Toyota says wiring harness needs replacing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Captainkbt, Dec 27, 2019.
  1. Dec 27, 2019 at 8:22 AM
    Captainkbt
    Captainkbt [OP] New Member
    Desperate newbie here needing help.
    2013 Tacoma with 87K miles. Pulled into driveway after running a few errands. Truck was running fine. Made a sandwich and a phone call went back out to run a few more errands and truck started very rough and all dash lights came on. This lasted less than five seconds and then it died and would not start thereafter. It was acting like it wasn’t getting fuel with half a tank. I’m thinking fuel pump. I have a scanner and ran codes P1603, P1604, P1605.
    I had it towed to a reputable shop with good ratings the owner/tech scratched his head for 3 days and replaced the fuel pump with no success. Owner/tech advised it needed to go to Toyota dealership and being a super nice guy didn’t charge me a dime.
    After several days at Loving Toyota in Lufkin TX, service Dept called and told me the “wiring harness” was “very corroded” and bad and would cost $3400 to replace (with labor), BUT they could do a bypass to the fuel pump to make it run for $500, but wiring harness would eventually have to be replaced. He actually accused me of running through high water, which I have not been over axles.
    I agreed to the temporary fix, paid $500 and truck ran fine.....for 5 days then crapped out again.....this time while driving. This time it felt exactly like I ran out of gas. Coasted in parking lot and had it towed back to Toyota in Lufkin.
    I am having a hard time understanding how a “wiring harness” can fail like this with 87K miles and just feel like this truck is in no mans land with no real answers. Wondering if anyone else has experience with this?
    Thanks in advance as always!!!
  2. Dec 27, 2019 at 8:29 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Welcome to TW! :hattip: :wave:
    It’s a shame you aren’t here under happier circumstances.
    It is amazing to me that a 2013 vehicle (especially one as mechanically and electronically simple as a 2nd Gen Tacoma) would be need the entire wiring harness replaced!
    My 2010 Tacoma 2.7L/auto has over 108K miles and has never had electrical problems!
    I was forced to drop almost $1,600 at the stealership back in 2018 when my mechanic couldn’t find a leak in my truck’s A/C system, and the dealer traced the leak to the evaporator core...
    It still boggles my mind as to how the hardest-to-access part of my truck’s A/C system developed a leak seemingly at random and for no reason when the truck was less than 8 years old and had barely 75K miles on it! It took over a year before the leak was finally found!
  3. Dec 27, 2019 at 8:31 AM
    PennSilverTaco
    Charlie
    Seriously though, find an honest independent mechanic to replace the wiring harness, and if you must go to the dealer avoid one in a wealthy zip code because they are used to dealing with people who have more dollars than sense, and their business practices are aimed at separating every customer from as much of their money as possible!
    Marc70 and 4x4spiegel like this.
  4. Dec 27, 2019 at 8:35 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    lets see pics of this corroded harness before passing judgement :duh::worthless:
    goforbroke123, GQ7227 and NYCTaco52 like this.
  5. Dec 27, 2019 at 8:36 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    What part of the wiring harness? Maybe they need to specify the next time you come in. It could be as easy as just the ground strap to chassis/motor or the entire engine harness or even interior harness.
    If I were in your shoes, I would like to know exactly what segment of wiring harness would be required to be replaced.
    I would take that information, purchase the required part and save some $ and install myself.
  6. Dec 27, 2019 at 8:38 AM
    PureWhiteYotee
    PureWhiteYotee Well-Known Member
    2015 White TRD Sport Long Bed
    I'd ask very specific questions, and have them take photos for you. Then you can go talk to somebody else and know exactly what you need to do.
  7. Dec 27, 2019 at 9:20 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Sounds pretty shaky to me. I'd seek out an independent shop that specializes in Toyota. I just cant see the need to replace a whole harness on a vehicle that will easily go 250K with regular maintenance. Maybe a rodent chewed on it somewhere or there is some other fluke problem outside of the harness. $3400.00 is a little insane. This is why I steer clear of dealers except for recall work that must be done by them.
    PennSilverTaco likes this.
  8. Dec 27, 2019 at 10:53 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Was the truck purchased new? If not was it a flooded vehicle. Might even be possible if it was purchased new. If the wire harness is corroded I would also look for signs of surface rust under the dash, kick panels and under the carpet. If signs of it possibly being a vehicle that was flooded I would be contacting your Insurance provider.
