Toyota Tacoma 2.4L I-Force Turbo Engine - FULL Engine Review & Breakdown from Diesel Mechanic
Discussion in '4th Gen. Tacomas (2024+)' started by Crooked Beat, Aug 17, 2025.
  1. Aug 19, 2025 at 9:13 AM
    #41
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Wife's 2014 4Runner has 123,000 miles. Thermostat housing isn't leaking. Same 1GR engine in the 2012 Tacoma I traded in earlier this year never had any problems either.
  2. Aug 19, 2025 at 9:13 AM
    #42
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    The coolant crossover on the 3rd gen never was metal. It was plastic the entire run and did fail in statistically low numbers. 3rd gens also had a plastic thermostat housing that I don't ever recall hearing fail.
    I'm talking out of my ass here but I think the crossover failing was likely fatigue from joining the two heads together and them moving around slightly differently. This housing shouldn't see that stress.
  3. Aug 19, 2025 at 9:18 AM
    #43
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    can you show us any reports of Toyota coolant valves failing in significant numbers?
    b_r_o and WhakoDog like this.
  4. Aug 19, 2025 at 9:29 AM
    #44
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Dude, everything can fail. Your fuel pump could fail tomorrow, leaving you stranded. You could have a tire blow out and cause the vehicle to flip over killing everyone inside. A fuel line could burst open and start a fire. A ignition coil could go bad and send raw fuel down into the converter which would destroy it.
    I'm not saying plastic never fails, I'm saying they fail less on Toyotas than other manufacturers.
    How many cars do you look at on a daily basis?
    If you're that worried then walk or take the bus
  5. Aug 19, 2025 at 9:38 AM
    #45
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I've never seen a 1GR-FE with a leaking thermostat housing.
    I have seen the metal coolant crossover pipe leak.
    The 2TR-FE coolant pipe, yes. Plastic, it leaks.
    The fix was was switching to a metal pipe.
    To say plastic fails more is false.
    Plastic doesn't rust or corrode. If used correctly, it will far out live a metal component.
    Location, design, and use are the biggest factors as to when and where to use meta lor plastic.
    Longbow25 and b_r_o like this.
  6. Aug 19, 2025 at 10:15 AM
    #46
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    We don't know yet as it's relatively new. I think it's new for the T24A-FTS. It's an electronically controlled valve, so it's got a motor of some sort in it that could fail along with the usual materials choices concerns. On top of that, it's bathed in coolant, so there's the possibility of issues from coolant contamination, scale and the like.
    We do know that Toyota traditionally is better at keeping the beancounters from forcing compromises with materials choices to save pennies and that the Japanese are better in general at electomotive stuff, so I'm less worried than I would be if it were, say, something German.
    I can say that I plan to keep on top of my coolant change intervals primarily because of this valve, though.
    BearWithMe likes this.
  7. Aug 19, 2025 at 10:21 AM
    #47
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    3rd gen owner here.
    Over 103,000 miles - 2017MY bought in Sept 2016 - no issues with coolant or anything else.
  8. Aug 19, 2025 at 12:11 PM
    #48
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yes.
    It was plastic for some years. IIRC, Toyota swapped to plastic, then back to metal.
    https://www.tacomaworld.com/threads/3rd-generation-coolant-bypass-leak.797196/
    Toyota TSB: https://static.nhtsa.gov/odi/tsbs/2022/MC-10224166-9999.pdf
    1GR's had enough issues with the thermostat housing that a billet alu housing was manufactured and sold by a 3rd party. I helped a member on here replace his and gave him cr*p about his plastic engine (when I had a 1st gen). It wasn't a failure of the plastic, but the housing would warp and the o-ring would leak. Its a common enough issue.
    You can argue with the data all you want. I'm not saying its for sure, but the data shows what the data shows. I'm not happy Toyota uses plastic and I think its a fail item.
    Nobody has shown anything to make me believe otherwise. And before you go on about "there's no data" "he's just watching too much youtube" go ahead and search for yourselves. Camry, leak. Corolla, leak. Rav4, leak. 4Runner, leak. 2nd/3rd gen Tacoma, leak. Tundra 5.7L, leak.
    Look guys, I love this truck and I very much like Toyota. However, I don't like the idea of a Turbo charged open deck engine and plastic coolant pipes and housing. I don't care how many miles you or your wife has on their vehicle, I've seen the statistics. Plastic sucks. Open deck blocks and turbos... we'll see.
  9. Aug 19, 2025 at 12:16 PM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Driving around worrying that much sounds exhausting
    Longbow25 likes this.
  10. Aug 19, 2025 at 12:20 PM
    #50
    TnShooter
    Deogee
    STOCK
    I'm not sure what your argument is here?
    There is an argument to be made both ways.
    And there's no way to resolve an argument that's being "argued" from two prospectives at once.
    Therefor, I'm done here.
  11. Aug 19, 2025 at 12:32 PM
    #51
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I not arguing. I said these were a concern of mine. Then everyone jumped on the "Toyota is infallible" bandwagon. I'm honestly surprised so many people aren't aware of this issue. Just google it. Practically every manufacture has either a TSB, recall, extended warranty, and/or class action lawsuit for leaky plastic coolant housings.
    TnShooter[QUOTED] likes this.
  12. Aug 19, 2025 at 12:43 PM
    #52
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Thank you for bringing it to our attention. You're acting like nobody else has ever heard of plastic stuff breaking or something
    We aren't disagreeing with the existence of the problem. We're disagreeing with the prevalence of the problem.
    dneal, clownkillerloaf and TnShooter like this.
  13. Aug 19, 2025 at 12:58 PM
    #53
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Your welcome for further elucidating on the prevalence of the problem.
  14. Aug 19, 2025 at 12:58 PM
    #54
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    To be fair, I understand your reluctance to embrace plastic technology. I started shooting 1911s in the 70s and still do but after carrying a plastic gun for duty, that is what I would choose if I only had one gun. I can still shoot the 1911 faster and it's more accurate at longer ranges, but the other gun would still get the nod.
  15. Aug 19, 2025 at 1:00 PM
    #55
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Just a spectator here, where was the data?
    Oh nevermind. I see whats going on here. Opinions, data, its all the same I guess:notsure:
    Where can one find this research study?
    b_r_o likes this.
  16. Aug 19, 2025 at 1:04 PM
    #56
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Elucidate is a cool word. But you still haven't shown anything that compares Toyota's rate of failure compared to other manufacturers
  17. Aug 19, 2025 at 1:06 PM
    #57
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    OK so if the plastic thermostat dohickey breaks, is it hard to replace? If it's a couple hour job, not a big deal.
  18. Aug 19, 2025 at 1:18 PM
    #58
    gpb
    Atlanta
    Umm, no, that's not what you said.
    Broad categorical claims contrary to people's lived experiences will generate pushback.
    Did you actually read the TSB?
    The procedure is to recenter the water outlet pipe, not to replace it.
    Off Topic Guy likes this.
  19. Aug 19, 2025 at 1:19 PM
    #59
    Off Topic Guy
    I was waiting for this one. I'm glad others can read.
  20. Aug 19, 2025 at 1:24 PM
    #60
    gpb
    Atlanta
    The devil is in the details.
    I've liked this example of why it's important to read past the headline...
    Study 'Proves' Parachutes Don't Save People Who Fall Out of Airplanes
    Off Topic Guy[QUOTED] likes this.
