Toyota Tacoma axle sticker question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mkkkahu, May 24, 2022.
  1. May 24, 2022 at 6:45 PM
    mkkkahu
    mkkkahu [OP] Member
    2014 Toyota Tacoma
    Can somebody explain what the sticker on my 2014 Toyota Tacoma axle means?
    C4 012314 0529 0rg 052
  2. May 24, 2022 at 7:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have no idea what the stickers mean.
    We could probably tell you more about the axle if you tell us what engine you have and if you have the factory E-Locker.
  3. May 24, 2022 at 8:55 PM
    mkkkahu
    mkkkahu [OP] Member
    2014 Toyota Tacoma
    Yes I have. 4.0 engine. No elocker.
    I have a Ted sport package and has 33 size tires. I was told it had a 5.29 gearing but not sure.
  4. May 24, 2022 at 9:26 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    No idea. Mine rubbed right off, just the big C4 was left when I bought it. Then I painted over it when I rust treated the axel.
  5. May 24, 2022 at 9:36 PM
    mkkkahu
    mkkkahu [OP] Member
    2014 Toyota Tacoma
    Ok thanks!!
  6. May 24, 2022 at 9:36 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Can't say definitively but more than likely it is a coded string intended to denote to the OEM date of manufacturer, batch group of manufacturer, origin of that particular metal and possibly importation or tax information.
  7. May 24, 2022 at 9:50 PM
    TnShooter
    Deogee
    STOCK
    The 4.0 (except XRunner) came with a 3.73 gear from the factory.
    Did you buy the truck used?
  8. May 24, 2022 at 9:53 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    TnShooter likes this.
  9. May 25, 2022 at 12:22 AM
    mkkkahu
    mkkkahu [OP] Member
    2014 Toyota Tacoma
    Yes, I did buy it used and that’s why I was curious about the sticker. I know the codes for the sticker on the door jamb but wasn’t sure if it was replaced.
    I had 5.29 on my 88 Toyota pickup with lockers and wanted to put lockers on this one because of the terrain I hunt in. I thought maybe I could go the easy way by interpreting the sticker but guess I have to open it up to see for sure. Limited slip works fine in dry mountain terrain but don’t do well in muddy mountain terrain. So gotta put the lockers and need to check the spline count also.
    Thanks!
    Wulf and ToyoTaco25 like this.
  10. May 25, 2022 at 10:06 AM
    TnShooter
    Deogee
    STOCK
    You can turn the rear tire and count how many times the driveshaft turns. No need to open it up.
    ToyoTaco25 and Wulf like this.
  11. May 25, 2022 at 10:07 AM
    Wulf
    rock raisin
    this, if it has 5.29s they will be aftermarket. any factory door sticker or axle sticker will not apply
    TnShooter[QUOTED] likes this.
  12. May 25, 2022 at 10:34 AM
    mkkkahu
    mkkkahu [OP] Member
    2014 Toyota Tacoma
    Thanks! Much appreciated that info!
  13. May 25, 2022 at 10:53 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    It means you're not getting your truck dirt enough.
    An 8 year old sticker on a suspension part that you can still read? :anonymous:
  14. May 25, 2022 at 11:52 AM
    mkkkahu
    mkkkahu [OP] Member
    2014 Toyota Tacoma
    Hahh! No just bought this truck from some city driver. My old truck drowned when launching my boat but it still runs!
    Here we hunt or fish nearly every week to feed the people in church. So my trucks get beat up pretty bad.
    Just put on Raptor lining on my whole truck cause it ggoes through some heavy stuff!
    TnShooter and davidstacoma like this.
