Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Sep 28, 2022 at 11:28 PM
    #2661
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Lift doesn't help, it's the wheel offset that causes rub. Lift has nothing to do with it!
  2. Sep 29, 2022 at 6:39 AM
    #2662
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Offset and wheel width right? How much modification will I need for 17x8.5 with -12 offset? I'm fine removing mudflaps and some mild trimming but want to avoid CMC. Otherwise i'd choose another wheel.
  3. Sep 29, 2022 at 7:04 AM
    #2663
    McGillz
    McGillz “It’s not accessorizing... It’s a BUILD!”
    New Jersey
    '19 TRD Sport Barcelona Red
    KMC Grenade wheels / BFG KO2 305/65/17 E rated, ECGS clamshell bushing, CMC, ARB Old Man Emu 2.5" lift- ARB 90000 OME Nitrocharger Sport Strut, ARB OME - 2886 Coil Springs (heavy), ARB OME Leaf Springs - EL111R (medium), SPC Specialty Products Upper Control Arms, Retrax One XR Tonneau Cover, Rhino Rack Vortex rails, Rago Fabrication Bed Stiffener, Tacomabeast- Spyder headlights /sequential LED DRL, Rigid driving/fog lightbar, RCI steel Skid Plate, Fab Fours Vengeance front bumper- High Pre Runner Guard, Fab Fours rear bumper, MillerCAT stainless Cat Shield, FEND-X wheel liners, Protec splash guards, Bushwhacker flares (Rhinoliner painted). For now…. Wife cut me off!!!
    I just had mine done for new 33's. UCA's, CMC and proper alignment was done to clear the new wheels.
    junkyarddogg and ancient11 like this.
  4. Oct 5, 2022 at 8:11 AM
    #2664
    junkyarddogg
    New Jersey
    2021 TRD Off Road
    Any reason why the dealer would refuse to install just the shocks? I want to hold off on the grill
  5. Oct 5, 2022 at 8:17 AM
    #2665
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Some shops flat-out will not install customer-supplied parts. Most shops will, you just have to ask them first (they'll probably tell you they cannot/will not warranty anything part-related, but their standard labor warranty would still apply). Shop-by-shop basis, you gotta ask them directly.
    junkyarddogg[QUOTED] likes this.
  6. Oct 5, 2022 at 6:33 PM
    #2666
    cxmoney
    cxmoney Well-Known Member
    2022 Wind Chill Sport
    Dumb question, but will I be able to fit 17x8.5 -12 wheels with this lift kit AND the factory mudflaps without destroying anything? I have the wind chill pearl paint and really want to keep the flaps to protect the paint if I can. If it is feasible, what size tire would be the best option
  7. Oct 5, 2022 at 10:48 PM
    #2667
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Word of warning: I had a 2019 Sport with the factory mudflaps and I was going to take them off to move over when I traded in for my 2020 OR a couple years later. When I took them off they had already started very noticeably wearing down the paint where they rub against the painted fender flares that the Sports have.
  8. Oct 6, 2022 at 4:32 AM
    #2668
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Yep. And -12 offset will still kick some stuff up past the flap. Gotta pick paint or aggressive offset or pay $$$ to ppf
  9. Oct 6, 2022 at 6:50 AM
    #2669
    deusxanime
    MN
    Or you can get some aftermarket ones. I ended up just leaving the factory ones on my 2019 when I traded it in and bought RokBlokz ones instead for my new 2020. They mount up to the factory holes (but don't wrap around the fender flares like the OEM ones do and rub again the paint) and you can kind of adjust them out a bit if you have some offset. If you have a lot of offset, they also sell XL versions which stick out even more I think.
  10. Oct 6, 2022 at 7:47 AM
    #2670
    cxmoney
    well damn. Wish I knew this beforehand . I purchased these flaps before I got the truck and installed them once it came in. Looks like I’ll never remove them now as I don’t want to see what is underneath
  11. Oct 6, 2022 at 7:48 AM
    #2671
    cxmoney
    hmmm this isn’t a bad idea. I may have to end up doing this. I’ll need to see if any damage has been done first though from the factory flaps.
    deusxanime[QUOTED] likes this.
  12. Oct 6, 2022 at 9:45 AM
    #2672
    deusxanime
    MN
    It's just a few screws/bolts to take them off and put them back on. Take a look at one or two and if it is too late, just put them back on - super easy.
  13. Oct 6, 2022 at 11:01 AM
    #2673
    TacoBuffet
    AL
    true but I’m not a fan of the look
  14. Oct 6, 2022 at 6:38 PM
    #2674
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    Finally getting the shocks in December (Birthday Gift) in talks with a dealer to get a price on labor/ecgs/alignment. I am going to set the front on the first clip at 1 inch and leave the rear stock other than the shocks. Excited but have to wait lol. Not looking for a huge lift just to level the front.
  15. Oct 7, 2022 at 12:12 AM
    #2675
    kevincaves
    kevincaves New Member
    Kevin
    Phoenix, AZ
    Are those 275 70 17 Falken Wildpeaks on your lunar?
  16. Oct 7, 2022 at 1:37 PM
    #2676
    norvegicus
    norvegicus Member
    12 SR5 2.7 ACLB 4x4
    Just got off the phone with my dealer. I have a '23 TRD Sport DCLB on order. He says the TRD lift kit isn't available for this model, confirmed with the regional service people. Oh well, I guess I'll go aftermarket. Meh.
  17. Oct 7, 2022 at 2:14 PM
    #2677
    VaToy
    Parts Unknown
    Go Bilstein 5100, cheaper, lifetime warranty, more settings, been used by several with no issues. I use them and going on 20k miles on my truck, never had an issue and I also have the TSS on my truck with the Pro grill.
  18. Oct 7, 2022 at 2:20 PM
    #2678
    cxmoney
    yep looks like I’m screwed. Guess I’ll kiss those SCS wheels goodbye and join the basic 4Runner TRD 17” wheel train since those are the only things that won’t destroy the flaps. Haha. Guess it saves me money in the long run since I won’t have to pay for a lift either. Win some lose some I guess
  19. Oct 9, 2022 at 10:10 PM
    #2679
    KevKev_22
    KevKev_22 Well-Known Member
    2021 Tacoma TRD Sport
    What size are your wheels/tires?
    RCrumb likes this.
  20. Oct 9, 2022 at 10:27 PM
    #2680
    KevKev_22
    I had a similar noise that drove me crazy. I don’t have the lift kit. But found out that it was the chassis bushing had a tear in it. Hopefully you get it taken care of. Things like that can drive you crazy.
