Toyota Tacoma SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eddiecruz6, Sep 7, 2019.
  1. Sep 7, 2019 at 7:20 PM
    Eddiecruz6
    Eddiecruz6 [OP] New Member
    2019 Toyota Tacoma SR
    hey guys I just bought me turn signal bulbs off of Lasfit. I have a 2019 Toyota Tacoma Sr. The turn signal and DRL use the same bulb. When I had the stock bulb on both turn signal and DRL worked. Now that I installed the lasfit bulbs only the turn signals work and the DRL won’t turn on. Anyone know the problem?
    Taco_Coma and Hobbs like this.
  2. Sep 7, 2019 at 7:31 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum!
    Eddiecruz6[OP] likes this.
  3. Sep 7, 2019 at 7:33 PM
    Acabsurf
    Acabsurf Well-Known Member
    Alex
    San antonio, Tx
    2015 silver SR5 4x4
    Fabfour vengeance front bumper, XD series wheels. Leveling kit.
    Maybe wrong bulb? I just replaced my DRL this past weekend. Worked fine for me.
  4. Sep 7, 2019 at 9:07 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you still have the stock bulbs, try putting them back in. If things are back to normal there is something wrong with the new bulbs or they are the wrong bulbs.
    Tacomaroma likes this.
  5. Sep 8, 2019 at 12:57 AM
    gringotaco
    gringotaco Active Member
    2018 sr5
    Staying stock.. maybe
    Stock is a dual filament bulb, your replacement might not be.
    Chew likes this.
  6. Sep 8, 2019 at 2:30 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I tried to change my turn signal bulbs to led and encountered problems too. My drl worked but because it was led and doesnt use resistance like a halogen bulb, I needed to add a resistor to prevent hyper flashing. It was too much trouble so I gave up.
  7. Sep 8, 2019 at 7:50 PM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    You need a switch back bulb. VLED’s make a nice switch back bulb but it’s white DRL and amber turn.
