Toyota said inverter mod caused LSD-ABS failure???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yhiki, Oct 15, 2009.
  1. Oct 15, 2009 at 12:07 PM
    yhiki
    yhiki [OP] Active Member
    Atlanta
    09 PreRunner
    Toyota said that the inverter mod was the cause if LSD and ABS failure???
    My ABS, LSD, and Stability lights came on. I took it to the local dealer for repair. They said it was a communication frailer. They undid my inverter mod because Toyota said that that could be causing the failure. They then worked on the truck for 24 hours and then later told me that the problem was a wire behind the fuse panel was in the wrong place. They said I must have done it when I was modifying the truck. I told them I did not do anything under the fuse pane. I did not push the issue because they are not trying to make me pay for the repair.
    They did scratch the windshield on the inside while working on the truck and we are still trying to resolve that problem.
  2. Oct 15, 2009 at 12:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    Kick them in the nuts and then tell them they are full of shit, after you get the truck back fixed of course.
