Toyota service cost
Discussion in '3rd Gen. Tacomas (2016-2023)' started by t'comatose, Oct 4, 2021.
  1. Oct 4, 2021 at 5:25 PM
    #61
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What are the benfits to change to an aluminum housing? I have 2 cars with plastic and combined mileage of 200k miles.
    I would bet a $20 , average diy'er has a sh!ty torque wrench(including myself) or not at all
    Tocamo and t'comatose[OP] like this.
  2. Oct 4, 2021 at 5:28 PM
    #62
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Seems about right for dealer. Depending how much your times worth you could obviously do it for cost of fluids and parts.
    Takes me about 30 minutes to change the spark plugs alone.
    Probably 2-3 hour jobs on your own.
    t'comatose[OP] likes this.
  3. Oct 4, 2021 at 5:55 PM
    #63
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Toyota did NOT charge him a penny, the OP was taken advantage of by a dealership because they could.
  4. Oct 6, 2021 at 8:55 AM
    #64
    t'comatose
    t'comatose [OP] Member
    kevin
    2016 Tacoma TRD 2wd 6cyl
    UPDATE: I rescheduled with same dealership for today, but have went over the list of maintenance they planned to do (list was without cost, except for the $206 rear differential service):
    1. Drain and refill oil (will ask to not do) (I go to other shop for this)
    2. oil filter replacement (will ask to not do) (I go to other shop for this)
    3. tire rotate
    4. cabin air filter replacement (will ask to not do) (will do myself)
    5. engine air filter replacement (will ask to not do) (will do myself)
    6. replace spark plugs
    7. torque driveshaft flange yoke
    8. install windshield washer solvent (will ask to not do) (maintenance not recommended per manufacturer)
    9. MPI multi point inspection
    10. install fuel system treatment (will ask to not do) (maintenance not recommended per manufacturer)
    11. install premium coolant conditioner (will ask to not do) (maintenance not recommended per manufacturer)
    12. perform battery cleaning service & install pads (will ask to not do) (maintenance not recommended per manufacturer)
    13. rear differential service (maintenance not recommended per manufacturer)
    = $1,300
  5. Oct 6, 2021 at 9:00 AM
    #65
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Dealer services are pricey . But you can shop around at other dealers since not all of them charge the same amount. The spark plug replacement is a lot of work and shop time .
    yoopersteeze likes this.
  6. Oct 6, 2021 at 11:50 AM
    #66
    asuchemist
    NONE
    Basically you have the following:
    Oil Change ($19.99 at any independent shop)
    Diff fluid change($89.99 at any independent shop)
    plugs ($149-199.99 at any independent shop)
    all the rest is always dealer fluff. local shop here will rotate your tires with oil change for free.
  7. Oct 6, 2021 at 11:58 AM
    #67
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    No chance you are getting Synthetic 0-20W oil changed for $19.99 and getting tires rotated. That’s. 79.99 job at independent shops in the Bay Area.
    t'comatose[OP] and yoopersteeze like this.
  8. Oct 6, 2021 at 12:01 PM
    #68
    Vlady
    Issy, WA
    0w20 5 qtrs cost more than you quoted
    Diff service - reputable diff oil alone costs close to your quote.
    Sparkplugs alone will cost you a over $100, not to mention driver’s side "difficulties" to replace them
  9. Oct 6, 2021 at 12:18 PM
    #69
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Those prices are insane for synthetic. Cost of supplies for me to do the oil change and diff alone exceeds those costs.
  10. Oct 6, 2021 at 12:32 PM
    #70
    asuchemist
    NONE
    Forgive me looks like full synthetic is $54.99 with rotation and semi-synth is $27.95 with rotation.
    suggest you bring your own fluid and plugs and just pay the labor.
  11. Oct 6, 2021 at 12:38 PM
    #71
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    $19.95 oil change? With what used motor oil ?
    the parts alone are $35 + at least 20 min in labor. So that would put you at $60-70 at cost and no shop overhead etc
    edit: looks like it was debunked
  12. Oct 6, 2021 at 12:39 PM
    #72
    maxmk8
    Which is cheap af if you ask me. Oil changes are loss leaders for any shop outside of Porsche that charges 699
  13. Oct 6, 2021 at 12:46 PM
    #73
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Excluding the tires, brakes, alternator and shocks I've had to replace I don't think I've spent $1300 total for service in the 14 years and 219,000 miles I've owned my truck. I do my own oil changes at 10,000 miles for around $30 using Mobile 1 and a filter bought at Wally World. I do my own air filter changes as needed Tires are rotated free from the tire store I use. Toyota reimbursed me for the U-Joint I replaced at 170,000 miles.
  14. Oct 6, 2021 at 12:46 PM
    #74
    asuchemist
    NONE
    Not debunked but updated. I had a local shop do all my work on my 11 before I started doing it. That is what they charged me.
    I quoted sundevil auto near my house with updated prices.
  15. Oct 6, 2021 at 12:48 PM
    #75
    maxmk8
    I don’t know what to say about that or what parts they used. But they sure as hell weren’t good parts. Regardless of whether or not they “ruined” the truck.
    $19.95 doesn’t get you a turn signal bulb change
  16. Oct 6, 2021 at 12:52 PM
    #76
    asuchemist
    NONE
    My 11 runs fine and feels more powerful than my 21 Pro.
    oil is oil. i put what toyota engineers spec and interval.
  17. Oct 6, 2021 at 1:02 PM
    #77
    Vlady
    Issy, WA
    Getting TP was not the issue a few years ago..
    asuchemist likes this.
  18. Feb 19, 2022 at 1:02 PM
    #78
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
    It's pretty pricey out there! Dropped off my 2019 Tacoma OR 4x4 and it cost $1150 for:
    - Fuel system/Throttle body service and cleaning (excessive carbon)
    - Oil and filter
    - Spark plugs
    - Front and rear Transfer case service
    - Differential service
    - 60k service (mostly the things listed above)
    - Tire rotation
    - re-torque propeller shaft bolt and grease
    Pretty sure I got hosed for a couple hundred, but saves the time of picking it up and taking it to an independent shop.
    Roast away.
  19. Feb 19, 2022 at 1:10 PM
    #79
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I don't doubt the op's bill if the dealer charges like ours here. I can get the same job done by our toyota certified napa shop in the next town for a little over half.
  20. Feb 19, 2022 at 1:42 PM
    #80
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Dealerships are getting greedy had my 4 Runner in for the last Toyota service and I asked them to look at evap pump thats making a LOUD noise ( that has been as silent as a mouse until now) $169 diagnostic fee thanks but no thanks....
    zoo truck likes this.
