Toyota Tacoma 2.5’’ Shocks from Elka Suspension
Discussion in 'Elka Suspension' started by Elka Suspension, Apr 8, 2019.
  1. Apr 8, 2019 at 5:52 AM
    Elka Suspension
    Elka Suspension [OP] New Member Vendor
    Montreal
    Three shock options, two lifts available
    A- 2.5 DC Reservoir (2.5’’ body size, Remote Reservoir, Dual Compression adjustable)
    Top of the line truck shocks from Elka Suspension! Increased comfort and better handling on road. Plush compliance, firm and stable handling and extra bottom-out protection off road. Perfect for a daily driver truck with regular off-road use.
    Features:
    · Massive 2.5 hard anodized aluminum body
    · Heavy duty ¾” induction-hardened shaft
    · Internal hydraulic valving optimized for each truck models
    · Big bore design for increase response and less fading
    · External remote reservoir for extra cooling
    · Triple sealing system with dust wiper
    · Semi-synthetic oil blend, ultra resistant to high temperature
    · Fully serviceable and rebuildable
    · High speed and low speed compression adjustment
    · Spring preload adjustment (front shocks)
    B- 2.5” Reservoir (2.5” body size, Remote Reservoir)
    These shocks offer the same great features as our DC shocks, but without compression adjustment. Perfect for a daily driver truck with occasional off-road use.
    C- 2.5” IFP (2.5” body size, Internal Floating Piston)
    Tremendous improvement over the stock shocks, the Internal Floating Piston (IFP) Elka shocks are perfect for the drivers looking to improve the handling and comfort of their trucks with a simple and efficient shock package capable of light off-road duties.
    All Elka Suspension Toyota Tacoma front coilover shocks are available in two lift options:
    · 0-2” lift. Set from the factory at 1.5” lift for the front shocks to achieve a level look with the rear. This is the “leveling kit” option from Elka.
    · 2-3” lift. Set from the factory at 2.5” for the front shocks to pair with a rear lift kit. This option should only be installed along with aftermarket Upper Control Arms (UCA) to allow proper suspension geometry, correct down travel and perfect alignment. *Currently only available as call-in special orders with Eibach springs in silver color*
    Factory preload is adjusted to correct the “Tacoma lean”, but please note that it can vary from a vehicle to another so an adjustment may be required.
    All Elka Suspension rear shocks (remote reservoirs or IFP) are compatible with a stock truck and lift kits up to 2”.
    These are a bolt-on installation, no need to cut or trim anything on the truck.
    The Elka Suspension Toyota Tacoma shocks are engineered to offer the best performance both on road and off road for daily driven trucks. Elka targets drivers doing overlanding adventure, gravel roads, light off-road trails, light crawling and daily driving on all kind of good or bad roads.
    Shop all our Toyota Tacoma shocks here:
    Elka Suspension - Toyota Tacoma 2.5 Shocks
    TacoPandaTRD, _anthony_ and Abelgonz like this.
  2. Apr 8, 2019 at 6:02 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Welcome to TW.
  3. May 6, 2019 at 6:26 AM
    flinky
    flinky Well-Known Member
    2017 Black Tacoma TRD Sport
    BUILD -Window tint back windows -Clear Tint front to reduce heat -Method NV's Matte Black 16" (reduced from stock 17") -Pro grille - Prinsu Roof Rack - 40" Light Bar Cut Out - Prinsu Top Rack - ARE canopy (windoor, sliding window, roof rack) - Prinsu Load panels - Baja Designs Sport Fog lights - 2 tepui awnings LIFT -BFG K02's 265/75/R16 -2" lift 2.0 Fox Coil Overs -2.5" lift 2.0 Fox w/ resi (mounted high/ shock stone guard) -Added extra leaf
    Very interested!
  4. May 21, 2019 at 1:12 PM
    taco-newb
    taco-newb Active Member
    Brigham City, UT
    2010 Grey Tacoma 4dr TRD Sport
    2" level in front
    I know Elka has a great reputation among the race atv and utv crowd and has for years. I hope these perform just as well.
    meats and whatstcp like this.
  5. Sep 23, 2019 at 11:12 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    and available in Canada easily versus importing from USA.
  6. Dec 24, 2019 at 7:13 AM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    All of these are answered in the post.
    3/4", No(?), the latter.
  7. Feb 26, 2020 at 1:47 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Do these have a top out "bump stop" built in them? Maybe I missed in somewhere but I thought I saw a video of it somewhere as well...
  8. May 21, 2020 at 10:01 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    Is there any "deal"or discount for TW members?
  9. May 21, 2020 at 1:16 PM
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    I would recommend contacting Headstrong Offroad @HeadStrong Off-Road. I ordered mine through a GB they organized for Elka, but their normal prices are pretty good I have found.
    And I should also add, they are very helpful! Ask for Marie. Great service all around.
    HeadStrong Off-Road likes this.
  10. May 28, 2020 at 10:03 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you for the recommendation @Wackyhacky we truly appreciate it! :cheers:
  11. May 28, 2020 at 5:11 PM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Marie and the HeadStrong team took great care of me and was always responsive with details and other answers and solutions available. Now just waiting on my Elka 2.5 shocks and coilovers to be made, shipped, and installed!
    They are worth messaging and looking at their Elka offerings and full suspension packages.
  12. Jun 1, 2020 at 9:17 AM
    HeadStrong Off-Road
    Thank you so much @Greg's Outdoors we try our best :)
  13. Jun 1, 2020 at 9:20 AM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    do
  14. Jun 1, 2020 at 9:20 AM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    you? bahahahahahahah!:boink:
  15. Jun 15, 2020 at 8:21 PM
    #NEVERGIVEUP
    #NEVERGIVEUP Well-Known Member
    California
    2017 Quicksand DCSB TRD OR
    TBD
    I’m keeping an eye out for better deals on these.
  16. Jun 15, 2020 at 8:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Why a 1.5" spacer shaft spacer which finally leads into the lower rod heim instead of a solid 3" lower rod heim? Picture below for those who don't know what I'm talking about.
    I am not attempting to s**t on this thread, welcome to TW actually! I want to point out that spacer robs potential travel as it sits directly above the lower rod heim making that part of the shaft "dead space..."
    Unless these are being marketed as a direct OE replacement and not "extended travel" coilovers? Or is/ was there another reason for going this route?
    jcayce likes this.
  17. Jun 16, 2020 at 8:11 AM
    HeadStrong Off-Road
    Our kits have added discounts built in but if you are only looking for front or rear you can PM again and I can see what I can do for you.
  18. Jun 16, 2020 at 8:52 AM
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
    Do these come with a sway bar relocate spacer?
  19. Jun 16, 2020 at 8:53 AM
    HeadStrong Off-Road
    Yes
    Micatom33[QUOTED] likes this.
  20. Jun 16, 2020 at 8:54 AM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Solid question.
    Curious about the reply.
