Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Jun 7, 2023 at 1:18 PM
    #3001
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    Get the alignment done then add the wheels/tires. Changing those out shouldn’t affect your alignment
  2. Jun 7, 2023 at 2:05 PM
    #3002
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    Welcome to TW. Search YT for Bilstein 5100 (same as the TRD lift). You don't need a spring compressor either (use weight of vehicle to compress spring). ;)
    Driving for a week or two will be fine before alignment... some folks prefer this to allow everything to "settle in". Nothing wrong with getting aligned before wheels and tires but it would require another trip to tire store.
    I installed my 5100's and 3aal and then got the alignment a week or two later.
  3. Jun 7, 2023 at 2:10 PM
    #3003
    Talkoma
    Talkoma Active Member
    Cement 21' TRD OR
    Interesting, I'll definitely have to look into that (assumed I would need one). Thanks!
  4. Jun 7, 2023 at 2:57 PM
    #3004
    rybern
    N Alabama
    I've read about guys that mentioned not needing it before and I thought they were morons LOL. I have spring compressor kit that I used on my 1st generation and other vehicles. Well I didn't use it when I did 5100's on my '23..... it felt like I was cheating. :)
    TRDRed and Talkoma[QUOTED] like this.
  5. Jun 8, 2023 at 4:37 AM
    #3005
    rybern
    N Alabama
    Here's a link to my truck thread where I specifically list which bolts I removed. I had forgotten that the (3) tophat nuts get to stay in place when using the truck weight to remove and compress the coils.
    https://www.tacomaworld.com/threads/2023-mgm-trd-off-road-mildly-modded.787908/page-3#post-28328880
    Here is one of many vids that show the "easy" method for installing 5100's/TRD coils. I highly recommend watching several vids.
    https://www.youtube.com/watch?v=a9N1fvbGAEw
  6. Jun 8, 2023 at 8:57 AM
    #3006
    Talkoma
    Cement 21' TRD OR
    I've got three videos (including your link) under my belt now. Looks very doable and honestly safer than the cheap Amazon spring compressors I was looking at.
    I've got all the tools needed, just need a free afternoon...
    Appreciate you steering me onto this technique!
  7. Jun 8, 2023 at 4:55 PM
    #3007
    rybern
    N Alabama
    Glad to help. How many miles are on your truck and do you intend to do the full 2" lift? Are you familiar with the ECGS bushing?
    Once again, welcomw. Lots of great folks on here. Be prepared to endure some bickering and thread drifts. And realize that some folks will spend lots of amount of money on thier trucks..... doesn't mean you should. :p
  8. Jun 8, 2023 at 5:31 PM
    #3008
    Talkoma
    Cement 21' TRD OR
    Thanks! It's sitting at just over 17k last I checked, and yes, was aiming for the full 2 inches.
    I have seen mention of that ECGS bushing on some posts before, something to do with vibrations post lift? People with factory lifts running into issues as well?
    Anyway, I'll try to take your last bit of advice to heart, but I've been known to readily spend on new hobbies in the past... (I also have a penchant for choosing ridiculously expensive hobbies)! :rofl:
    rybern[QUOTED] likes this.
  9. Jun 8, 2023 at 6:32 PM
    #3009
    rybern
    N Alabama
    Some folks get by without issue. But I did the ECGS bushing on my 2023 with only 529 miles on it because I wanted to get it done while I was doing the 5100's(with mild lift to 1.55"). It made sense to me to do it all at once. Just be aware if you dont do it that you may experience vibration down the road which is a warning of needle bearing failure. The issue seems to be hit and miss.
    It's easy to get caught up with the truck that someone else is building to suit thier wants/needs. I have found it difficult to stay focused on my wants/needs because someone else's truck is so cool. This has caused me to take breaks from TW and limit myself from build threads.... which has helped immensely..... YMMV. Good luck brother. Sounds like you already have issues... like me LOL.
    Talkoma[QUOTED] likes this.
  10. Jun 9, 2023 at 6:39 AM
    #3010
    Lucky132014
    Lucky132014 New Member
    I just purchase a TRD OE lift kit. My truck is a 2022 off road extended cab. I would only like to lift the front 1". What notch would I set it on the middle or bottom?
