Toyota Tacoma pulls left
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trigger61, Jan 19, 2016.
  1. Jan 19, 2016 at 7:45 AM
    Trigger61
    Trigger61 [OP] New Member
    2013 Toyota Tacoma TRD
    I have a 2013 Toyota Tacoma 4x4 TRD with only 10,000 highway miles on it. Ever since I purchased it, new, it has pulled to the left on almost every road I drive it on. The dealership has rotated the tires and aligned it. It helps a little bit for a little while but then it is right back to pulling left - and it's very noticeable. Going back to dealership tomorrow. What can I ask them to look at or do that they have not done?
  2. Jan 19, 2016 at 7:56 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    You say it did it since new - then why did you buy it? Did it do it on the test drive, or did it develop soon after you bought it?
  3. Jan 19, 2016 at 7:58 AM
    Trigger61
    Developed shortly after purchase.
  4. Jan 19, 2016 at 8:04 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Turn to the right, then.
    Just kidding; that sucks. Have you noticed this in other cars? When I drive in the left lane, my truck wants to go left because of the crown in the road. The opposite is true for the right lane as well.
    I know you said they did an alignment. Maybe the caster is at the edge of the spec and making your truck more sensitive to these things?
    Sorry, just throwing out ideas.
  5. Jan 19, 2016 at 8:07 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Post the alignment result sheet so we can take a look.
    Swap left and right tires to see if the pulling disappears or moves to the opposite side. Note this is different from the normal tire rotation "algorithm".
    Are you on stock tires? What tire pressures are you running?
  6. Jan 19, 2016 at 8:07 AM
    The Streak
    The Streak Member
    Tim
    New York
    2013 Silver Streak
    I could be a stuck brake caliper. After you notice it pulling to the left, stop, get out and feel the front wheel. If it feels warm/hot its the caliper. It happened to me.
  7. Jan 19, 2016 at 9:00 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Ask for a different tech to do the alignment.
    Ask when table and computer was last calibrated.
    Mine pulled right for 20,000 miles and through 8 attempts at the dealer. Turned out the alignment table hadn't been calibrated in 18 months. Once it had been calibrated and the head shop mechanic himself performed the alignment, mine tracked straight.
  8. Jan 19, 2016 at 9:02 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Also, try a different shop for an alignment. Different shop equipment might be calibrated differently...
