Toyota Sevice Intervals (? Miles over before voiding warranty.)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mtn_man_mike, Feb 25, 2019.
  1. Feb 25, 2019 at 9:53 AM
    Mtn_man_mike
    Mtn_man_mike [OP] Active Member
    2017 DCOR
    Several
    Hello everyone,
    I’m due for my 20k service but due to several reasons need to push it back a bit.
    Does anyone know the amount of miles Toyota allows you to go over before potentially voiding warranty?
    Thanks,
  2. Feb 25, 2019 at 9:55 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Not sure about that but I would at least try to change the oil yourself.
  3. Feb 25, 2019 at 10:00 AM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Call the service center at your dealership.
    kahanabob likes this.
  4. Feb 25, 2019 at 10:02 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The failure has to be related to the maintenance work. e.g. if your radio stops working, the dealer can't reasonably refuse warranty repair because you didn't get an oil change on time. If your engine dies due to sludging, or if the rear diff grenades due to water ingress, then yes, but those failures are unlikely if you went over the maintenance interval by just a little.
    shakerhood likes this.
  5. Feb 25, 2019 at 10:09 AM
    Mtn_man_mike
    2017 DCOR
    Several
    Thanks for the replies! I’m only 400 miles past 20k but was curious if there was a defined cut off by Toyota.
    I’ll have to give them a call. I’m aware that it wouldn’t affect unrelated warranty work but the engine is a big one!
  6. Feb 25, 2019 at 10:15 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    A warranty does NOT become void like that.
    If you don’t change your oil for 50k miles and your engine ceases up... Toyota will refuse warranty coverage for your engine.
    If you fail to change your oil for 50k miles and your transmission blows up, you’ll get a new transmission under warranty.
    The warranty claim has to be traced back to your failure to do a recommended service item. The warranty as a whole is never voided.
    You also do not have yo have your service done by a dealer. You can change your own oil.
  7. Feb 25, 2019 at 10:30 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    I think you worry too much.....I had the 10k oil/filter at the dealer @7500 miles, no problem. I had 15k for the second freebee, no problem. Its not in stone within 3-4k.
