Toyota Tacoma A/C stinks when I first turn it on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yorkiemom61, Sep 3, 2017.
  1. Sep 3, 2017 at 5:04 PM
    yorkiemom61
    yorkiemom61 [OP] New Member
    P J
    2012 Toyota Tacoma TRD
    I purchased a used 2012 Toy Tacoma in January. I don't recall smelling the horrible smell that I now smell every time I turn it on. It last about 2-5 minutes. It is an awful pungent perfume smell. Any suggestions?
  2. Sep 3, 2017 at 5:11 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Sounds like mold.
    I'd pull out the cabin filter and check that first. Next Check the a/c drain tube to make sure it's not clogged.
    outlawtacoma likes this.
  3. Sep 3, 2017 at 5:24 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Spray lysol in the cabin fan while its running
  4. Sep 3, 2017 at 5:29 PM
    yorkiemom61
    P J
    I have already replaced the cabin filter. I will try the drain tube, thank you!
  5. Sep 3, 2017 at 5:30 PM
    yorkiemom61
    P J
    My brother in law gave me that suggestion as well. It helped for the first time I turned it on, but the next day it still came back to that funky smell!
  6. Sep 3, 2017 at 5:33 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Drain tube probably clogged.
  7. Sep 3, 2017 at 5:37 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    rain flood damage from tx
  8. Sep 3, 2017 at 5:57 PM
    82ND_AAF_TACO
    82ND_AAF_TACO Well-Known Member
    New: 18 TRD OR Old: 09 SWB Pre TRD Sport
    There is some form of bacteria growing within your a/c system- due to something being clogged or not working properly. I'm not entirely sure what's the Taco AC component consist of, but I know the vehicles we work on have a dryer assembly that's suppose to separate the moisture from refridgerant from the AC lines- and from time to time gets clogged then we end up replacing it.
