Toyota Tacoma "Real World" Gas Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maats, Jan 9, 2010.
  1. Jun 20, 2016 at 1:47 PM
    #481
    58LesPaul
    58LesPaul Well-Known Member
    Jeff
    Kentucky
    2013 Tacoma TRD Sport 4x4 DCSB
    2" Lift
    Just checked my mileage for the first time on my 2013 DCSB 4X4 with 3" lift. 19.49 mpg, I've made a few short trips but no interstate driving, mostly around town. I'm very happy with that!
  2. Dec 28, 2016 at 9:45 PM
    #482
    dck002
    dck002 Member
    2015 DCLB Mag Gray TRD Sport
    I'm getting confusing readings from my '15. On mixed highway/local driving I average high 18's to high 19's, aggressive driving doesn't change it too much. On strictly highway driving, I get the following:
    Hovering around 80MPH I get 15MPG
    75MPH I get 16MPG
    70MPH I get 17-18MPG
    I don't understand how I'm getting worse mileage on strictly highway driving than mixed. I've brought it up to the dealer tech's and they have no idea what could be causing it.
    I'm getting my MPG readings by clocking miles driven then dividing by gallons filled. I break some rules of this method by going to 2 different gas stations (costco and arco) but my MPG readings have been consistent over the 50k miles I've driven so far. I've taken 4 trips from norcal to socal, then back so I've been using each trip to test what MPG I get for each speed.
    What's even more confusing is when I hook up my OBD reader, at the higher speeds 70-80MPH I get inst MPG readings of 20-23 MPG. It's a cheap bluetooth OBD reader hooked up to torque on my phone.
    Does anyone have any clues as to what might be happening? My next step was to follow generic steps for bad mileage, clean MAF sensors, check cats/o2 sensors, discon battery, replace plugs.
  3. Dec 28, 2016 at 9:50 PM
    #483
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    With 230K -ish miles on my 06 I'm getting anywhere from 18-20 mpg. But I'm also doing mostly freeway driving back and forth to work lately.
    I'm sure the number will go down when I re-attach my bed rack and Tepui tent.
  4. Dec 28, 2016 at 9:56 PM
    #484
    dck002
    dck002 Member
    Have either of you guys found out more about this issue? I'm having a similar issue (see post above).
  5. Dec 29, 2016 at 7:28 AM
    #485
    bkrdave36
    Dave
    Wittmann,AZ
    I should have added I put the cruise control at 65 and coast on the freeway. When I get up to 70 75 it becomes a gas sucker and my mikeage goes to crap.
  6. Dec 29, 2016 at 7:31 AM
    #486
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    the Tacoma's happy place on the highway is 60-65, over that and fuel economy decreases
    Fight4Function and Mush Mouse like this.
  7. Dec 29, 2016 at 7:32 AM
    #487
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    I think what you are experiencing is aerodynamics at play. I get best gas mileage in rural stop and go situations where the speed limit is 45-50 and i stop every mile or so at an intersection. I run out towards the Oregon border when the speed limit is legally 80 and it drops...
    There is a multiplier effect with aerodynamics- for example the resistance at doing 40mph is not double going 80 mph. You may have double speed but you have tripled resistance.(Not actual numbers just illustrating the multiply/exponential effect of speed versus wind resistance) i put a relatively light 3600 pound trailer on and with a 8' wide frontal area and going highway speeds I can cut mpg in half from pulling the same trailer at 40 mph.
    Hopefully that makes since but I think that explains what you are seeing. According to my scan gauge anything over 65 and I am getting equal or worse than in town MPG.
  8. Dec 29, 2016 at 7:38 AM
    #488
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    I get pretty much exactly what they say I should be getting if not better. 16+ city, 20-21 highway.