  11. Jun 9, 2023 at 6:45 AM
    #3011
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Bottom, I believe those struts only have options for 1", 1.5", and 2".
  12. Jun 9, 2023 at 6:52 AM
    #3012
    Lucky132014
    Yes only 3 notches. Thank you.
  13. Jun 9, 2023 at 6:54 AM
    #3013
    BLtheP
    Plano, TX
    You're welcome. Are you lifting the truck 1" all around? This is exactly what I wanted to do (haven't done anything yet, stock TRD OR). Couldn't find anyone else who has done so, everybody seems to go 1.5" so definitely curious to see how yours goes at 1". I like the factory rake, and would prefer the truck to just go up 1" all around.
    TRDRed likes this.
  14. Jun 9, 2023 at 7:07 AM
    #3014
    Lucky132014
    I purchased a half inch rear block from Toyota that's used on the Trail Edition instead of using the 1 inch the kit came with. That should help keep the rear with a little rake.
  15. Jun 9, 2023 at 7:09 AM
    #3015
    rumbum
    rumbum Member
    Del Boca Vista, FL
    Lunar Rock 2023 TRD Off-Road
    OTT tune, TRD lift & Icon RXT rear springs, Metal Tech Sliders, Icon Rebound SLX's, 285/70/17 BFG AT's, Softopper, Mountain Hatch tailgate cover and a laundry list of other things.
    If I install the Toyota lift kit myself, and the needle bearing goes, is it covered under warranty? This is on a 2023. I'm guessing the answer is "it depends on the dealer". But wondering if anyone had firsthand experience.
  16. Jun 9, 2023 at 10:57 AM
    #3016
    raptorman7
    raptorman7 Member
    Needle bearing failure is on you if you install the kit yourself. Regardless, Toyota would just keep replacing the same needle bearing leading to another future failure until the warranty runs out. Just install ECGS bushing and save yourself the hassle. I installed the TRD lift myself and the needle bearing failed within a couple of days forcing the ECGS bushing install. I should have done the bushing during the initial install of the lift.
    rumbum[QUOTED] likes this.
  17. Jun 12, 2023 at 1:43 PM
    #3017
    KYTACO23
    KYTACO23 Member
    K
    Western Kentucky
    2023 Tacoma TRD Sport Dbl Cab
    None yet. Hoping to add TRD lift kit and 275-70/R17 Wildpeak AT3W.
    I have hit the high points of this thread, but don't have time to read/search through all 150 pages. I am going to do the TRD front and rear shocks. I see so many mixed answers on what the 3 notch measurements are for the TRD Bilstein vs the Bilstein 5100's having 5 positions. Does anyone have an actual .PDF image they could share of the factory TRD installation directions to show the clip setting differences. I'm wanting to do the front at 2 inch and use the Icon progressive AAL 1.5" in the rear to maintain a bit of the factory "rake". Any help would be appreciated. Thanks
  18. Jun 12, 2023 at 2:40 PM
    #3018
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    Factory install guide doesn't list the circlip setting heights for whatever reason. Full guide below if you're interested.
    http://toyotaparts.sparkstoyota.com/install/PT84K-35221binst.pdf
    It's 1", 1.5" and 2" for the settings on the TRD's (maybe 1.1" and 1.55" for the lower 2 if Toyota decided to just take a 5100 and remove the bottom two settings. Not sure, close enough). If 2" is your goal you'll use the top setting regardless.
  19. Jun 12, 2023 at 7:51 PM
    #3019
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    An inch in the rear is more leveled looking with an ever so slight rake.
  20. Jun 12, 2023 at 8:30 PM
    #3020
    KYTACO23
    KYTACO23 Member
    K
    Western Kentucky
    I appreciate it! Yeah that is weird that they wouldn’t tell the clip setting in the factory install instructions! I’ may just end up doing regular 5100’s and read 1.5” AAl. Probably go ahead and do the ECGS bushing while I’m at it.
    TRD_Seeds[QUOTED] likes this.
