Toyota Tacoma biggest tires
Discussion in 'Wheels & Tires' started by jaerika499, Jan 6, 2011.
  1. Jan 6, 2011 at 7:15 PM
    jaerika499
    jaerika499 [OP] Member
    2008 Toyota Tacoman Crew cab
    What is the biggest size 16" tire that can go on the 2008 Tacoma Double Cab stock 4WD A/T tires?
  2. Jan 6, 2011 at 7:17 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    265/75/16
  3. Jan 6, 2011 at 7:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    265/75-16
  4. Jan 6, 2011 at 7:20 PM
    jaerika499
    what will happen if i use 265/70/16?
  5. Jan 6, 2011 at 7:21 PM
    ktmrider
    Junk
    nothing, it will be fine just a little smaller. I believe thats the stock size
  6. Jan 6, 2011 at 7:22 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Thats slightly shorter than a 265/75/16. so it will also fit.
  7. Jan 6, 2011 at 7:23 PM
    jaerika499
    are the yokohoma tires a good atv tire?
  8. Jan 6, 2011 at 7:23 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    search!!!
  9. Jan 6, 2011 at 7:26 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  10. Jan 6, 2011 at 7:26 PM
    jaerika499
    sorry i meant
    are the yokohoma tires a good AT tire?
  11. Jan 6, 2011 at 11:03 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    lmao i was about to start clowning i didnt even know yokohama made atv tires.
  12. Jan 6, 2011 at 11:12 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    What size tires do you have???
    My 3 trucks all had the same size, 265/70-16 (extra cab and double cab 4WDs)... 31" tires.
    Maybe if you aren't an Off Road TRD you have smaller tires???
    You asked what is the biggest (without a lift or mods?): 265/75-16... 32" tires.
  13. Jan 6, 2011 at 11:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I've heard good things about them
