Toyota Speaks on Gas!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoskim, Oct 16, 2008.
  1. Oct 16, 2008 at 3:05 PM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    so i was talking to my service guy yesterday and told him bout our huge debate on which gasoline the 4.0 desires. he said premium is the way to go for these types of engines.
  2. Oct 16, 2008 at 3:09 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Oh great the guy can read the manual... I don't have much respect for the service guys:rolleyes:
    Besides the mpg jump I had (about 4 mpg) for using 89 instead of 83 I'm not gonna be using premium.
  3. Oct 16, 2008 at 3:10 PM
    jrw1965
    jrw1965 Well-Known Member
    Southern Maryland
    '08 dbl cab long bed 4 x 4
    Front tint, Stainless steel nerf bars, Leer tonneau, Rear spring TSB, Michelin LTX A/T2 265 70 16, Pioneer AVIC X910 so far
    The book says 87. Did he give you a reference
  4. Oct 16, 2008 at 3:10 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea well if u have a good relationship with ur service guy youll be surprised on how much money they can save u by giving u their discounts. my service guy is ok in my book
  5. Oct 16, 2008 at 3:14 PM
    tacoskim
    Los Angeles, CA
    Stock
    he said on the 4 banger 87 will run fine, but for the 4.0 premium is the right way to go
  6. Oct 16, 2008 at 3:18 PM
    Toyhauler
    Toyhauler Well-Known Member
    SoCal
    08 PreRunner TRD Sport
    ehhhh i ran 91 before and gas mileage still sucked, a little bit more power but 87 will do.
  7. Oct 16, 2008 at 3:20 PM
    tacoskim
    Los Angeles, CA
    Stock
    the idling is alot smoother with premium. same with acceleration, also not much of a ticking with 91
  8. Oct 16, 2008 at 4:37 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Well, it's not exactly "Toyota" speaking out on gas. It's your service rep. There are service reps who say the suspension is fine even though there is a TSB out on it. Mine runs fine on 87 (not ethanol). I was running mid-grade when I first bought it but tried regular. No difference in mileage on mine (unless your truck runs crappy on regular, you won't see a boost in mileage). Our truck is right at the threshold for going to premium (10:1 compression). Premium is recommended for any vehicle with over 10:1 compression. If your truck isn't knocking when you hit the accelerator (sign of preignition), going any higher is just a waste of money.
    You might see a mileage difference if your regular gas is ethanol.
  9. Oct 16, 2008 at 4:40 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    How about with the 3.4's?
  10. Oct 16, 2008 at 4:41 PM
    tacoskim
    Los Angeles, CA
    Stock
    thanks for the compression info. sorry should of clarified my self more when i said "toyota" speaks bout gas
  11. Oct 16, 2008 at 4:42 PM
    tacoskim
    Los Angeles, CA
    Stock
    3.4 are perfectly fine with regular
  12. Oct 16, 2008 at 4:42 PM
    jrw1965
    Southern Maryland
    What He Said
  13. Oct 16, 2008 at 4:45 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    Tacomas have VVT (variable valve timing). Which means that the truck will change the timing in which gas is let into the cylinder as well as change the timing in which the spark plug fires. Tacomas will never knock, but you may see a difference in gas milage based what type of gas you put in.
    I'm trying premium for the first time, hopefully my gas milage goes up.
  14. Oct 16, 2008 at 5:27 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    thank u i have been saying this forever.
  15. Oct 16, 2008 at 5:30 PM
    allrsdup
    Sahuarita AZ.
    and yes they will nock mine pings like crazy if i run 87
  16. Oct 16, 2008 at 5:31 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    My tick is so loud! :(
    87 is the only thing that fits in my budget though. :eek:
  17. Oct 16, 2008 at 5:36 PM
    Evil Monkey
    Robert
    Escondido, CA
    No difference in mine.
  18. Oct 16, 2008 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Toyotas will have knock. Not to the point of destruction, but they will have some.
  19. Oct 17, 2008 at 4:50 AM
    flavalk
    flavalk 2-Broke 2-Care
    Orlando, Florida via Huntsville, Alabama
    '07 PreRunner SR5 Double Cab 2WD - Short Bed - Automatic- Silver Mica
    Not much. Toyota bed mat, Toyota step bars, tinted windows, Toyota seat covers, Toyota all-weather mats, quart of Wild Turkey in the glove box, KelTec PT3AT in the center console, backseat full of old speeding tickets
  20. Oct 17, 2008 at 6:08 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I have never run anything but 91/93 in my truck it runs great. what does the 10% ethanol do? I noticed this morning the pump said "all grade contain up to 10% ethanol."
