Toyota Tacoma / S&B Cold Air Intake
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Mr. Know-It-All, Jun 27, 2022.
  1. Jun 27, 2022 at 11:39 AM
    Mr. Know-It-All
    Mr. Know-It-All [OP] Well-Known Member
    2022 SR5 Trail Edition
    $175 this includes shipping to the lower 48 states.
    Selling like new S&B cold air intake for 2016-2022 Toyota Tacoma’s. Less than 3000 miles on this cold air intake I’m trading in my Tacoma and putting back the stock air intake. Everything shown is what you will get. I’ve packed it in the original box and it takes less than an hour to install in your Tacoma.
    Superior Cold Air Intake
    Improves Horsepower and Torque
    Enhances Throttle Response
    Dramatically Outflows Stock Intake
    Oiled 8-Layer Cotton Cleanable Filter
    High-Strength Construction
    Limited Million-Mile Warranty
    Fits All 2016-2022 3.5L Tacomas
    Improved Performance. Instead of settling for less, give your 2016-2022 3.5L Tacoma the impressive drive that will set your rig apart by investing in S&B's Cold Air Intake with Oiled Cleanable Cotton Filter. Featuring a design that outflows your stock intake by up to 43.83%, this intake manages to make serious improvements to your truck's horsepower, torque, and throttle response, so that you can stay at the front of the pack at all times.
    Ideal Filter. The cold air intake also comes complete with an oiled cleanable filter made from 8-layer cotton media for unbeatable power and ideal efficiency. With a massive stature and effective design, this filter banishes dust, dirt, and power-robbing particles from the engine, ensuring it remains perfectly intact and improving its function. Its oiled and cleanable build also means you can use it again and again.
    Strong Construction. Constructed from high-strength, hardcore materials, this intake offers long-lasting durability in the most difficult conditions. With heavy-duty construction and a fully-enclosed air box that keeps out dust and dirt while minimizing engine heat, this intake offers superior reliability as well as an impressive power upgrade, giving your truck the drive it needs to go the distance.
    Installation. Using basic mechanical skills, this intake and filter can be secured easily. Just set aside about 1 hour to complete the installation.
    Warranty. Boasting a limited million-mile warranty, this intake and filter are protected against defects in materials and craftsmanship. However, some limitations do apply, so check out the full warranty for details.
    Application. S&B's Cold Air Intake with Oiled Cleanable Cotton Filter is built to perfectly fit all 2016-2022 3.5L Tacomas.
    eurowner likes this.
  2. Jun 27, 2022 at 12:55 PM
    eurowner
    eurowner Duke Sky
    Scoty
    One of the best aftermarket CAI for our Tacomas!
  3. Jun 27, 2022 at 1:15 PM
    IssaGreenTaco
    IssaGreenTaco Well-Known Member
    Canton GA
    21 TRD Off-Road
    Dobinsons IMS Lift SPC UCA's
    hmm I have been looking at these and pondering
  4. Jun 27, 2022 at 4:36 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Just buy it already!
    I put an S&B intake on my old 1994 Chevy 6.5 Turbodiesel Suburban and was amazed with the results for a 7000lb station wagon!
  5. Jun 27, 2022 at 4:40 PM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    This is tempting for me also. How did you like it? I would have to buy the spiker engineering single hood strut then. I have their double now
  6. Jun 27, 2022 at 5:38 PM
    IssaGreenTaco
    Canton GA
    21 TRD Off-Road
    You can't use their double with this?
  7. Jun 27, 2022 at 6:52 PM
    WhiteTaco20
    Perkasie, PA
    No because the box will be in the way on the passenger side
  8. Jun 27, 2022 at 6:53 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Oiled filters are greeeeeat for the MAF. :rolleyes:
  9. Jun 27, 2022 at 7:02 PM
    Mr. Know-It-All
