Toyota says: Change tacoma synthetic oil every 5000 miles. Why?
Discussion in '4 Cylinder' started by TurnTheLead, Jan 9, 2012.
  1. Jan 10, 2012 at 6:57 PM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    I can tell you this as a Toyota tech u change your oil every 5k your good. If longer than that you will be all sludged up seen it. For what it's worth
  2. Jan 11, 2012 at 1:00 PM
    RTaco
    RTaco Member
    4 cyl. 4X4
    In my manual it's written to change every 16,000 km. or 10,000 mi..
    The first oil change is scheduled at 8,000 km. When I did it, the oil was still clean.
    My taco is a 4 cyl 2011.
  3. Jan 11, 2012 at 1:07 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    This is copied right out of the scheduled maint guide for a 2011 tacoma:
    5,000 miles or 6 months
    Check installation of driver’s floor mat
    Inspect and adjust all fluid levels
    Replace engine oil and oil filter
    Rotate tires
    Visually inspect brake linings/drums and
    brake pads/discs
  4. Jan 11, 2012 at 1:11 PM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    I have 4,568 miles on truck and the warning light started flashing on today.
  5. Jan 11, 2012 at 1:13 PM
    Toyota Tech31
    Debary, Florida
    Thats normal, it will flash like 400 miles before it's due, then go start going solid i think 50 miles before or something like that.
  6. Jan 11, 2012 at 5:38 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    this pretty much goes for any yota. every 5k change the oil and it'll last forever.
  7. Jan 11, 2012 at 8:39 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Yup...5,001 miles and all hell will break loose. :rolleyes:
  8. Jan 12, 2012 at 12:42 AM
    TurnTheLead
    TurnTheLead [OP] Active Member
    Mississippi
    2012 PreRunner SR5 4x2 2.7
    Rubber bed mat, Tuff Tonno cover.
    I wouldn't have a problem if it's 5000 miles with regular oil. That's a $30 change at the dealership. A synthetic change, which I have to get since my truck came with synthetic, costs $60. Usually the payoff with getting synthetic is that you can get it changed half as much, offsetting the cost, which is about twice as much.
    With synthetic you shouldn't have to change it every 5-- which is why toyota recommends 10k for almost every single one of the other vehicles they make, except for the 4 cyl tacoma. Why is the Tacoma 2TR-FE different? wtf..
  9. Jan 12, 2012 at 12:46 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Our BMW goes 15-18k on synthetic based on the computer adjusting for driving conditions. I go 5,000 with synthetic on my Tacoma. The Duramax goes 10k on 12 TBN synthetic. They all vary.
  10. Jan 14, 2012 at 4:02 PM
    frog13
    frog13 Well-Known Member
    These are still combustion engines...CNC machining or not.
  11. Jan 14, 2012 at 4:08 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would change the filter with more frequency than a full synthetic.
  12. Jan 14, 2012 at 4:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have a friend who owned a gas station that still had a shop built into it. He had one customer who insisted on changing his oil with Mobil 1 every 3K miles. My friend used to save the oil from that customer's car and put in in his personal vehicles. He'd run another 7K on it and then throw it away. I think he changed his oil filter at 3500 miles though. I certainly won't recommend doing it blindly, but I would suspect that with Mobile 1 and a good oil filter, an oil analysis will probably prove that 10K is safe.
    However, oil analysis or not, if your engine blows up and Toyota asks for your oil change reciepts and you only did it every 10K, no warranty for you. I'd do as they say until you're out of warranty.
  13. Jan 19, 2012 at 6:14 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    You can run dino oil if you want. It won't hurt the motor..:cool:
  14. Jan 19, 2012 at 7:22 AM
    Camshaft
    Camshaft Active Member
    Camshaft
    Saskatchewan
    Tacoma SR5 2.7 2wd
    GROM ipod, usb, 3.5mm input
    If your oil starts looking 'heavier' and has a very burnt smell to it replace it. I would also recommend running the larger capacity oil filter if you plan on following the 10 000+km oil change schedule. I knew a guy with a 2006 4.0l 4x4 taco and it started burping oil out at around 10 000kms ( likely clogged the smaller filter) Just my 2cents.
  15. May 3, 2015 at 2:27 PM
    #35
    tbird71
    tbird71 Member
    Tom
    2015 Tacoma Double Cab Prerunner
    I've got 24 months free maintenance so no biggie. This is our part time vehicle, so we prolly wont have 5000
    miles in 6 months. But since it's free may as well do it
    After reading all this it is no wonder why these tacos are pure gold at resale time
    nothing else can come close
    300K with regular oil changes is conservative, anything with less than 100K is considered extremely low mileage
    I'll drive this little taco for practically nothing
  16. May 4, 2015 at 9:17 AM
    #36
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I change my oil every 7k km with Mobil 1 synthetic And a toyota filter. I'm about to do my second diff change as well (the po never ever did it but the truck never left the pavement before I got it) I use my truck hard to i treat it well. Even with 180k km's on the clock still runs like new, won't even hesitate when it comes time to SC this bad boy
  17. Jun 8, 2015 at 7:13 AM
    #37
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    I did my first change at 1,000 miles and used Mobil 1 0w-20 full synthetic. I do this with every new vehicle I purchase just out of habit. I just recently rolled over 10,000 and changed it again. Oil was still amber in color, barely darker than new and hadn't used a drop.
    10k intervals for me.
    I'll try to find an article I read awhile back showing that too frequent oil changes cause as much or more wear than not changing enough. According to the article, oil is most abrasive during the first 1,000 miles of use, in fact, even more abrasive than after it begins to break down.
  18. Jun 24, 2015 at 8:03 AM
    #38
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    This is the proper response. I use Mobil 1 and a Mobil one oil filter and I change mine every 7500 miles which is half the distance Mobil says you can go for both oil and filter. I drive just about all interstate 15 miles each way to work and once or twice a month go crawling around in the mountains. I haven't owned the truck for much over a year and am getting ready to do my 3rd oil change. I'll get an oil analysis done on this third one and take it from there.
    If you're going to go past the recommended change interval I would think it's a real good idea to change the filter and add a quart half way through eventhough these filter manufacturers, like Mobil 1 are saying you can go 15,000 miles on a filter. That's what I would do if I was going 10,000. Oil lasts forever. Contamination is why you change it.
    It also depends on what you're doing with the truck. Are you hauling heavy loads on dusty roads all the time in 100* weather?, Short tripping in sub zero weather? In other words, severe service?. It comes down to common sense and oil analysis if you're going to go past the factory recommended intervals. If it's still under warranty there is no way you should go outside the bounds of what the manufacturer recommends.
  19. Jun 24, 2015 at 8:24 AM
    #39
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Same here. It may be overkill, but a clean motor is a happy motor.
  20. Jun 29, 2015 at 2:18 PM
    #40
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    ^ This sums up my thoughts pretty well.
    I'll go out on a limb and say that at least 60% of Tacoma owners drive their trucks like they would drive a car: mostly paved roads, normal speeds, little/no abuse, etc. This means they should be on the "normal service" schedule and can safely go 7500 miles between oil changes on synthetic oil, assuming they are beyond the warranty period. If any of the "severe service" conditions apply, then the oil and filter should be changed more often.
