    Macon, GA
    That’s what I was told by the arrogant Toyota guy. I’ll dig up the receipt and see for sure what I was charged for. My truck is a 2002 Tacoma Extended cab V-6
  4. May 19, 2023 at 5:08 PM
    Jwa538
    Jwa538 [OP] Member
    Jimmy
    Macon, GA
    It was the passenger side sensor that was replaced and not the airbag as I mistakenly said earlier. When I returned 6 weeks later I was told it was now the middle air bag sensor that was bad. Is it likely these 2 sensors would both go bad so close together? I’ve suspected the Toyota place may have damaged the 2nd sensor.
  5. May 20, 2023 at 7:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    cruxofthebisquit, TacoSR523 and Wulf like this.
  6. May 20, 2023 at 8:27 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Without knowing what code(s) were set it's anyones guess but I do know Toyota refers to the airbag module as the Center Airbag Sensor Assembly so they could have been talking about that although it's pretty uncommon for that to fail unless it got wet.
    DrabT100 likes this.
  7. May 20, 2023 at 10:26 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    There are only two sensors, one on each frame rail in the engine bay. There is no middle sensor, unless they’re referring to the control module under your dash. It takes about 10 minutes to replace one of the sensors, so unless the part costs about $1100 of that $1200, you got taken for a ride by that dealership.
    TacoSR523 likes this.
  8. May 20, 2023 at 1:34 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I don't think dealerships are quick enough to pull a quick one. Maybe a dumb one.
    Moonrman, TacoSR523 and Rusty Taco 11 like this.
