Toyota Tacoma Makes Wah Wah Wah Noise at 40-50Mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chapman1991, Apr 5, 2025.
  1. Apr 5, 2025 at 1:43 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Have checked the u-joints and carrier bearing?
  2. Apr 5, 2025 at 1:45 PM
    Chapman1991
    Chapman1991 [OP] Well-Known Member
    Mathew
    Cullman Alabama
    2010 Toyota Tacoma PreRunner V6
    None
    It has a brand new driveshaft. Like not even a month old
  3. Apr 5, 2025 at 2:18 PM
    gotoman1969
    Have you checked the pinion bearing?
  4. Apr 5, 2025 at 2:26 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    The reason I asked how many miles is because I was thinking it could be an axle bearing or pinion bearing. With that many miles it is possible it is a bearing in the rear end. Do you have any leaks or wetness around the pinion or rear drum brakes? That can be a sign of a bearing going out but not always. You can have a bad bearing and not have a leak.
  5. Apr 5, 2025 at 3:08 PM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    No not really. How do you go about checking that with the driveshaft attached?
  6. Apr 5, 2025 at 3:10 PM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    I haven't noticed any leaks. I did check the differential fluid and it wasn't low by any means. Will the pinion bearing leak diff fluid? Sorry I'm no mechanic by any means lol
  7. Apr 5, 2025 at 3:21 PM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    I just checked everything is bone dry. No leaks anywhere but like you said doesn't mean it's not bad. How would I check the pinion bearing with the driveshaft attached?
  8. Apr 5, 2025 at 3:49 PM
    Chapman1991
    Mathew
    Cullman Alabama
    None
    How do you check the pinion bearing and or axle bearing to see if they are bad?
  9. Apr 6, 2025 at 5:14 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Everybody sing along
    "And the wheels on the bus go round and round"
  10. Apr 9, 2025 at 1:35 PM
    jawmes
    jawmes Well-Known Member
    James
    Kauai, Hawaii
    2007 Tacoma 4x4 PreRunner
    I’m running into a similar sound, I also replaced my wheel bearings and driveshaft components too. Does the pinion bearing going out make noise on acceleration/deceleration only?
  11. Apr 9, 2025 at 2:28 PM
    Darty03
    Darty03 •‿•
    It can make a noise on both acceleration or deceleration.
    The simplest way to check for a pinion or wheel/axle bearing going out in the rear end is to drain the oil and look for glitter or a shimmer in the old oil.
    jawmes likes this.
  12. Apr 13, 2025 at 6:08 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Bad torque converter?
  13. Apr 15, 2025 at 9:19 AM
    StLouTacoma
    StLouTacoma New Member
    2011 Tacoma 4WD
    New JDM engine
    2011 Tacoma Base 2.7L engine.
    New tires. Balanced.
    Drive shaft center hanger bearing replaced (it had failed).
    Wheel bearings inspected and are fine.
    Pinion bearing seemed fine when we removed the drive shaft to replace the hanger bearing.
    The noise isn't maw maw maw.
    It's more like loud rode noise that increases as vehicle speed increases. Maaawwwwwwwwwwwwwwwwwww...continuously without any rhythm or periodicity.
    Dropping into neutral while rolling does not impact sound volume.
    I'm almost convinced that these Taco's are just loud trucks.
  14. Apr 15, 2025 at 9:25 AM
    henryp
    Henry
    Montana
    They are loud. Dynomat helps. First thing I did years ago when I bought it.
    StLouTacoma[QUOTED] likes this.
  15. Apr 15, 2025 at 9:33 AM
    #35
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the exhaust heat shield mounted to the floor above the cat is secure, maybe.
