Toyota Super White paint
Discussion in '3rd Gen. Tacomas (2016+)' started by baraban, Jan 6, 2020.
  1. Jan 6, 2020 at 12:41 PM
    baraban
    baraban [OP] Active Member
    Ig
    2019 TRD OffRoad
  2. Jan 6, 2020 at 12:53 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Just my $0.02
    I've used Dupli-color before with very good success. From the research that I have done, there is a lot more involved with matching paint other than the paint itself. If your painting a new item to match existing paint, the results can vary based on how you prep the new item. IE: Primer, Base Coat, Color Coat and Clear Coat. If you are very particular about getting a perfect match, you may want to pay a professional. If you can be satisfied with "close enough", then you will be happy.
  3. Jan 6, 2020 at 2:01 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    From 25 feet away sure
  4. Jan 6, 2020 at 2:29 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2016 DCLB TRD OR, 2019 T4r TRD OR
    Yup. Pretty dang close. Have used it with good results.
    baraban [OP] likes this.
  5. Jan 6, 2020 at 3:59 PM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Used it on my 2nd gen and followed up with the clear coat spray and it matched well.
