Toyota Tacoma "Real World" Gas Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maats, Jan 9, 2010.
  1. Aug 18, 2015 at 5:48 AM
    #381
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    my truck is lifted with 285's and I am doing better than the website forecasts. I have averaged no lower than 19.5 and usually 20.5. Note I am 80 percent highway driving.
  2. Aug 19, 2015 at 10:11 AM
    #382
    Maats
    Maats [OP] Well-Known Member
    Belleville, On
    16 Tacoma Double Cab TRD Sport 4x4 Blazing Blue Pearl
    2015 Tacoma DBCB TRD. I have a 20 Km drive to work. I have 9 traffic lights to go through one way. Cruising on rural roads and in town, I am averaging 11 L / 100 Km. This is equivelant to 21 Mpg (US Gallon). I currently have 2500 Km on the vehicle.
  3. Aug 19, 2015 at 10:56 AM
    #383
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    2015 Access Cab, 6cyl, 4x4, SR5, Cooper AT3 (265/R70/16), Procomp Rims, sound deadening, running boards. Last 3 tanks average 19.1
    Mixed driving 70% local, 30% interstate. 50-50 level and hills (very hilly here).
    2450 on the OD.
    When I do the next fill-up, I'm taking it to the local gravel yard and getting a true weight.
  4. Aug 19, 2015 at 11:00 AM
    #384
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 08 seems to average 18.9-19.1 doing everyday driving but strangely it gets lower on the highway.
  5. Aug 19, 2015 at 11:01 AM
    #385
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    2013 DCLB V6 w/ 8k. The best I ever got was 17mpg, I'm averaging between 15-16, with 95% city driving.
    Maybe my plastidip badges are weighing me down.
  6. Aug 26, 2015 at 9:37 AM
    #386
    shakerhood
    Southern Ohio
    I have 300 miles on the new truck and got 21 mpg on the first fill up. I was feeling pretty good about that until I just checked the tire pressure only to see the dealer had them cranked up to 46 psi. I am sure it will drop now that I set them correctly but then again the engine is not even broke in yet.
  7. Aug 28, 2015 at 2:15 PM
    #387
    AJS5870
    AJS5870 Well-Known Member
    Andrew
    Raleigh
    2012 TRD Tacoma, DC magnetic gray
    Tint, De-badged. Soon to come. 3" front leveling kit, 265/75/r16 on mickey Thompson classic 3 in black
    Im banking 21-22 mpg with a 3" lift, 32" tires, after market rims but I'm all highway. running 36 psi, alignment is good, synthetic oils, clean air filter.
    also the truck has a learning ECM and adjust fuel input based on how you drive. if i drive heavy i get 17mpg, but i can drive to the beach, 140 miles. Drive on the beach 4 miles down 4 back plus some play time in-between, and drive 140 miles back on a full tank. IF i drive 65mph there and back. 75 i have to fill up before I'm half way back home.
  8. Oct 12, 2015 at 8:07 PM
    #388
    juyeates
    juyeates New Member
    Ok, you guys think you've got it bad... I have a 4 door 4wd 2009 tacoma with 2.5" lift and B F Goodrich AT tires and I'm getting 13.5!! A friend of mine has the same truck but a 2006 with very similar tires and has always got 18. I've had it checked out, O2 sensors and everything we could think of but no difference.
    I love this truck but I'm starting to think there's something wrong. Any ideas??
  9. Oct 12, 2015 at 8:31 PM
    #389
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    After a fresh oil change and new air filter, I got into the high 20's on the highway yesterday with 27mpg being my best and 21mpg being the average. 3.4 V6, completely stock bumper to bumper for now. I love this truck, gets the same mileage my 4 cylinder did and has more power!
  10. Oct 13, 2015 at 6:57 AM
    #390
    YotaGuy
    YotaGuy Well-Known Member
    Cody
    Phoenix, AZ
    08 DCSB 4x4 O/R & Yota crawler
    Stuff n junk
    I had the same setup with my 2011, 90k miles I got 18 stock. Between 14-16 afterwards, average of 15. Depending on miles id say to try this
    New spark plugs, new filter, clean maf sensor, change oil and oil filter, fuel filter, and run Lucas through a tank of the highest grade you can. Than next tank run your regular fuel, see if that helps
  11. Oct 13, 2015 at 7:27 AM
    #391
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    2006 Prerunner AC V6, 147k miles, well taken care of, all stock except for 265/75/16 BF Goodrich All Terrain TAs.
    87 Octane = 17.9
    89 Octane = 17.9
    91 Octane = 17.9
    I'm starting to see a trend here. Haha. Mostly highway driving. Some can be stop and go in my morning commute.
  12. Oct 13, 2015 at 12:48 PM
    #392
    Stroonzo
    Stroonzo Well-Known Member
    I've had my 2013 for about two months. 265 75s on stock 16" wheels. It is a V6 Prerunner TRD Double Cab. I've calculated gas mileage on every fill up. Without adjusting for the slightly taller tire, I have consistently achieved an avg of 19.5 MPG. So I guess you could call it 20 considering my tripometer registers slightly less than actual miles driven (right?).
  13. Oct 13, 2015 at 12:56 PM
    #393
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    V6 AC, 3" lift, 33" tires, steel wheels, 150 lb steel front bumper. 200 miles in town driving per week (40 mph average), 280 highway miles per week (70-72 mph average).
    16.5-17 mpg consistently. It is what it is.
  14. Oct 13, 2015 at 4:07 PM
    #394
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The trip odometer is showing ~4 miles less per 100 actual traveled with the 265/75-16 tires. So if you add gas at 250 miles on your trip odometer, add 10 miles (ie. enter 260 on your calculator) before you divide it by the gallons to fill.
  15. Oct 13, 2015 at 8:39 PM
    #395
    ThomasMore66
    Dallas/Fort Worth & Durango
    Again, does it matter? Do you enjoy the truck? Does it take you places?
  16. Oct 13, 2015 at 8:48 PM
    #396
    FtApache
    FtApache Well-Known Member
    2019 Raptor
    DCSB 4x4 Off Road with SEMA wheels and KO2 265/70/17...Last road trip was 17.79mpg highway speed 80mph from NM to NV.
  17. Oct 13, 2015 at 9:02 PM
    #397
    ThomasMore66
    At 80 I get about 14.
  18. Oct 14, 2015 at 2:10 AM
    #398
    devkurf
    devkurf Member at Large
    midwest
    I do about 15-16 in town, and 19-20 all highway.
  19. Oct 14, 2015 at 2:21 AM
    #399
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    15 dcsb 4x4 sport stock 1500 miles.. First tank got 21 probably from driving on the safe side. Since then all 18.5mpg at fill up driving 75-80 on the highway with 50/50 hwy/city driving. Hoping it will increase, my 02 same configuration got 20mpg driving the same route/speeds.
  20. Oct 14, 2015 at 6:03 AM
    #400
    David K
    With a few exceptions of you guys who claim to get over 18 in the city or over 22 highway, most of us 4x4 V-6 automatics are on the same page. I do hold the California gas blend responsible for at least a half mpg drop, if not more. My 1" taller than stock tires also drop the reading another 1/2 mpg, so it looks that much worse than it really is...
    13.5-14.5 city, 17.5-19.5 highway this past year. Add 1 mpg for the tires and if gas bought outside California!
    2010 Double Cab 4WD V-6 Automatic, 78,000 miles on odo.
