Toyota Tacoma Makes Wah Wah Wah Noise at 40-50Mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chapman1991, Apr 5, 2025.
  1. Apr 5, 2025 at 8:29 AM
    Chapman1991
    Chapman1991 [OP] Well-Known Member
    Mathew
    Cullman Alabama
    2010 Toyota Tacoma PreRunner V6
    None
    I'm not great at describing car noises but it's the best I can do. When my truck reaches 40- 50 mph it makes a Wah Wah Wah Noise. Everyone I've asked says it's just the tires on the pavement. I don't agree. It gets a little louder and changes tempo as you go a little faster but stops at 50 mph or above. I've changed both front wheel bearings and I'm kinda stumped on this. I know some people on here got good ears and I can post a video but I'm not sure if the mic on my phone has picked it up quite good enough but I'll post it anyways. Any help would be very appreciated thanks in advance!
  2. Apr 5, 2025 at 8:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    High odds 'everyone' is right.
    Tell us how you've eliminated the tire possibility.
    BabyBilly likes this.
  3. Apr 5, 2025 at 8:40 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    If you have ATs or MTs, it’s probably just the harmonic drone of the tread on the pavement. I get the same waaaaAAAAAaaaa waaaaaaAAAaaaaa drone on the interstate.
    Chapman1991[OP] likes this.
  4. Apr 5, 2025 at 8:48 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    If you don't have ATs or MTs, it might be a U-joint or carrier bearing
  5. Apr 5, 2025 at 9:04 AM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    How many miles on the truck and what tires do you have?
  6. Apr 5, 2025 at 9:19 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    It has brand new tires
  7. Apr 5, 2025 at 9:34 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    I'm not familiar with ATs or MTs..is that All Terrains and Mid Terrains? And I just replaced the whole driveshaft also because my carrier bearing was shot. It has brand new all terrain tires and brand new driveshaft. Brand new front wheel bearings and sway bar links. It also has had a front and and back alignment with brand new tires balanced.
  8. Apr 5, 2025 at 9:35 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    It has 254,849 miles and has dextro all terrain tires that are brand new
  9. Apr 5, 2025 at 9:35 AM
    mxl556
    mxl556 Well-Known Member
    2021 Tacoma Trail
    Sounds like tires. If new, maybe they are out of balance?
  10. Apr 5, 2025 at 9:36 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    But why does it happen only at 40-50 mph?
  11. Apr 5, 2025 at 9:37 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    I got the tires balanced the same day I bought them.
  12. Apr 5, 2025 at 10:05 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Unless you have Jimi Hendrix on the stereo, it's probably the tires. Road surface and temperature makes different noises.
  13. Apr 5, 2025 at 10:08 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Did it start after the new tires?
  14. Apr 5, 2025 at 10:30 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    No. It was doing it before the new tires
  15. Apr 5, 2025 at 10:33 AM
    Waasheem
    Waasheem
    2007 xrunner
    This is something I used to believe untrue. Apparently worn shocks can cause some weird tire wear, which in turn can cause weird noises.
    Look at the tires. What do you see? Cupping, unevenly worn, feathering ?
  16. Apr 5, 2025 at 11:30 AM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    Well the tires are too new to see any wear as of right now but I'll keep a check on them. And I've replaced the rear shocks but haven't messed with the front ones.
  17. Apr 5, 2025 at 12:39 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Well. I looked at the tire. If it’s the Dextro Dat1 all terrain. It’s probably not the tires(since they are new)the pattern on that tire should be relatively quiet at this point. Are you saying before 40mph and after 50mph it does not happen?
  18. Apr 5, 2025 at 12:55 PM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    Correct. Before 40 mph it's quiet. And after 50 mph it's quiet.
  19. Apr 5, 2025 at 1:18 PM
    henryp
    Henry
    Montana
    And it’s a pre runner (2WD) right? I had a similar issue with my needle bearing after a lift but I’m 4x4.
    amyracecar and Chapman1991[OP] like this.
  20. Apr 5, 2025 at 1:36 PM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    Correct. 2WD PreRunner