    Unless I'm pulling the trailer. Those numbers are depressing. 14 hwy :(
  9. Dec 29, 2016 at 7:39 AM
    #489
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I started using COSTCO gas recently and noticed that my MPG went down 1 mpg and the second tank down 1.5 mpg the gas was about 10 cent a gallon cheaper than my normal stuff. since I have went back to the old brand im back to 22 mpg
  10. Dec 29, 2016 at 8:06 AM
    #490
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    15-16 city
    17-18 Highway ( 70-80mph on highway)
    I have a heavy foot and drive like a man that owns a truck and not a prius.
    Its a truck and gas is cheap !
    Mush Mouse likes this.
  11. Jan 1, 2017 at 9:56 AM
    #491
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    mine has done this since new so i'm not sure if anything can be done. can pull 21 around town but 18 on the highway at 70mph, drop it to 60mph and i can get 21.
    agreed
    thats not the point. never expected prius mileage, just what was on the window for highway mileage without getting run over at 60 mph, my roads are 70mph
    i probably baby my truck when im around town and not towing. more for longevity purpose though, being easier on trans and engine while im not working in hopes it will last me longer
  12. Jan 14, 2017 at 9:27 AM
    #492
    Fight4Function
    Fight4Function Slightly Mutant
    G
    SF Bay Area
    2014 DC TRD OR
    I did not know that. Thank you! You see?.. This is why I like this forum-- you learn stuff.
  13. Jan 14, 2017 at 12:22 PM
    #493
    RFT
    RFT Well-Known Member
    BC
    2020 AG Pro 6MT
    F/R Coastal high clearance, F:Elka 2.5 IFP & Rancho UCA, R:Dobinson & Fox 2.0 resi, LT255/85R16 ST Maxx
    Over the course of 40,000 km I averaged a little over 17 mpg on my 13 DCSB 4x4 MT.
  14. Jan 14, 2017 at 12:55 PM
    #494
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Driving 65 on highway. I'm around 21 in town 18-19.
  15. Jan 14, 2017 at 1:05 PM
    #495
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    16 mpg on a stock TRD sport 4x4 with only 16" SCS wheels and 265/75/16 cooper AT3. No matter what I can't break the 18mph mark lol. Fuck me right
  16. Jan 14, 2017 at 1:36 PM
    #496
    Chapman
    Chapman Well-Known Member
    Bay Area, CA
    2013 SW DCLB TRD Sport 4x4
    I just did 13ish mpg before my last fill up. I don't even have a lead foot. I'm thinking it's gonna get worse after I add my steel bumpers and bigger wheels. Sigh...
  17. Jan 14, 2017 at 3:23 PM
    #497
    terps2005
    terps2005 Well-Known Member
    Southern MD
    17 Super White DCLB Sport
    TRD Pro Grill w/white letters Inno roof rack Body Armor Hiline Bumper TRD Pro Skid plate Full meso interior chrome delete Bronze AGP T4R replica wheels Falken Wildpeak AT3W tires Homelink Mirror Pioneer DMH-WC6600NEX head unit with Maestro integration A shit ton of crumbs and dirt in the back from my 2 little monsters
    Tracked mine for 45,796 miles (over 16 months!) and I'm averaging 20.0 mpg. 2011 DCSB 4.0 Prerunner.
  18. Jun 8, 2017 at 11:55 PM
    #498
    Waited many moons
    Waited many moons Well-Known Member
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    I get like 14.5 miles to a gallon at best. I do enjoy my truck through.
  19. Jun 9, 2017 at 12:08 AM
    #499
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    It seems as thou the faster I go on the highway the more gas it sucks , I mean I know I'm using more gas to go faster lol . It also seems as thou I get better mpg around town then highway . I tried not goin above 70 for 1 tank , then above 65 for 1 tank , then at 60 and the slower I go the better the mpg gets but highway driving hurts my overall mpg . I would think it should increase it, if
    I turn the AC on I'm screwed lol
  20. Jun 9, 2017 at 12:20 AM
    #500
    igno1tus
    I'm seeing similar also , although I haven't gone 80 in my truck , it seems like highway kills my mpg where as you should get better mpg on the highways and worse around town
