Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Apr 25, 2022 at 8:00 PM
    #2521
    kylek327
    kylek327 Active Member
    Kyle
    21 Army Green TRD Off Road
    That’s just a filler piece they use to go into the bracket where a camera would go if you had one. You are correct about the TSS stuff being below.
  2. Apr 25, 2022 at 8:27 PM
    #2522
    Cement-Taco127
    Cement-Taco127 Well-Known Member
    Charleston Illinois
    If that’s a filler piece I could replace that with a real camera then? Correct? I’ve been looking at a few of the upgrade “kits” and they all come with a front camera. Sounds like stupid questions but I’m still new.
  3. Apr 26, 2022 at 2:20 PM
    #2523
    CheddarBoB
    CheddarBoB New Member
    Jeremy
    2021 TRD
    None
    Has anyone did a 2” lift coil with just the shocks?
  4. Apr 27, 2022 at 8:16 AM
    #2524
    kashing
    kashing Well-Known Member
    David
    '22 MGM TRD OR
    I'm picking up a TRD OR in a couple weeks and have been looking into this kit. I've been reading through the posts, but haven't really found the answer. Will this raise the OR 2" in the front and 1" in the back, or less since it is already raised a bit.
  5. Apr 27, 2022 at 8:30 AM
    #2525
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    2" at top setting, 1.5" at mid setting, 1" at bottom for the front and yes, 1" in the back with the spacer provided. Some members have left out the spacer and gone with an AAL instead for 1.5" - 2" in the back.
  6. Apr 27, 2022 at 8:35 AM
    #2526
    Mirthaar
    Mirthaar 22'
    2022 Lunar Rock Tacoma TRD Off Road
    2"/1" factory lift
    Curious if any of you have upgraded your UCAs with the factory lift kit? I went down and talked to the guys at 4Wheel Parts last week and they didn’t recommend the UCAs unless you’ve got more than a 3” lift.
    Curious what the TW consensus is… if I can run stock UCAs for a while and save some money, that’d be sweet, but I don’t want to jack up the suspension if stock will cause trouble. I’m only doing very light off roading at the moment, mostly pavement driving.
  7. Apr 27, 2022 at 8:36 AM
    #2527
    Lorescar
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    It's doable but the consensus seems to be that you don't need UCA's with 2" or less of lift.
  8. Apr 29, 2022 at 8:03 PM
    #2528
    CPax
    CPax Well-Known Member
    love it. Just curious - why 265/70/17 instead of 275/70/17? About to upgrade to one of the two on some TRD 17 4Runner sema wheels. Seems like I see more folks rolling 265/70 and am just curious if there is a reason or if it’s just personal preference?
  9. Apr 29, 2022 at 8:18 PM
    #2529
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    275s are a heavy tire. And they rub on stock tacomas. So the most common size tire for fuel economy, weight, ply and fitment is probably 265
    TRD_Seeds likes this.
  10. May 1, 2022 at 12:32 PM
    #2530
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    Many folks here opt for the 265 or 285 before going 275. Weight being a big factor as well as selection. There just isn't a great selection of 275's and most of them are only available in an E load range, like the KO2's for example.
  11. May 2, 2022 at 10:17 AM
    #2531
    Vedauwoo Crawler
    Vedauwoo Crawler Well-Known Member
    Wyoming
    2022 TRD OR MT Lunar Rock DCSB
    How many of you are running 255/80/17s with this lift kit?
    These will be on a 0 offset rim.
    275/70/17 would be my other choice I'm looking at.
    Getting things together for my new Tacoma I have on order.
  12. May 2, 2022 at 7:35 PM
    #2532
    Samstitch
    Samstitch Member
    2022 TRD Offroad
    TRD OEM Lift, TRD Skid Plate, TRD SEMA wheels and 265/70-R17, Body Armor Hi Line Bumper, Smittybilt X2O Gen2 Wireless Winch, ProComp 20" light bar, Factor 55 Ultrahook; Currently looking for sliders
    Sorry for the late response; just back from Spring Turkey hunt.
    My 2019 first had 275's and then 285's. They just didn't work for me. I typically use my Taco for hunting in some pretty remote areas. (Why I don't drive Jeeps anymore; they just break down ALL THE TIME! I've been through 3, the most recent a 2017 Rubicon.)
    The wider tire limited some of the tight areas I needed to get too. My objective with this truck was to make it functional for what I do. If I want big I drive my V-10, F250 Super Duty w/ it's 4" lift, etc.... However, it's not fun when you get 10 mi/gal, regardless if I'm pulling a gooseneck trailer full of hay or driving down the road empty; FJB has our gas prices out the roof.
  13. May 11, 2022 at 7:28 AM
    #2533
    jjjjiiiimmmmmmmmyyyy
    jjjjiiiimmmmmmmmyyyy Member
    Jimmy
    Fort Collins, CO
    MGM TRD OR
    Has anyone tried to run a heavier duty coil on these struts?
  14. May 16, 2022 at 6:12 AM
    #2534
    Jimmy
    Fort Collins, CO
    MGM TRD OR
    Have you had any vibration issues?
  15. May 16, 2022 at 9:05 AM
    #2535
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    So far, so good.
  16. May 17, 2022 at 12:10 PM
    #2536
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Im late to the question. But those are rebranded 5100s for Toyota, just with less height adjustment . they will ride the same as 5100s because they are the same .
  17. May 17, 2022 at 12:55 PM
    #2537
    GoPDemon
    GoPDemon Member
    Did you have the rumble strip vibration also before? I am thinking of adding shims as I get a slow rumble strip vibration at like 40mph.
  18. May 18, 2022 at 8:43 AM
    #2538
    davered00ss
    davered00ss Well-Known Member
    I also have some vibration issues.
  19. May 18, 2022 at 10:28 AM
    #2539
    Jimmy
    Fort Collins, CO
    MGM TRD OR
    Have you tried anything to remedy it? Do you get it in 4 hi?
  20. May 18, 2022 at 10:39 AM
    #2540
    davered00ss
    I havent tried anything. I'm sure its the needle bearings. It does it in 2wd
