TOYOTA TACOMA FRAME NEED REPLACEMENT 2003 RECALL
Discussion in '1st Gen. Tacomas (1995-2004)' started by cvteck679410, Mar 27, 2018.
  1. Nov 2, 2018 at 5:07 PM
    #41
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    It will be recorded in the Toyota database. Check your VIN on the Toyota website.
  2. Nov 6, 2018 at 5:46 PM
    #42
    NightForce27
    NightForce27 Well-Known Member
    WNC
    2017 TRD Sport/2002 Tacoma
    I was just saying the coating saved me in regards of them accepting the recall. I got a whole new frame
  3. Nov 6, 2018 at 6:30 PM
    #43
    hoshor
    hoshor New Member
    I have a 2000 Tacoma. The frame was very rusty in 2014 when I took it to a local Toyota dealership. They would not deem the frame replaceable, but admitted it was quite rusty, so they sprayed it with anti-rust coating. By 2017, my frame had rusted through, but of course it is now outside the warranty. I'm assuming I'm SOL now.
  4. Nov 6, 2018 at 6:59 PM
    #44
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    They never replaced 95-2000, only 01-04, The rest of them got crushed.
  5. Nov 7, 2018 at 6:20 PM
    #45
    hoshor
    hoshor New Member
    Yes, you are correct, I mis-spoke. However, they didn't deem it crushable, they would now of course, but outside of the warranty for me....
  6. Nov 22, 2020 at 12:50 PM
    #46
    sundirec
    sundirec New Member
    George
    2003 Tacoma Extended Cab 4X4 w/ Off Road package
    Same Crap Here. I was able to follow the trail. 03 Taco 4x4 Extended cab. Bought in Nov '16 with 90 K. This past summer noticed a Rear Diff leak. @ different shops said they patched it up.
    Not! Blew the rear and lost the left rear brake line at the same time. Also for some time could smell fuel in the cab. Took to a Tranny/Rear shop. Part to rebuild $3400, Labor $900 plus brake line. But, he told that this frame was shot and not replaced.
    The Used Car Dealer I purchased from said it was a replaced frame. I'm about the 4th owner.
    I called Toyota and got the following information from the VIN. In 2010 the framed was retreated with Protection which extended the warranty a total of 15 years (from off the LOT date-January 03. They also replaced the spare under carriage plate which was another known issue. I put about 8,000 miles on in 4 years.
    It is now worthless unless I want to fix the rear (which was probably caused by rusted pinholes- brake line , probably from a rusty spring or just rust) plus frame work? Is it worth it? Good engine, low mileage for an 03. No oil burn!
    Bottom line, if I had known in 2018 that this frame was not replaced , I could have at least had a shot at negotiating a frame or Buyback from Toyota. It seems all Toyota Truck have Frame Rust issues. Especially here in PA. I had a Ranger prior, same thing.
    A rust shop told me that when Toyota redid the corrosion spray, their plan was to hopefully get it through the 15 year warranty phase.
    Worked like a charm
    Disgusted
  7. Nov 22, 2020 at 1:28 PM
    #47
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Hello George
    Welcome to TacomaWorld
    Depends how bad the frame is rusted through and how many places need repairs. upload_2020-1-29_20-32-46.jpg
    https://www.tacomaworld.com/threads/rust-prevention-treatment-consolidation-thread.355928/
    CygnusX191 likes this.
