Toyota service center said it would be $1300+ to fix my heater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SSFtacoma98, May 10, 2020.
  1. May 10, 2020 at 1:41 PM
    SSFtacoma98
    SSFtacoma98 [OP] Well-Known Member
    California
    2013 TRD Off Road
    TRD Pro grill. TRD wheels, skid plate
    So here’s what’s going on. My 2013 Tacoma off road heater/AC stopped working a couple weeks ago. I thought it was due to the heater resistor or blower, so I went out and bought those parts and tried to replace it all myself. After that didn’t work, I said I might as well just go to Toyota and see if they can figure out what’s going on. After waiting all day yesterday for Toyota to figure it out, they finally call and tell me the reason my heater/AC stopped working is because of a technical issue with my heater control assembly. And said it would be $1300+ to fix it. I was shocked. And this is after I had to spend $250 on a “diagnosis” all for them to just figure out what the problem was. I asked them to give me the part number for the heater/ac controller that they said needs to be replaced, and it’s 55900-04070. I found it new on a couple of Toyota part sites for a little more than $500. I checked eBay and found ones for under a $100 that are salvaged from totaled Tacoma’s.
    So my question is, has anyone had this problem before. And if so, how did they go about fixing it. I am NOT going to spend the amount of money that Toyota quoted me. That is unreasonable just to fix a heater/AC.
    DG92071 likes this.
  2. May 10, 2020 at 2:29 PM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    A Toyota dealership quoted me $2800 for a faulty A/C system, hoses, condenser and so on. Took to an Indy who specializes in heating & A/C and fixed it for $1200. Shop around.....
    Sugar Silva likes this.
  3. May 10, 2020 at 2:36 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Can always remove the entire dash yourself
  4. May 10, 2020 at 2:36 PM
    DG92071
    DG92071 Well-Known Member
    I've read of this problem before on TW.
    I've also read of the heater control's plug being burnt.
    Once when I was driving on a nasty hard pack dirt road in Tijuana my A/C started changing speeds on its own but I haven't had the problem since.
  5. May 10, 2020 at 3:05 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yup. Sounds like the dash has to be removed. May be cheaper to install seat heaters.
  6. May 10, 2020 at 3:08 PM
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    As I have said before, Toyota built a truck around an a/c and named it “Tacoma” -
    To fix the a/c the dash has to come out - a royal pain in the ass - I paid 1200 to have the dealer fix mine on my ‘13.
  7. May 10, 2020 at 3:18 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The 55900-04070 control assembly is the panel with the knobs. No need to pull the dash apart to replace that. See attached pdf for how to test yours.
    JGO and Jimmyh like this.
