Toyota Tacoma 2009 turns on but turns off immediately
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ito, Jan 31, 2020.
  1. Jan 31, 2020 at 6:08 PM
    ito
    ito [OP] New Member
    My Tacoma runs normally after a while and before it turns off the slip indicator and the engine light turns on. Then when I turn it on again the engine starts and turns off immediately. My scanner shows PO351 and PO353 (ignition coils), but the ignition coils are good, i have changed the Crank Shaft sensor and the 6 spark plugs. And i still have the problem.
    Please Help Me!!!!
  2. Jan 31, 2020 at 8:54 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Bump, let’s help a brother out
  3. Jan 31, 2020 at 9:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is it the same codes each time?
    Or different each time?
    How do you know the coils are good? (They likely are, as 2 going bad at the same time is not typical)
    Have you swapped coils?
    Are you testing for power at the coil?
    IIRC, the coils share a common ground.
    Does the truck always start up, but die soon after starting?
  4. Jan 31, 2020 at 9:53 PM
    Waasheem
    Waasheem
    2007 xrunner
    Respond to the above questions then maybe you’ll get an answer. Check you have good ground from battery negative post to the engine block. Spark plugs are gapped correct, not counterfeit plugs?
  5. Feb 1, 2020 at 5:02 AM
    g8rnbft
    g8rnbft Member
    Blair
    2009 Gray Tacoma TRD, leather, sunroof, Bluetooth, 2" lift
    Failing chip in the key? Try using your spare key! That was my experience.
  6. Feb 1, 2020 at 6:19 AM
    ito
    ito [OP] New Member
    It turn on normally but immediately shouts off with out misfire
  7. Feb 1, 2020 at 6:24 AM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
  8. Feb 1, 2020 at 7:02 AM
    ito
    ito [OP] New Member
    i don't know, right now I'm far away from the car
  9. Feb 1, 2020 at 7:05 AM
    DG92071
    DG92071 Well-Known Member
    I'll leave these here.
  10. Feb 1, 2020 at 7:15 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    My 2009 Corolla is doing the same thing, just randomly, may be months apart, don’t have knowledge to troubleshoot, fix it myself, just going to drive till it does it and won’t start ever
  11. Feb 1, 2020 at 1:07 PM
    TnShooter
    Deogee
    STOCK
    You could check the Fuel Pump Resistor.
    A symptom of it going bad is start up and then engine dies.
    I think you can by-pass it to “test” it.
    Or you can actually test it with an Ohmmeter.
    Pretty sure the resistance should be some where between 0.71 and 0.75Ω
    Muddinfun likes this.
