Toyota Tacoma "Real World" Gas Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maats, Jan 9, 2010.
  1. Feb 10, 2015 at 9:39 PM
    #341
    SoCalSteve
    SoCalSteve Sunshine Tax
    San Diego
    2017 F150 XLT
    Must say, I am impressed by everyones MPG's. My entirely stock truck, winter or summer, gets about 14 city with AC on and 15 if the AC is off. Highway is around 17. Once got 20 coming home downhill from Big Bear... was so shocked I doubled checked the Scan Gauge with the math, and there it was.
    No complaints though. This a a tall, heavy truck with big tires and low gearing. Exactly the reason I bought it!
  2. Feb 10, 2015 at 10:02 PM
    #342
    Tgreening
    Tgreening Check Check
    2010 TRD Offroad
    2010 4x4 w/4.0 auto. No lift that I can see (bought used) and rolling on 265/75R16.
    I'm not a heavy foot and normally stay 65, 70 max on the highway. I've been seeing around 16-16.5 mixed driving and 20 on the highway.
    Somebody said these trucks don't get decent fuel mileage. Wellll, my other truck is a tuned F-450 dually. That truck couldn't avg 20mgp if I put it in neutral and shoved it out of the space shuttle.
  3. Feb 11, 2015 at 5:49 AM
    #343
    jhcole
    jhcole Well-Known Member
    Hunter
    Birmingham, AL
    '15 DCSB 4x4 TRD-OR MGM
    ToyTec 3" w/ Bilstein 5100's
    Here are my fill up avg's so far on my 2015 DCSB 4x4 TRD OR (3" ToyTec Lift, 265/75/16 BFG AT KO2 Load Range E). Mostly city miles stop and go less than 50mph. I am applying a tire size correction factor to my MPG calc's in a spreadsheet.
    Tire Size Speedometer Calibration
    65mph is actually 67.22mph with the bigger tires, or a correction factor of 1.03
    So if I put 17gal in at fill up, and have gone 270 miles by trip meter, my ratio is 1.03 so my mpg is (270*1.03)/17=16.35mpg avg
    15.61
    16.47
    16.63
    15.49
    16.03
    14.66
    Total AVG: 15.82 (odometer <2000miles)
    My truck is advertised at 16mpg city, before my lift and tires, so I guess I'm not doing so bad after all.
  4. Feb 12, 2015 at 4:57 AM
    #344
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Your mpg may or may not be accurate. The correction you applied for the tire change may be accurate for the difference in mph between the 2 sizes, but it assumes your speedometer was accurate originally. My Tacoma, new oem tires, had less than 1% odometer error, but the typical 2-3 mph speedometer error. The two "meters" are independent of each other, and often have different % error. Additional error is introduced over time as tires wear. New Michelins (same size) record more miles than actually traveled.
    Bottom line - use a GPS or mile markers to establish odometer error. THEN calculate your mpg with correction factor.
  5. Feb 12, 2015 at 5:07 AM
    #345
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    All I can say is that with sticky, studded, oversized snow tires, 265/70-17, and winter gas, I am filling up at 250 miles and showing 1/4 tank...'11 AC 4x4, 6 speed and 3.73 gears.
  6. Feb 12, 2015 at 5:10 AM
    #346
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Just got 19 mpg, over 300 mi, in my '14 RCSB 4x4 MT, 245/75/16s
    Usually get 20-21... few warm up idles and has been bitter cold recently
  7. Feb 12, 2015 at 7:06 AM
    #347
    jhcole
    Hunter
    Birmingham, AL
    Good advice!
    Well check my odo with GPS to calibrate my spreadsheet.
  8. Feb 12, 2015 at 8:01 AM
    #348
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    2010 TRD OR, bed cap, sliders, 31" tires. I'm getting 17 around town, 20-22 on the freeway calculated from the odometer and fillup numbers including the 3% tire diameter change. Scan gauge really helps me keep my foot where it needs to be. Small changes in throttle affect mileage a lot in this truck without changing your speed much. My mileage matches the Scan gauge numbers pretty well. In November/December, had two tanks in a row where I got 12 and 13 mpg but I think those involved some gas theft. I put on an Autozone locking gas cap and mileage numbers picked right up. No Engine codes from this cap yet either.
  9. Feb 12, 2015 at 9:50 AM
    #349
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I use the Fuelly app when I fill up. Lately I'm getting around 14, but my average is still right around 15. That is not corrected for tires/mileage though.
  10. Feb 12, 2015 at 10:09 AM
    #350
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Update. After 4 fill ups on my 2015 4.0 AT, AC I get right at 16.1 city driving only.
    Update. After 11 fill ups it's now 18 mpg average. With 20.6 my best.
  11. Apr 30, 2015 at 8:04 AM
    #351
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I've tracked the past 4-5 tanks of gas. Mixed drive City/Hwy 70/30 I am averaging 16 MPG. Occasionally rip into it, but mostly cruising along in traffic 45-50 mph and some stop and go.
  12. Apr 30, 2015 at 11:34 PM
    #352
    Ron Knievel
    Ron Knievel Active Member
    Checked my mileage on a new 2015 crew cab off road trd with the 4.0 and manual. This was a combo of city driving (25%) and highway driving (75%) doing around 80mph.
    I averaged 15.3mpg.
    Is running premium gas worth the additional expense in these trucks?
  13. May 1, 2015 at 9:24 AM
    #353
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    No. Others will tell you it is, but it's not
  14. May 1, 2015 at 9:50 AM
    #354
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Unless you are towing a heavy load, in which case it is totally worth it.
  15. May 1, 2015 at 10:01 AM
    #355
    myke232
    myke232 Well-Known Member
    So, if I get a 2015 base 4x4 4 cyl. manual, and drive it conservatively (coasting in neutral down hills, not speeding up to red lights, shifting at 2.5k rpms etc.), would getting about 23-24 mixed be an impossibility?
  16. May 1, 2015 at 10:12 AM
    #356
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    It does make more torque lower running premium. 278 lb-ft of torque at 3700 RPM instead of 266 lb-ft at 4000 RPM.
    I do get better gas mileage with regular, but it's not significant. The power difference, to me, is noticeable on hills on the highway. No downshifting at the same speeds on the same hills on 93. If I run 87 it has to kick to 4th to climb.
  17. May 1, 2015 at 10:12 AM
    #357
    Harry
    Santa Fe NM
    Mixed driving I consistently got 21mpg. The only times I got 24 in my 2.7L was country roads at around 50mph.
  18. May 1, 2015 at 10:39 AM
    #358
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I got 20.8 on the last tank. First time I have checked since the highways on my commute bumped the speed limits by 5 - 10.
  19. May 1, 2015 at 10:45 AM
    #359
    myke232
    I would imagine that is the sweet spot...
  20. May 1, 2015 at 10:54 AM
    #360
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Averaging almost 19, broke 20 last fill up.