  9. Dec 27, 2019 at 11:19 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    After working in quality for about 30 years and without knowing anything else about the issue, I'd say a one off assembly defect by the manufacture. How to prove it, is another question. Absolutely nothing surprise me with this type of defect. To convince a service writer, tech, or corporate quality desk jockey of this is impossible. Notice, I said Quality Desk Jockey. Chances are the person you need to call has had no experience in shop quality assembly line personnel at Toyota. The quality at the assembly line is only as good as the attitude of the person doing the assembly. Subpar assembly issues will get by test and final inspection if it's done. Think BIS, (before in service) claims.
    Once a harness has been passed in test either at the sub-contractor, harness manufacture or in final assembly test, Toyota), the harness should last the life of the vehicle unless it had sustained some type of damage along the way. Water damaged, harness rubbing on something or was pinched somewhere along it's history. And this is what the corporate quality desk jockey will argue.
    4x4spiegel likes this.
  10. Dec 27, 2019 at 11:22 AM
    chiffonade
    chiffonade Well-Known Member
    lol no. this is not a mfg defect. a japanese wiring harness doesn't fail after 7 years. sounds like rodents chewed through your harness my dude...
  11. Dec 27, 2019 at 11:26 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Was some acorns on the engine. Now it's rodent damage. Insurance pays to fix that.
    GQ7227 likes this.
  12. Dec 27, 2019 at 11:26 AM
    PureWhiteYotee
    Had a rodent chew a set of brake lines once, that was fun.
    DG92071 likes this.
  13. Dec 27, 2019 at 11:34 AM
    Tayoflor
    Tayoflor Well-Known Member
    Taylor
    Woodinville
    2013 DCSB MGM
    Leer topper BAMF weld on sliders BAMF LCA skids Icon stage 4 SCS F5s wrapped in 285/75r16 Cooper Stt Maxx
    I work at Lexus as a tech, usually this is rode t damage. I have only seen specific pins in single connectors go bad, and those can use be replaced or repaired. As far as trying to do it yourself, replacing wiring harnesses is not an easy task. I admittedly have not replaced one on a Tacoma but, several vehicles require you to drop the motor to access all the harness
    DG92071 likes this.
  14. Dec 27, 2019 at 12:27 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Little beast chewed thru my injector wires once so pull the plastic engine cover off like 4 nuts or 10mm bolts and look. Mine was also leaking at the bypass hoses another chew spot. Dealer said harness same as yours over $3000 but could try a few splices and heat connections and that worked. Plus hoses and as I called it in to insurance as comp claim was covered and dealer said should do thermostat and coolant for contamination and I said do whatever insurance will allow as why not after $50 deductible. That was like 8 years ago.
    Hope its that simple for you and not water damage before you bought it. If it was whoever sold you the vehicle can be liable and taken to court - if a dealer they should do a full refund if you tell them you are calling the state attorney general as a fraud case.
    Comment above about a bad ground to the fuel pump was another good idea but again why did it happen.
  15. Dec 27, 2019 at 12:42 PM
    Muddinfun
    Muddinfun Well-Known Member
    With a last seen time the same as his 1 and only post, I will be surprised if he ever comes back. Oh yeah, “Thanks in advance” translates to “I’ve already thanked you. No further interaction is necessary on my part”
    @Captainkbt I double dog dare you to prove me wrong.
    Just sayin, people giving out lots of helpful advice, and the OP doesn’t seem “desperate” enough to stick around.
  16. Dec 27, 2019 at 12:45 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I hear ya. The one and done dudes are the worst.
    Larzzzz and Muddinfun[QUOTED] like this.
  17. Dec 27, 2019 at 1:17 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Shenolike...
  18. Dec 27, 2019 at 1:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is this some kind of a warranty issue?
    my relative has a 2o11 4cyl and i was cleaning/detailing out the engine compartment for them and was amazed at how many little things were corroded in there at only 42k miles
  19. Dec 27, 2019 at 1:47 PM
    DG92071
    DG92071 Well-Known Member
    Wham bam thank you ma'am lol
  20. Dec 27, 2019 at 4:40 PM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    Does Toyota not use waterproof connectors any more on the underside of the vehicle? My old FJ40 spent about as much time up to its headlights in water as it did on dry land; I never had so much as a taillight fail. You'd think a pickup truck made for off-road use would be a bit more water resistant. If it's truly a corroded harness, I think it's something other than an immersion problem.
