Toyota Replacing 2nd Gen Frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lightlytoasted1726, Oct 3, 2020.
  1. Oct 3, 2020 at 2:56 PM
    lightlytoasted1726
    lightlytoasted1726 [OP] Active Member
    2010 Tacoma TRD Sport
    Brought in my newly bought 2010 TRD Sport DCLB to the dealer for a trans and diff fluid change and low and behold they told me my frame failed inspection and that they're going to replace it! Set me up in a brand now Tacoma for the time being
    They said its going to take at least 3 months due COVID thus there being no frames in stock. Anyone have a similar experience? Anything else I should look out for or expect?
    Here's a pic of where it failed (next to the cat). I would have never known. Otherwise the frame looked great.
  2. Oct 3, 2020 at 3:08 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Congrats! Dodged a bullet there. Take this as a lesson to always get a pre purchase inspection on a used car if you don’t know what you are looking at. This could have been a very expensive education for you
    Clearwater Bill and Muddinfun like this.
  3. Oct 3, 2020 at 3:19 PM
    HONY BADGER
    HONY BADGER Missing my memes
    BADGER
    2010 DBLB Silver Taco
    Could possibly run you around $1000.00 , all depends on what needs to be replaced?But the best of luck to you ,being the frame is the most expensive part !
  4. Oct 3, 2020 at 3:19 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    When you get it back, first thing you should do is coat the frame with either Fluid Film, WoolWax, or Amsoil HD Metal Protect. You’ll need a wand to get in the boxed section.
    TRDSport10 and ABNFDC like this.
  5. Oct 3, 2020 at 3:29 PM
    lightlytoasted1726
    What can run me around $1000?
  6. Oct 3, 2020 at 3:33 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    wow, impressed no fighting. just told you.
    HONY BADGER likes this.
  7. Oct 3, 2020 at 3:46 PM
    HONY BADGER
    BADGER
    The busted parts from replacing a frame,Quote friend of mine same situation bought before doing his home work!Frame replacement before purchase, It just makes sense ,but who thinks of that when your looking at that truck!Best of luck to you.
  8. Oct 3, 2020 at 4:33 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I have a 2010 and had the frame replaced. My dealer did a great job took three days once the frame was in. And absolutely NO out of pocket expenses except for the gas for the loaner.they never tried to upsale me on anything. It rides better than when I bought it and all the fluids except for the trans were changed. You probably also have a recall on the leaf springs. And know that the dealer know whos had a frame replacement they want to buy them back. There constantly asking me to come in for a trade. And I keep telling them that I really don’t like the look of the 3rd gens. If you’re dealer does a great job you will basically have a new truck . Good luck with your frame. And like every one else has mentioned. Coat the new frame with fluid film or some equivalent
  9. Oct 3, 2020 at 4:52 PM
    lightlytoasted1726
    I see you're from jersey too. What dealer did the work for you? And yeah they said they're gonna do the leaf springs as well
  10. Oct 3, 2020 at 4:55 PM
    lightlytoasted1726
    Bought it from a family friend, told me he had it checked out by the dealer a few years ago and they passed it. Also gave it to me for nearly half of what its worth.. so no complaints here
  11. Oct 3, 2020 at 5:14 PM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    Liberty Toyota in Burlington
  12. Oct 3, 2020 at 5:41 PM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    My 07 replacement was a 3 day job. No real out of pocket for me. Supplied them new rear shocks and they installed at no charge. Repaired an ABS wire that got crimped under the bed or something. 20 bucks I think. New brake lines. Coolant new too. Should not cost you anything. Don't let the dealer screw you. If they try, go to another dealer.
  13. Oct 3, 2020 at 6:30 PM
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    My 2012 is in for a replacement and getting close to when they start doing work. By time I get it back it will be about five months. I am having the water pump changed and a new set of leaf springs put in. They also said the calipers were rusty and might need to be replaced.
  14. Oct 3, 2020 at 6:43 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Had mine done this past March. I supplied front struts, UCA's, (LCA's come with frame, as do hard brake & fuel lines, & various fasteners/hardware). I paid ZERO.
