Toyota Tacoma a/c
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011GTACO, Nov 15, 2015.
  1. Nov 15, 2015 at 7:44 PM
    2011GTACO
    2011GTACO [OP] Well-Known Member
    Dallas, TX
    2011 Gray Tacoma TRD sport 4x4
    I recently bought a 2011 Tacoma and every time I turn in the ac I hear this clicking noise by the glove box do you guys have that problem too?? If yes what is it or is it normal.
  2. Nov 15, 2015 at 7:52 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I haven't ever noticed anything to be completely honest. Maybe the compressor/fan? :notsure: Have you checked your cabin air filter located behind the glove box? I'm sure some others will chime in here shortly.
  3. Nov 15, 2015 at 8:28 PM
    Triple D
    Triple D Well-Known Member
    Florida
    07 4x4 Double Cab Sport Pack.
    If it's not the obvious leaf or debris stuck in the fan then it is most likely the "chirping" issue which is very common on Tacomas without the latest model blower motor. It's a noise that clicks or chirps caused by poor lubrication on the bearing I believe. If you search the forums for "blower motor chirping noise" you will see mounds of info about how to go about lubricating the motor however the only way to permanently fix this (if it's the issue) is to replace the blower motor with the latest motor which u think is number -044. I just did this as my 07' was making this noise more and more often.
    https://www.tacomaworld.com/threads/blower-motor-squeek-chirp-on-low-fix.28355/
  4. Nov 15, 2015 at 9:29 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    I had that once and a stick somehow got into my a/c intake, tore through the filter and was hitting the fan. I bet if you took out your cabin air filter and put your hand down by the fan you will pull out whatever is causing the issue.
  5. Nov 15, 2015 at 9:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
