Toyota Service Manager rude about me lifting my truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ctaro, Jul 31, 2018.
  1. Jul 31, 2018 at 10:01 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  2. Jul 31, 2018 at 10:07 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    $1300 to install blocks!?!?
    Oh hell no! No, no, no, no fukin way I would ever, in a million years, pay some dipshit mechanic to install a lift on my truck. Never ever ever... and DEFINATELY NOT blocks.
    (and yes, mechanics at stealerships are just as much dipshits as any where else)
    Ctaro[OP] likes this.
  3. Jul 31, 2018 at 10:08 AM
    Alden
    Alden Well-Known Member
    Alden
    Atascadero, CA
    2018 Cement Tacoma DCSB TRD OR AT 4x4
    Most dealerships don't install or sell level or lift kits. The ones that do charge twice as much for the "kit" and twice as much to install it. Out of the options you listed, I would purchase the $300 "kit", install it yourself and get an alignment.
    Your current warranty will still be valid, minus anything that the "kit" affected. You'll have a difficult time getting any dealership to cover steering components/tie rods, upper control arm bushings/balljoints, and CV joints under warranty if your truck is leveled or lifted at all. Frame, drivetrain, electronics, etc. will all still be covered 100%.
    Keep in mind, most warranties don't cover wear-and-tear items (like balljoints) anyway. Balljoints, tie rod ends and CV axles aren't expensive though. Save the $900 that the dealer is trying to rip you off on and use that for preventative maintenance or use the $900 difference to upgrade to an actual coilover and upper-arm kit like the Camburg entry level kit.
  4. Jul 31, 2018 at 10:10 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    And btw.... if that guy would have had that attitude with me, in my truck, while on a test drive... (Quote "I'd have told you to get the hell outta here")
    I would have pulled to the curb and told him he can walk his happy ass back to the dealership.
  5. Jul 31, 2018 at 10:11 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Do you need the lift right away? I'm more in the camp of driving it a few years until the warranty is done and the shocks are worn out .. THEN do the lift properly. You can save up for 3 years and get a really nice KING coilover setup.
    Gunshot-6A likes this.
  6. Jul 31, 2018 at 10:28 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Blocks change the way the truck rides cause you are not only changing the space in the shock tower you are changing the geometry of the shock. Which leads to rough rides and if you offroad it somewhat hard it could break things.
    Adjustable coilovers like king, fox, icon, ads, and I'm sure there's others would be best.
    Next step down would be new shocks with better/ heavier springs like eibach or ome
    Farthest I would go would be adjustable shocks like bilstein 5100 with the stock coils
    Ctaro[QUOTED][OP] likes this.
  7. Jul 31, 2018 at 10:33 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    That lift sucks. and you would be insane to pay that. A dealer doesn't decide what voids your warranty. Toyota corporate decides and the only things that should be voided by a lift are things affected by the lift. Lift and larger tire put extra strain on axle, driveshaft's, wheel bearing, steering components, transmission, tcase.......
  8. Jul 31, 2018 at 10:33 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    This is basically what I am doing. The rear springs are pretty clapped out, and so it is time to get regal...
  9. Jul 31, 2018 at 11:15 AM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    I can simplify lift arguments for you.
    1. If you are 2wd and don't offroad (you can still do light offroading carefully): The spacers and blocks are just fine.
    2. If you are 4wd and go offroad: Suspension lift (new shocks, coils, leafs and possibly upper control arms and bushing)
    If you don't fit into those two categories, you bought the wrong truck. :D
    I would talk to your dealer and see if you can bring your own kit and have them install. Most will and they will warranty the labor, not the parts. The kit from low range is much better quality so you won't have to worry about parts: http://www.lowrangeoffroad.com/toyo...a-tacoma-by-low-range-off-road-lr-lrtaco.html
  10. Jul 31, 2018 at 11:25 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    don't lift the truck you will just open Pandoras box for more expensive repairs that wont be covered by your warranty
  11. Jul 31, 2018 at 11:36 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    X2
    It's all about customer service
  12. Jul 31, 2018 at 11:38 AM
    Ctaro
    Ctaro [OP] Active Member
    Northeast, USA
    [/QUOTE]
    Thanks alot!
  13. Jul 31, 2018 at 11:39 AM
    Ctaro
    Northeast, USA
    All good points, so you end up adjusting or changing parts relative to those symptoms?
  14. Jul 31, 2018 at 11:40 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Something just hit me...
    Why in the HELL would you ever pay a >>Toyota mechanic<< 1300 bucks to lift your truck... if he has to even ask if your truck is lifted?
    Mr-Paul and Taco-Grinder like this.
  15. Jul 31, 2018 at 11:41 AM
    #35
    Ctaro
    Northeast, USA
    Yes true, I've always been friendly, and I don't think he meant to be extremely rude, more probably untactful but came across rude. I have some more research and consideration to do, I've read every response thanks to anyones opinion. Most seem to agree and this has changed my mind and saved me the hassle of finding out a bad lift after I pay to have it installed.
  16. Jul 31, 2018 at 11:48 AM
    #36
    Ctaro
    Northeast, USA
    Yeah I think I'm going to go this route, take my time, do research in the meanwhile and some other mods I want to do, I already upgraded my tires to wrangler duratracs, and a few other small mods, so far found the truck capable for the light-intermediate offroad I need it for. I think saving up for the better kit is going to do me better in the long run considering this truck is going to be with me as long as possible.
  17. Jul 31, 2018 at 12:13 PM
    #37
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes. Known issues and known remedies documented in the “Suspension” Forum.
  18. Jul 31, 2018 at 1:31 PM
    #38
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    two things...
    1. if readylift is blocks, nix that, do it right.
    2. tell the service manager to look up MagnusonMoss Warranty Act (P.L. 93-637)
  19. Jul 31, 2018 at 1:40 PM
    #39
    Ctaro
    Northeast, USA
    So you think I'm good to offroad light-moderate with stock setup?
  20. Jul 31, 2018 at 1:40 PM
    #40
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Yes, for sure.