  15. Oct 3, 2020 at 6:53 PM
    Eatmorevegtables77
    Eatmorevegtables77 Well-Known Member
    Kevin
    2016 trd offroad
    It sucks Toyota has 1st,2nd and 3rd gen frame problems but at least they stand behind there vehicles.chevy, ford and the rest probably wouldn't even mention there is an issue.lol best of luck.
  16. Oct 3, 2020 at 6:59 PM
    Muddinfun
    Muddinfun Well-Known Member
    The WEP specifically states, "At no cost to the owner". Some dealers try to make the unknowing customer pay for miscellaneous extras. If you stand your ground and quote the WEP (Especially if you have a copy in your hand), you can probably get out of paying anything. However, there are some maintenance items that would be much cheaper or free labor to have them do while it's apart. Rear shocks are 1 example of that.
    Eatmorevegtables77 likes this.
  17. Oct 3, 2020 at 8:54 PM
    whiteknight4x4
    whiteknight4x4 Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    @lightlytoasted1726 Hey good for you dude! I had a great and interesting experience with my frame replacement! I lived in CO last year and was at Boulder Toyota for a routine oil change when they caught mine. I literally only had like 3 months left so I'm super lucky they caught it. They quarantined my truck and gave me a 2019 dcsb 4x4 which was sweet. That was in September. Told me it would it would be a month or two, reason being that they don't make regular cabs anymore and that they have to literally make a brand new frame. And it ships from Japan. Said it could be a month, could be longer. But whatever I get a brand new one to drive around, right? So anyway, I finally get a call that it's ready, in December. It only took them like a day and a half to get it all back together once the frame came in. I get my truck back and take it for a nice long spin. Everything feels great! I get home, open the tailgate, (I had a tonneau cover at the time) lo and behold, there's an empty 12 pack box of Modelo Especial in the bed...bottles too. No idea if the local hobos had a good time in the dealership parking lot or the techs while putting my truck back together :cheers: I never brought it up lol. I did however have my check engine light come on and I took it right back. Turns out they just forgot to connect a vacuum hose. Not a day after they fixed that, I was trying to beat a left turn signal and smoked a median doing like 30... instantly destroyed my alignment. Took the truck back again. I even admitted my mistake and they aligned it for FREE!
    2 things that I noticed later on. 1.Theres a big ol white sticker slapped on the frame that says: MADE IN MEXICO like wtf they told me it was coming from Japan? Maybe it did but was assembled in Mexico..no idea how that works..maybe that explains the Modelo. LAWL. 2. I noticed after awhile that my hood was kind of shaking. Come to find out, they forgot to replace the nut that goes on the bottom of my radiator core support bolts. The bolts were literally just sitting in the hole. I had been driving it like that for like two months! I ended up replacing the core supports myself with some poly bushings and some nuts from the hardware store. I didn't contact Boulder Toyota cause I had moved away but I'm sure they would have fixed it for free.
    This whole process aside from the bushings I replaced, cost me $0. All the fluids were also replaced for free. My experience with Boulder Toyota has always been great, I would definitely reccommend them to anyone on the Front Range. So anywho, kind of a long story but I thought you might get a kick out of my good (but strange) experience.
  18. Oct 4, 2020 at 9:45 AM
    lightlytoasted1726
    Thanks for the story haha. They told me my frame would probably ship from Texas but we'll see. I assume they'll have to align the truck after assembly as well?
  19. Oct 4, 2020 at 9:48 AM
    lightlytoasted1726
    You think if I bring them something like Bilstein 5100s and an add a leaf they'd agree to put it on? lol
  20. Oct 4, 2020 at 9:54 AM
    whiteknight4x4
    Drew
    Missouri
    My truck drove straight as an arrow when I got it back, that is until I smoked that curb lol.
    I asked my dealer about this, they said as long as it was components such as suspension that will already have to go on the new frame, it shouldn't cost you anything. Just tell them what setting you want the 5100s set to. Hopefully your people will be as cool as mine were. Already sounds like they are.
    Muddinfun likes this.
