Toyota Tacoma dipping down a lot on front left after off-roading
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Liftanddrift, Nov 29, 2021.
  1. Dec 2, 2021 at 5:38 AM
    #41
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I read goodly.
  2. Dec 2, 2021 at 5:40 AM
    #42
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The gas spring force at any time is simply the gas pressure times the area of the rod. The floating piston size doesn't factor in.
  3. Dec 11, 2021 at 1:01 PM
    #43
    Liftanddrift
    Liftanddrift [OP] Active Member
    Devin
    2019 silver Toyota Tacoma Ted off-road
    3 inch fox 2.5 coils in front Add a leaf and 2.0 fox shocks in back Camberg upper arms 33” BFGoodrich tires Hidden bumper light bar
    thanks for all responses everyone! my 3rd gen is on jack stands and the lower control arm is supported by a floor jack, that is why the cv boot is compressed. yes the easiest way to remove the coil over is to disconnect the UCA. The reason i dont have a locking pin and the bolt looks like its walked out is because i put the bolt back on to hold the wheel hub while i waited for the coilover to be repaired. once i have everything put back together i will check if its leaning still and send pick of everything.
  4. Mar 10, 2022 at 4:28 PM
    #44
    Liftanddrift
    Devin
    Alright guys I have repaired the coil and have been riding on it for a bit to see if anything changes and it is still leaning heavily to drivers side! here are some pictures. It s not cause of taco lean or anything this is massive lean compared to when I first got it. Driver rear 6 inches from tire to fender. Passenger rear 7.5” driver front 4.5”. passenger front 6”. Any ideas?? If it’s the frames it’s the frame but I didn’t jump it so I doubt that would be the frame but who knows ‍♂️ Need to have somewhere to look
  5. Mar 10, 2022 at 4:36 PM
    #45
    Crunkbananas
    Crunkbananas Member
    Chase
    Portland, OR
    1999 Tacoma TRD, 2022 TRDOR DCLB
    Softopper!
    Have you been driving it like that for three months?
  6. Mar 10, 2022 at 4:39 PM
    #46
    Liftanddrift
    Devin
  7. Mar 10, 2022 at 4:46 PM
    #47
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Repaired the coil or replaced the coil?
  8. Mar 10, 2022 at 4:48 PM
    #48
    Liftanddrift
    Devin
    repaired. it was blown but it’s all fixed and works great
  9. Mar 10, 2022 at 4:49 PM
    #49
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Did you ever check the rear leafs? Because the driverside is probably bent/flattened.
  10. Mar 10, 2022 at 4:51 PM
    #50
    gudujarlson
    Minnesota
    Do you mean the shock?
  11. Mar 10, 2022 at 4:52 PM
    #51
    Liftanddrift
    Devin
    Yes it was and I got a whole new rear leaf kit so suspension is all good
    Lt. Dangle likes this.
  12. Mar 10, 2022 at 4:53 PM
    #52
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Wild ass shot in the dark, but have you put equal-height stands under the frame rails to see if a wheel droops lower?
  13. Mar 10, 2022 at 4:56 PM
    #53
    gudujarlson
    Minnesota
    Okie dokie. It sounds like we need to go back the beginning and fully understand where you at. Describe everything you did to the truck and post new pictures.
    skeletron likes this.
  14. Mar 10, 2022 at 4:58 PM
    #54
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Still need pics of both coilovers installed
    gudujarlson likes this.
  15. Mar 10, 2022 at 4:59 PM
    #55
    gudujarlson
    Minnesota
    It would be good to know the distance between the bottom bolt and the top hat of your front shock on both sides. Maybe on the back too. That might allow us to rule out a problem with the suspension.
  16. Mar 10, 2022 at 5:00 PM
    #56
    gudujarlson
    Minnesota
    We also need to know the amount of preload on each front coil over
  17. Mar 10, 2022 at 5:01 PM
    #57
    Liftanddrift
    Devin
    Yes I do mean my front shock
    i will try this tomorrow but what would that show that the frame is bent ?
  18. Mar 10, 2022 at 5:05 PM
    #58
    gudujarlson
    Minnesota
    I have no idea how to determine if a frame is bent, but Based on your description a bent frame seems unlikely.
    If you really think your frame is bent, I suggest taking it to a trusted shop.
  19. Mar 10, 2022 at 5:15 PM
    #59
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Possibly. I wonder if the upper frame mount is tweaked. Again, wild-ass guess. I've never seen one that didn't twist the rest of the frame and show obvious body panel alignment. But if the control arms are good, the suspension is good, then what else could there be? :notsure:
  20. Mar 10, 2022 at 5:16 PM
    #60
    gudujarlson
    Minnesota
    I don’t think we can rule out a suspension problem based on what we’ve seen and told.
    Rock Lobster[QUOTED] likes this.
