Toyota Tacoma 2008 4x4 shift problem
Discussion in 'Toyota Trucks & SUVs' started by ritetoyota, Mar 14, 2011.
  1. Mar 14, 2011 at 8:11 PM
    ritetoyota
    ritetoyota [OP] Member
    Barry
    St. Albert Alberta
    08 Tacoma
    When I shift from 4x2 to 4x4 low it does not shift.. It remains in 4x4 High. The vehicle is an automatic. when I shift to 4x4 low the lite flashs and I get a sound that matches the flashing lite..B:(
  2. Mar 14, 2011 at 8:13 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You need to stop and be in neutral
  3. Mar 15, 2011 at 1:54 PM
    ritetoyota
    Barry
    St. Albert Alberta
    08 Tacoma
    I stopped and put it in neutral and it worked.. thanks for the advice and help..B
  4. Mar 15, 2011 at 2:01 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Life should be so simple in other matters, as well! ;)
  5. Mar 15, 2011 at 2:11 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    this is a great site. Ask a question and get an answer in a minute or two!
  6. Mar 15, 2011 at 2:14 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It should shift to 4lo under 5mph from 4hi. If it hasn't been used much, it may take a few tries.
  7. Mar 15, 2011 at 2:27 PM
    David K
    This card is found in your sun visor pouch (or should be)... note item #5:
  8. Mar 16, 2011 at 7:28 AM
    ritetoyota
    Barry
    St. Albert Alberta
    08 Tacoma
    thanks for all the advice..much appreciated..Barry..
  9. Mar 21, 2011 at 8:26 PM
    volcom85
    volcom85 New Member
    MN
    08 DBL Cab TRD OFFROAD
    hey does anyone know if you have to take the tow hooks off to put bull bars on?
  10. Mar 21, 2011 at 8:35 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    If you had got a manual you wouldn't have these problems mon!:p
  11. Mar 22, 2011 at 2:44 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Damage multiplier+thread jack=fail;)
