Toyota tacoma need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by connroids, Feb 15, 2022.
  1. Feb 15, 2022 at 8:10 PM
    connroids
    connroids [OP] Member
    Connor
    Tacoma
    I have a 2005 toyota tacoma 4.0 auto. Was running great. Now it’s running rich, having rough idle and won’t rev passed 3k rpm. Cleaned maf, nothing. Also has cold air intake. Thinking about swapping with my bodies stock intake to see if that helps. If you got any ideas please let me know. Don’t know what else to try. Thanks in advance
  2. Feb 15, 2022 at 8:16 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Try unhooking the battery for a bit, reconnect and then nurse the throttle while it ‘re-learns”…
    maybe.
    cruxofthebisquit likes this.
  3. Feb 15, 2022 at 8:20 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Any codes? Seems like it would. What leads to the conclusion it's rich and not lean?
    MNMLST likes this.
  4. Feb 15, 2022 at 8:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like it’s in Fail-Safe mode.
    Do you have a check engine light On?
  5. Feb 15, 2022 at 8:53 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Good luck and I hope you get more helpful info. Threads with "Need help" in the title are typically reserved for emergencies... you may want to edit it.
  6. Feb 15, 2022 at 8:54 PM
    Anothertacomadriver
    Anothertacomadriver Active Member
    Anthony
    2014 Tacoma V6 Manual
    Make sure all your air boots tight
  7. Feb 15, 2022 at 8:59 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How do you know its running rich? Any codes?
    Did this problem start when the CAI was installed?
    12TRDTacoma, TnShooter and Dm93 like this.
  8. Feb 15, 2022 at 9:21 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    @connroids said he doesn't have any catalytic converters over here. Might be part of the problem.....
  9. Feb 15, 2022 at 9:28 PM
    connroids
    Connor
    Tacoma
    Getting code p0102. Which is mass or volume air flow circuit low input. Cleaned and even tried why friends mass sensor(same year and model) I’m saying it’s rich because the exhaust smells allot more like fuel, more then usual. I’ve had the CAI on for awhile but I’m now dealing with this problem.
  10. Feb 15, 2022 at 10:31 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Put a code reader on the OBD. Even though it hasn't gone to CEL, it could have a DTC logged that might give you a clue. Upstream O² Sensors might be wonky. Obviously, it can be a lot of things but try a scan tool first.
  11. Feb 15, 2022 at 10:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What kind of CAI is it? These trucks are particular about the type of intake you put on it and if you put the wrong type on, boom, code.
  12. Feb 16, 2022 at 2:43 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Have you checked the EFI #2 fuse ?
