Toyota Service Mistake
Discussion in '4 Cylinder' started by rydaniels, Nov 17, 2011.
  1. Nov 17, 2011 at 5:05 PM
    rydaniels
    rydaniels [OP] Well-Known Member
    South Jersey
    4x4 4cyl manual
    bone stock except tool box in bed
    I took my tacoma in for the toyota care oil change tonight and when I got home I looked over the paperwork and it is noted that 5.5 quarts of 5W-30 were put into the truck. Of course the manual states 5W-20 or 0W-20...but it also says a higher viscosity oil can be used if the truck is operated under frequent heavy loads or at high speeds. I do not operate my truck at high speeds or under frequent heavy loads. I am more than likely going to take it back tomorrow to have 5W-20 put in. Any opinions on the matter? I dont think it is a tremendous deal but If ive been running oil per manual specs, i expect the right oil to be in it. Also this is the last oil change I will have them do.
  2. Nov 17, 2011 at 5:07 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    I think your being too picky.
  3. Nov 17, 2011 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You'll be fine with the oil they put in, but I suggest you learn to do it yourself if you want it done right, and with the oil you want. Otherwise, you get whatever bulk oil they want to throw in.
  4. Nov 17, 2011 at 5:13 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    It's going to make no difference whatsoever. No reason to waste a perfectly good oil fill.
  5. Nov 17, 2011 at 5:15 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    I was thinking that too....I mean there isnt too much of a difference....But I would hope that the dealership would know what type of oil goes in my truck per the manual. 5W-30 goes in the V6 but not my 4cyl again per the manual. Gunna sleep on it and see how i feel in the morning
  6. Nov 17, 2011 at 5:16 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    I have always done it myself...but free oil changes are free oil changes...Im going to switch to synth anyway after this cycle
  7. Nov 17, 2011 at 5:17 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    This is true
  8. Nov 17, 2011 at 6:23 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    You cant expect to get exactly what you want when its free.
  9. Nov 17, 2011 at 6:59 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    youre right....i did a little research on the differences...this is my first brand spanking new vehicle so..im a little uptight about it...but anyway I found this great article about the differences in viscosity and the like and why 5W-20 is essentially a product of CAFE standards and the desire to increase fuel efficiency in a laboratory setting.....www.machinerylubrication.com/Read/518/motor-oils
  10. Nov 17, 2011 at 6:59 PM
    Colombiarunner
    Colombiarunner Member
    johnny
    FLORIDA
    you should google viscosity of oil and learn what it means, if it were me, I would prefer the 5w30.
    click this link if you want a shortcut
  11. Nov 17, 2011 at 7:00 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    youre right...see my post above
  12. Nov 17, 2011 at 7:10 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Look at the bright side...at least they remembered to put oil back in!
  13. Nov 17, 2011 at 7:14 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    yea.....i got caught up looking at the 2012 crews on the lot and didnt read the paper work til i got home....as mentioned before, I did some more research and I believe it is better to have the 5W-30 in it than the 5W-20
  14. Nov 17, 2011 at 7:31 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    And how do you plan to prove they change what they put in it?
    They're going to drive your truck behind the wall while you have a complimentary cup of coffee, and watch tv. About a half hour later, they're going to apolgize and say, "You're all set." And you'll leave the dealership believing that they actually did something. Why not save yourself the aggravation?
    I have a better idea, You lay down and I'll kick you in the nuts. It will be alot less painful. :cool:
  15. Nov 17, 2011 at 7:38 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    you are a very honest and truthful man....I appreciate it....good point
  16. Nov 17, 2011 at 7:43 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    I would feel similar to how you are feeling. However, it's not going to do any damage, so call the dealership and complain and get your next oil change free. Then do it yourself after that one. Good luck.
  17. Nov 17, 2011 at 7:47 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    thanks...i figured use up the free oil changes while i got em but i miss getting underneath my truck and getting dirty.....thanks again
  18. Nov 18, 2011 at 5:55 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    I'd be uptight if i had a brand new truck too thought :D
  19. Nov 18, 2011 at 10:32 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    we have 22 new 2011 with the 2.7 in are fleet and they all get 15w40
  20. Nov 19, 2011 at 11:30 AM
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    15w40? That's what I run in my Cummins! Not in my 2.7
