Toyota says lugnuts are warping my rear drums
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SloTaco89, Apr 16, 2018.
  1. Apr 16, 2018 at 3:16 PM
    SloTaco89
    SloTaco89 [OP] Member
    I have brought my 2017 Tacoma into the dealership now for the 4th time for wheel wobble while braking at all speeds. They have grinded down both the front rotors and the rear drums, and I continue to have an issue. They are now claiming that I have the wrong lugnuts on my TRD 4Runner wheels and that this is causing the issue. Has anyone ever had / heard of this issue before? Thanks.
  2. Apr 16, 2018 at 3:17 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Sounds like bullshit, if you have stock lug nuts you have a dealer problem not a truck problem
  3. Apr 16, 2018 at 3:17 PM
    riverrockar
    riverrockar Well-Known Member
    Indiana
    2017 Tacoma DCSB TRD Sport INFERNO
    I know overtorquing lugs can/will do that, but not the wrong lugs. got me. sounds like a cop out to me.
    BillsSR5 likes this.
  4. Apr 16, 2018 at 3:18 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Search bent axle. I'm sure that's your issue. Some 17s and 18s have it. Sounds like they're going to replace under warranty. Your dealership doesn't know yet obviously.
  5. Apr 16, 2018 at 3:22 PM
    SloTaco89
    After 2.5k miles I replaced my stockies with TRD Pro 4Runner wheels and Discount Tire used Toyota Lugs, but not "TRD" Lugs
  6. Apr 16, 2018 at 3:22 PM
    toyotatacomaTRD
  7. Apr 16, 2018 at 3:25 PM
    Chucky1953
    Chucky1953 Active Member
    2018 TRD Off-Road
    Pro-Grille
    Good God, all these things sound very "Un-"like. WTF?
  8. Apr 16, 2018 at 3:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you don't have the right lugs for the wheels, you can certainly have a mess.
    So do those wheels take a tapered lug or a flat bottom lug?
    Which are you using?
    hiPSI, Lawfarin and phsycle like this.
  9. Apr 16, 2018 at 3:28 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    There's at least 2 or 3 different kinds of lug nuts depending on which Toyota wheel you have.
    abarber11 likes this.
  10. Apr 16, 2018 at 3:31 PM
    SloTaco89
  11. Apr 16, 2018 at 3:32 PM
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    I've always brought my vehicles to busy, large-volume Les Schwab dealers. They usually know what to do in these situations. You'll have better luck having a problem free experience there than anywhere else, in my opinion. Sure you pay more but you get the great warranty and they usually do pretty good work. I only use them for tires and wheels. .. and a cheap easy lift.
  12. Apr 16, 2018 at 3:32 PM
    phsycle
    phsycle Well-Known Member
    CA
    Yup, exactly. Tapered, conical, flat. These may not be the technical terms, but something like that. If they're not able to seat right because the shape, it certainly can cause variance in torque, which MAY lead to issues. But I will say back in my college days when I had no money, I just guessed on torque (READ: Hamfisted) and never had issues.
  13. Apr 16, 2018 at 3:36 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I have the same wheels as you op and am using the stock lugnuts fom my OR with no issues for 10k miles now.
  14. Apr 16, 2018 at 3:38 PM
    SloTaco89
    I believe the TRD lugs are tapered. Discount Tire just used regular Toyota Lugs which I believe are not tapered. My old lugs below:
  15. Apr 16, 2018 at 3:40 PM
    SloTaco89
  16. Apr 16, 2018 at 3:49 PM
    airboatgreg
    airboatgreg Active Member
    Greg
    2018 Tacoma TRD 4X4.
    Die Meister Macher emblem
    If the steering wheel is wobbling it is the front brakes. If the brake pedal pulsates then it is usually the rear. Apply parking brake an see if wobble happens. The problem with machining rotors is they are already to thin and when you take material off(Turning) they heat and cool quicker causing warping. You may have a dealer issue
    tonered likes this.
  17. Apr 16, 2018 at 4:00 PM
    phsycle
    CA
    Warped rotors typically doesn't mean the rotors actually warp. Pulsating/shaking is caused by uneven deposits left by the brake pads after heavy braking. But I agree with you, machining rotors typically means less material, which results in rotors heating up faster, and prone to "warping" again.
    PackCon and tonered like this.
  18. Apr 16, 2018 at 4:05 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    While many TRD accessory wheels use a tapered cone type lug nut (and therefore require TRD or other cone-seat lug nuts), the 4Runner TRD Pro wheels use the stock shank style lug nuts. Have them check the installation instructions for those wheels (see Item #8):
  19. Apr 16, 2018 at 4:44 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
  20. Apr 16, 2018 at 7:18 PM
    SloTaco89
