Toyota Tacoma Reversible Crossbar (fits years 2005 and up)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by KB Voodoo, Aug 1, 2017.
  1. Aug 1, 2017 at 5:13 PM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    A very versatile crossbar....
    Provides a 3" rise, or a 2" drop if you flip them over.
    Stainless steel mounting brackets lock into your factory accessory rail with the provided hardware.
    A 14 gauge steel powder coated crossbar provides plenty of strength.
    (we suggest three crossbars for use with RTT's)
    Pricing
    $135 plus shipping for one bar
    $245 plus shipping for two bars
    Order Here
    Jeff108, Hawj123, cnote4l and 3 others like this.
  2. Aug 1, 2017 at 5:23 PM
    Muddinfun
    Muddinfun Well-Known Member
    Am I missing something here?
    Vasqu3zk and HandOfGod like this.
  3. Aug 1, 2017 at 5:24 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Typo....
    Muddinfun[QUOTED] likes this.
  4. Aug 1, 2017 at 9:45 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    The nylon washer (spacer) doesn't look like it matches the installed pic. One aluminum spacer to fit inside the rail and two knobs in the installed pic?
  5. Aug 1, 2017 at 9:46 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    One more thing, Can't see the knobs on the uninstalled pic. either.
  6. Aug 2, 2017 at 4:36 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You might be looking at it wrong. There's one knob and two nylon spacers at each end.
  7. Aug 2, 2017 at 4:36 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That's because it's hiding behind the stainless steel bracket. The T-Slot nut is attached to the knob.
  8. Oct 4, 2017 at 3:06 PM
    Philly Guy w 2012 tacoma
    Philly Guy w 2012 tacoma Well-Known Member
    Can you tell me S&H to 17601?
  9. Oct 4, 2017 at 3:35 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Looks like about $26 bucks.
  10. Oct 4, 2017 at 8:05 PM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    Can our accessory rail actually support an rtt? Typically i see the bars bracket resting on the bed side to distribute weight. If so, this would be ideal bc i have an access brand cover and it wont work with your tonneau brackets
  11. Oct 4, 2017 at 8:07 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    A small to medium size RTT, and we suggest three crossbars if the weight will solely be supported by the accessory rail.
  12. Oct 19, 2017 at 6:02 AM
    NorthCountryTRD
    NorthCountryTRD Well-Known Member
    Patrick
    New Hampshire
    2015 Tacoma TRD Off Road V6 Manual
    Current Mods: - Locking Lug Nuts - Weather Tech floor Liners - N-Fab light bar - 32” Led Light bar - TRD skid plate - Leer Cap (Pyrite Mica) - Rigid TSM-22 Tow Strap Shackle Mount - Rigid Orange Shackle - @ACEkraut License plate bracket - Flashwolves LED reverse bulbs - TRD Stainless Cat Back - AFE Pro Dry S drop in filter - Glove box organizer - Center Console organizer - Bed Stiffeners - Color match grille - Custom Car Grills Perf SS Mesh flat black - Thule Cap roof rails - TRD PRO Suspension - Wheelers 2" Add a Leaf - HS 1/4 inch strut spacers - SCS Ray 10's in Brushed Copper - Cooper Maxx St's 275's - Under hood Led Light Kit Future Mods (as of right now): - 20inch LED Bar (Caliraised,Rigid, Baja) - 32inch LED Bar (Caliraised,Rigid,Baja) - LED Pods Side Projecting (Caliraised, Rigid) - Toyota Bed Matt - Quick fist Axe and Shovel mounts in Truck Bed - Cap mounted Awning - 100% No Drill Bolt on sliders - Wet Oak Seat covers (All black with TRD in them) - VooDoo Bed Bars/Basket that works under a cap
    Good work man those flip brackets came out good !
    KB Voodoo[OP] likes this.
  13. Oct 19, 2017 at 10:01 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Hmmmm, 1 bar flipped down to fit under tonneau (when not in use) with my 15x100mm & 15x110mm fork mounts attached to it seems much nicer and secure than bolting them to a board. But the board could be used in other vehicles without bedrails and board on floor of bed = no handlebars over cab height. Pondering in progress......................& subbed
  14. Dec 11, 2017 at 9:12 AM
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    What do these look like flipped down?
  15. Dec 11, 2017 at 9:29 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    TacoTRD78 likes this.
  16. Oct 28, 2018 at 9:09 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    IN STOCK!!
    Order Here
