Toyota Tacoma Bilstein 5100 Question - HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacozona, Jan 11, 2010.
  1. May 30, 2014 at 5:10 AM
    #41
    Lost pilot
    Lost pilot Well-Known Member
    Reid
    Nashville, TN
    04 TRD 4x4
    Front window tint, some other stuff
    For the bilsteins too? That's good. Shop quoted me 200 bucks just for the front
  2. May 30, 2014 at 5:44 AM
    #42
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    I didn't think it would either but it actually did alittle bit and yea I will get a pic up I'm still working on ordering the AAL.
    No diff drop needed here yet.
  3. May 30, 2014 at 5:53 AM
    #43
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    No sorry, I thought you were asking about the diff drop. As for the Billy's, if you don't have a spring compressor or don't feel like playing Russian rulet with one, I'd take your NEW Billy's and old shocks/springs to a shop and simply ask them to switch over shocks. Let them know which setting you want it at. I think I payed $50 to have mine switched over. Then just reinstall your new front setup in your truck. 4 bolts and the entire shock assembly comes out. Nothing to it
  4. May 30, 2014 at 10:21 AM
    #44
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    Roger. I'm gonna do it your way!
  5. May 30, 2014 at 7:00 PM
    #45
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Do you need a lift to fit 265? My truck is stock and 265 fit just fine. And you can't use 5100 in the rear without a lift.
  6. May 31, 2014 at 7:12 PM
    #46
    muddog67
    muddog67 Well-Known Member
    Sorry to get back to you so late , no I did not install longer break lines with the one inch blocks .If you go more then an inch like 1.5 lift then you should do longer break line if you are flexing allot . After installing the billies , what a difference on the smoothness of the ride after installing all four 5100s . I hit speed bumps hard and no problem and very smooth . Took this pic after I installed in the same spot as the pics on my profile b4 installed .
  7. May 31, 2014 at 7:15 PM
    #47
    muddog67
    Yes you should do the dif drop if your going more then 1.5 inch lift and the install for the kit is really easy just two bolts , but make sure you use a floor jack to drop the engine an inch .
  8. Aug 23, 2014 at 2:45 PM
    #48
    damiksterr
    damiksterr Member
    03 Prerunner SR5
    If I currently have 2.5" front top plate spacer, if I get the 5100 front adjusting shocks and add the top plate spacer, how much can I put the adjusting shocks at until it's maxed out?
  9. Aug 24, 2014 at 2:33 PM
    #49
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well the top groove on the 5100's would be "maxed out" & thats right at 2.5" of lift , are you talking about adding another 2.5" on top of that ??
    If so I'll say right now thats not going to fly well for you, you'd be so far out of range for alignment, not even sure if you could jam that whole mess (strut assembly) into place..
  10. Aug 24, 2014 at 5:08 PM
    #50
    damiksterr
    damiksterr Member
    03 Prerunner SR5
    I'm saying, would it be possible if I were to put the 2.5" top plate spacer on the adjustable shocks, and put it at 1" on the shock, would it cause any problems? In other words, with the top plate spacer on top of the 5100, what is the highest setting I can adjust the shocks to (0" of lift to max lift on shocks) without causing problems. Also, I forgot to add, I have the light racing upper control arms installed which give me a lot more room with angles cause of the amazing adjustability. Thanks!
  11. Aug 25, 2014 at 1:39 PM
    #51
    Porthos33
    Porthos33 Active Member
    Eric
    TN
    2002 Toyota tacoma prerunner ext cab
    brush guard, 3" coil spacer lift with add a leaf in rear, Are camper top, k&n air intake, 2 hella ff1000 driving lights
    You can't do that bud. You would have to change out your upper control arms once you get at or above 3 inches.
  12. Aug 25, 2014 at 1:54 PM
    #52
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    He does have after market uppers (LR's which are great) & they do add more geometrical diversity but pretty sure that 3" is going to be about it without going to spindles as well (didn't notice if prerunner or 4x)might even mix some aftermarket lowers as well, Not a 100% on this tho'...
  13. Aug 26, 2014 at 8:41 AM
    #53
    damiksterr
    damiksterr Member
    03 Prerunner SR5
    How much are spindles? I've never seen any for our year trucks
  14. Aug 26, 2014 at 8:51 AM
    #54
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Lift spindles for a prerunner ?? Depends.. The Max's are somewhere in the , ya know not sure but I'll take a stab & say around $600 maybe ?? Just guessing but for the higher end (not necessarily better) 4" spindles like Camburg's are going to push you right over $1000 for the set..
  15. Aug 26, 2014 at 8:55 AM
    #55
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    & that price is for 2nd gens but I don't think there would be much if any difference in price if available for 1st gens..
  16. Aug 26, 2014 at 9:23 AM
    #56
    damiksterr
    damiksterr Member
    03 Prerunner SR5
    Oh alright. So do you think 1" on the adjustable shocks and 2.5" top plate spacer would work or no?
  17. Aug 26, 2014 at 9:36 AM
    #57
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well that puts you at 3.5" , technically out of range for proper alignment but the LR's are adjustable & you could probably eek out a 1/2" of adjustment to put it back in range if you play with it some, don't know how your ride quality will be tho'....
  18. Jul 22, 2017 at 4:31 PM
    #58
    Tech1
    Tech1 Well-Known Member
    San Diego California
    TRD Sport
    Hi guys, I just purchased 5100 for my 2004 Tacoma extra cab 4x4, can you run these on the rear without
    1'' spacers. I know the instructions say 1'' spacer required due to the collapsing range of the shock, but
    I kinda believe in leaving things stock if possible old fashion I guess.
  19. Jul 22, 2017 at 4:34 PM
    #59
    muddog67
    It's recommended that you do at least a 1 inch block or spacer of some sort for the reason that they need room for down travel. If you only plan on driving on pavement and light dirt roads you'll be fine but if you do any slight flexing you will have a problem with down travel
  20. Jul 22, 2017 at 6:53 PM
    #60
    Tech1
    TRD Sport
    Does adding the 1'' block cause any issues , I'm planning on 5100 up front set at 1'' clip ring
