Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Sep 11, 2024 at 7:59 PM
    #3201
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    10.5 hours to replace the rear shocks, add a 1" block, replace the front struts and swap grilles?
    I could see that if UCAs were in the mix but that seems awfully long for the components in the kit?
    MGMDesertTaco likes this.
  2. Sep 11, 2024 at 8:08 PM
    #3202
    MGMDesertTaco
    If you have any mechanical skill set or have friends who do, buy some tools, drinks and food. Give it a whirl.
    edit: You can also rent tools.
  3. Oct 11, 2024 at 12:27 AM
    #3203
    joonoh
    joonoh New Member
    I read that the 3rd circlip groove that's not mentioned on the trd lift kit is for a 1 inch lift. Is this true? I was thinking about just doing a 1 inch leveling without having to adding anything to the rear but still using the trd shocks.
  4. Oct 11, 2024 at 10:59 AM
    #3204
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    Correct, this is what I'm on currently.
    joonoh[QUOTED] likes this.
  5. Oct 11, 2024 at 2:52 PM
    #3205
    joonoh
    joonoh New Member
    I wouldnt run into any issues using the trd shocks for the rear without the inch block right?
  6. Oct 12, 2024 at 7:45 AM
    #3206
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    Anyone on here have a specific AAL they used in conjunction with the TRD lift that works well? I find that the 1" block in the back creates for a pretty rough ride both on and off road with an empty bed. Washboard roads cause me to think the windshield is going to spontaneously explode!
    majpooper likes this.
  7. Oct 12, 2024 at 9:04 AM
    #3207
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Just my opinion which is basically worthless I guess. But first the OEM TRD lift kit is a rip off (~$1500) - again just my opinion. I say this because for the same $$$ you can get something (lots of choices) much better. Second, getting a lift with blocks is a bad choice because of axle wrap I am definitely of the opinion (and we all know what my opinions are worth) of NO BLOCKS.
    OK so what would Mr. Worthless opinion recommend? Just get some Bilstein 5100s front and rear ($~450) and ICON AAL ~($250) - you can do that yourself in the driveway but even if a shop does it for you probably less than the Toyota dealer and a better set up. But I would go just a tad farther and will cost a bit more but way worth it - skip the AAL and replace the leaf pack with Deaver or RXT (~$700) because the stock leaf packs are garbage. And again in my opinion (yep - I know) I would go with the 5100 in front but get my lift with some coilovers (front springs) (~$850)
    So do the math (if I got it right, better check me)
    TRD lift kit is what about $1500
    My basic recommendation is about $700
    But if you were going to spend $1500 anyway then go all the way with the 5100s with coil overs and a new leaf pack for $1550
  8. Oct 12, 2024 at 9:16 AM
    #3208
    Bishop84
    Bishop84 Well-Known Member
    AAL will roughen the ride even more, 1" blocks basically do nothing to the suspension.
    The best you can do is add weight to the rear or reduce tire pressures.
    If you do go AAL go Icon progressive.
  9. Oct 12, 2024 at 11:22 AM
    #3209
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I right way noticed an improvement in ride, not at all worse. Bumps are better absorbed, including washboard roads.
  10. Oct 12, 2024 at 12:37 PM
    #3210
    Lorescar
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    I haven’t. Been running it with my current setup (1” front, 0 back) for about 50k miles.
  11. Oct 12, 2024 at 12:42 PM
    #3211
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Thanks for a helpful opinion besides getting all new suspension lol so the roughness in the rear is not due to the block included in the kit?
    BC Hunter likes this.
  12. Oct 12, 2024 at 2:40 PM
    #3212
    007YO
    007YO Member
    ne ohio
    2020 offroad
    as previously stated adding blocks has nothing to do with ride quality , if u think its harsh now wait till u add a ad a leaf . its either tire pressure or the new shocks or both
  13. Oct 12, 2024 at 6:23 PM
    #3213
    eduardofuria
    eduardofuria Well-Known Member
    Eduardo
    That was a great deal, the dealership charged me 1700 for the Toyota tacoma lift kit
  14. Oct 13, 2024 at 3:39 AM
    #3214
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Nothing wrong with a 1 inch rear block. Didn't effect my ride when I installed 5100s 6 years ago. No issues!
  15. Oct 13, 2024 at 3:46 AM
    #3215
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    The TRD shocks can be bought separately, without the whole kit, if you want to use Toyota/TRD stuff without buying all the extra crap the kit comes with (what I did).
    I then threw the Icon 3 leaf add a leaf on mine and like the result (gave about 1” of rear lift).
    deusxanime likes this.
  16. Oct 14, 2024 at 9:52 AM
    #3216
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Had it done December of 22 @ 4500 miles. I'm creeping up on 15k miles now.
  17. Oct 14, 2024 at 4:45 PM
    #3217
    NewWheeler
    NewWheeler Well-Known Member
    Gus
    Fort Worth, TX
    2017 Quicksand DCSB TRDOR 6MT
    This is what I did too. I waited until all the Black Friday sales were going on and I think that I was all in for under $600. I think that it was a big improvement over the stock TRDOR ride and handling.
    My only complaint was that I only got about 3/4” lift out of the “1.5 inch” Icon AAL and had to go back and add 1/2” blocks in the back.
    SnuggleTruck[QUOTED] likes this.
  18. Oct 15, 2024 at 3:22 AM
    #3218
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    I’m also not sure why they call it a 1.5” lift. Both myself and my neighbor put it on and both only got about an inch. Maybe it’s 1.5” if you leave the overload spring in, but the directions say to remove it and I’m sure the ride would be awful if you left it in.
    Ive also considered adding a 1/2 block in the rear at some point, although if I redo the suspension again I’d likely just do a full pack in the rear and adjustable Icon/Eibach in the front to get 2.5” front and 2” rear.
    NewWheeler[QUOTED] likes this.
  19. Oct 15, 2024 at 10:32 AM
    #3219
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Okay.... now I feel like the universe is talking to me with this video dropping just 3 days after I asked the same question... this guy didn't have the TRD lift, but had a block in the back similar to ours. He has the same complaint about the rear being too rough and found that it was due to the block. He replaced the leaf springs completely and added Super Springs bump stops to alleviate the issue...
    https://www.youtube.com/watch?v=_jhrJQLyJwo&t=1516s
    Canadian Caber likes this.
  20. Oct 16, 2024 at 7:16 AM
    #3220
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    I guess I should clarify that I hope to not change out the entire leaf pack, but hoping that someone has done something similar before with one of the AAL. I think the addition of the aftermarket bump stops on the front and back would be optimal as well.
