TOYOTA TACOMA 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iversonhof, Feb 9, 2019.
  1. Feb 9, 2019 at 1:32 PM
    iversonhof
    iversonhof [OP] Member
    Nicholas
    2013 Toyota Tacoma Quad Cab
    Just stereo equipment
    I need some help. My Tacoma I bought brand new in 2013. Its a 4 cylinder. I drive it everyday with almost 100000 miles. Now I have a problem. During driving sometimes I push on the gas and it will go up to like 3000 RPM then the RPM shots down to like 1200 RPM. If I lift off gas and hammer it will take off like normal. Same thing if I'm driving sometimes it will be at 3000 RPM then loses power down to around 1200 RPM and I just leave my foot on there. After about 2 seconds it continues on like everything is perfectly fine. I have taken care to one toyota dealership and they don't know what wrongs with it. I have also taken to multiple auto zones and used different brands code reader. No codes. I've cleaned mass air flow sensor like 5 times. Please give me some other idea.
  2. Feb 9, 2019 at 1:47 PM
    GMan8402
    GMan8402 Member
    98 SR5 4x4 / 14 Prerunner TRD OR 4x2
    Is it getting enough fuel? Also the engine has the greatest stress on it when you hit the gas around 40mph... Could be an ignition coil going out? Just shotgunning here.
  3. Feb 9, 2019 at 2:00 PM
    desertrunner24
    desertrunner24 Chronic tacos
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Stock for now
    Could be a bad ecu. Have you had the battery tested? Is the alternator charging properly? Are your battery conections clean and tight? How about the grounds, clean?(body to frame and engine to frame)
  4. Feb 9, 2019 at 9:16 PM
    iversonhof
    Nicholas
    Don't know how to tell if its getting enough fuel. Ignition coil going out. Is there just one?
  5. Feb 9, 2019 at 9:20 PM
    iversonhof
    Nicholas
    No I have not had battery tested! I need to do that its same battery since I bought truck brand new. Alternator charging have not checked that yet. Battery I took off both positive and negative and cleaned them. There was corrosion all over it. But nothing improved or changed. Grounds I will check and clean.
  6. Feb 10, 2019 at 9:22 PM
    slayer fan
    slayer fan Active Member
    tommy
    ky
    2013 tacoma 4x4 regular cab
    2" lift.
    my truck exhibited similar symptoms about a year ago. it was the throttle body. I bought a used one from LKQ and haven't had it happen since. I guess the motor that regulates the butterfly was failing. my truck only had 38k on it at that time.
    desertrunner24 and TnShooter like this.
  7. Feb 11, 2019 at 9:50 AM
    TnShooter
    TnShooter Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
    I'm going to guess it's a fuel or air issue.
    Might be fuel pump or fuel pressure?
  8. Feb 11, 2019 at 12:02 PM
    hamachang
    hamachang Well-Known Member
    "Changy"
    Pasadena, CA
    '13 TRD Sport DCSB
    When's the last time you had a fuel injection cleaning?
  9. Feb 11, 2019 at 7:38 PM
    iversonhof
    Nicholas
    Other then cleaners like the 5.00 dollar crap never fuel injection cleaning
  10. Feb 11, 2019 at 7:45 PM
    iversonhof
    Nicholas
    I was told that the truck didn't have a fuel filter. Is that true? I thought it might be gas, because sometimes my truck will sit for like 45 days without being driven. But I've ran all the gas out numerous times to near empty to make sure no condensation was in there.
  11. Feb 11, 2019 at 7:49 PM
    iversonhof
    Nicholas
    I took that completely apart and checked the gasket. There was a bunch of black shit in there. It doesn't completely close! Is that normal?
  12. Feb 11, 2019 at 8:58 PM
    TnShooter
    STOCK
    The filter is in the tank.
    It’s not easy to access with out dropping the tank or removing the bed.
    Actually it’s considered a non serviceable part.
    You just replace it when you have to, which is when it causes problems.
    And if you go that far you might as well replace the whole pump.
    At least I would anyways.
  13. Feb 12, 2019 at 12:29 AM
    hamachang
    "Changy"
    Pasadena, CA
    '13 TRD Sport DCSB
    I also have a 2013 with 65K. I just had a fuel injection flush. Man, that thing drive like a new car. Smooth acceleration.
