Toyota said they cannot advise a dealership to check transmission fluid level on my truck...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sbpark, Feb 29, 2016.
  1. Mar 9, 2016 at 7:30 AM
    #101
    gearcruncher
    Canadain bumper technician
    It would be nice to know how the OP,s truck is doing ?
    When he finally found a dealership that would work with him , they said the fluid was " fine " yet he was experiencing severe symptoms of a transmission that was extremely low on fluid . His truck would fall completely out of gear to the point where it could have easily caused an accident .
  2. Mar 19, 2016 at 8:06 AM
    #102
    nizmoz
    nizmoz Member
    Abilene, TX
    2000 Camry
    Suggest read your manual.....
  3. Mar 19, 2016 at 9:01 AM
    #103
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    A little late maybe but I purchased my Tacoma from Earnhardt and my limited experience with their service department has been very good. The only service needed so far was the problem with the hood vibrating. This was back in early November and my truck was the first one they had seen with the problem. Got all the service managers out to look at it and take pictures, gave me a loaner and had it fixed the next day, no problems since.
  4. Mar 19, 2016 at 9:15 AM
    #104
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Please explain your statement. Temp range is 94-114*. Not full operating temp. I havent looked in my owners man but the required procedure would never be printed in an OM. Too complex for an owner to comprehend.
  5. Mar 19, 2016 at 9:36 AM
    #105
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The recommended procedure for checking the fluid level is for the ATF to be below 35°C (95°F) to start, but it must be below 45°C (113°F). If it is higher than that, you must wait for it to cool down before starting the procedure. The procedure then involves making sure that the ATF circulates to all of the components of the transmission by alternating between N and D for a period of time, letting the engine idle until the temperature reaches between 35°C (95°F) and 45°C (113°F), then you alternate between N and D again to circulate the fluid.
    Once on the lift, the vehicle must be level, you need to make sure that the tilt angle from the front to rear of the vehicle is within +/-1°.
    Jeff
  6. Mar 19, 2016 at 11:35 AM
    #106
    CVOTRDSPORT
    This is just the kind of info they do not put in an OM.
  7. Mar 19, 2016 at 12:08 PM
    #107
    Jeff Lange
    Calgary, Canada
    You also need to jump 2 of the pins on the DLC2 connector to make sure the engine idle does not fluctuate while performing the procedure. It really isn't "normal-"owner friendly.
    Jeff
  8. Mar 19, 2016 at 6:16 PM
    #108
    TRDTacoma626
    TRDTacoma626 Well-Known Member
    1 fucking quart low here.
    Dealer just filled it up today for me
  9. Mar 20, 2016 at 4:44 AM
    #109
    gearcruncher
    I wonder how the OP,s truck is doing ? Hasn't been around here since March 13th
    I assume it must be fixed because he hasnt posted back since his visit to the 2nd dealership ??????
  10. Mar 21, 2016 at 4:41 PM
    #110
    nizmoz
    nizmoz Member
    Abilene, TX
    2000 Camry
    All Toyotas are the same for this check that I have seen. I have owned many Toyotas, and currently my 16 year old Camry runs like a champ. There is a reason why it has lasted this long, proper care. Please make sure you read what Toyota recommends and not what you think.
    • Park the vehicle on a level surface.
    • With the engine idling and the parking brake applied, shift the selector into all positions from "P" to "L", and then shift into "P" position.
    • Pull out the dipstick and wipe off the fluid with a clean rag. Re-insert the dipstick and check that the fluid level is in the HOT range.
    • Do this check with the fluid at normal driving temperature (70 - 80°C, 158 - 176°F) .
  11. Mar 21, 2016 at 4:47 PM
    #111
    nizmoz
    nizmoz Member
    Abilene, TX
    2000 Camry
    Like I said, normal operating temperature.
    http://www.highcountrytoyota.com/faq/check-transmission-fluid
    Keep Your Car Healthy By Checking The Transmission Fluid Regularly To Ensure Smooth Gear Shifts, A Cool Transmission, And Properly Lubricated Parts.
    Checking the transmission fluid in your car is a relatively simple procedure and should be done about once per month. To get the most accurate reading you should check the transmission with the engine running and properly warmed up, on a level service. Follow these easy steps to check your transmission fluid:
    • First, remove the dipstick from under the hood (if you are unsure as to where it is located, check your owner's manual).
    • The handle is usually a bright color (generally yellow or red).
    • Remove the stick, wipe it clean, replace, and then remove it again.
    • There are labels for "Warm" and "Cold"- check the warm readings.
    • If your transmission fluid is not full, slowly fill the fluid up a little at a time, and continue to measure with the dipstick.
    • To fill the fluid you should use a funnel and pour it into the hole where you pulled the dipstick. After filling, replace the dipstick, and after a few moments remove to confirm that it has been done correctly.
      When checking your transmission fluid be sure to check it's color. Transmission fluid is a pinkish/red color usually, though it can be other colors like green. If your fluid is brown or dark, or if there is sand, dirt, or debris in the fluid, that is a sign that there may be something wrong with the car. If this is the case, schedule a service appointment at High Country Toyota in Scottsboro, AL, where our experienced technicians are more than happy to help!
  12. Mar 21, 2016 at 7:55 PM
    #112
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    @nizmoz, the 2016 Tacoma does not have a transmission fluid dipstick, so its not like all other Toyotas you have owned.
  13. Mar 22, 2016 at 4:17 AM
    #113
    gearcruncher
    nizmoz[QUOTED] likes this.
  14. Mar 22, 2016 at 3:18 PM
    #114
    Jeff Lange
    Calgary, Canada
    None of this applies to the transmission in the 2016 Tacoma.
    Jeff
