Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Oct 16, 2024 at 7:44 AM
    #3221
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    What height are you trying to get? What do you plan on doing? and what kind of ride?
  2. Oct 16, 2024 at 7:46 AM
    #3222
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    I enjoy the level look that the TRD Lift kit gives me. If there's something that gives the 1" lift in the rear once the block is removed, that would be great!
    Lorescar[QUOTED] likes this.
  3. Oct 16, 2024 at 7:49 AM
    #3223
    Lorescar
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    Unfortunately, outside of a custom pack, no. you could get close (within 1/2") with any aal and the overload removed, General Spring KC HD has a complete replacement pack that lifts about 1.5 after settling. But those are the only options off the top of my head.
  4. Oct 16, 2024 at 10:14 AM
    #3224
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Appreciate your help! I could potentially live with 1.5" if it takes away the rough riding conditions... I'll be starting my research with those recommendations!
  5. Jan 31, 2025 at 11:07 AM
    #3225
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Just ordered this kit today...except the Bolt Flange W Washer.
    SnuggleTruck, raptorman7 and Tacobelt like this.
  6. Feb 16, 2025 at 4:48 PM
    #3226
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Does anyone know the compressed and extended lengths of the rear shocks? Would love to be able to properly compare these to other options.
  7. Feb 26, 2025 at 10:54 PM
    #3227
    Mach
    Looking at the pictures here it seems the shocks are the exact same length as 5100s. With the 1in block that means you would be losing 1in of down travel by installing this lift. Why wouldn't they have based it on the 5125 shocks that are 1in longer and wouldn't lose the droop?
  8. Feb 27, 2025 at 12:23 PM
    #3228
    Taco dv
    Taco dv Well-Known Member
    2020 Tacoma TRD off-road
    The 5100’s are 1” longer.
  9. Feb 27, 2025 at 12:39 PM
    #3229
    Mach
    Longer than what? 5100 rear shocks are the same length as the stock 3rd gen TRD off-road shocks. The leafs can droop about 5/8in beyond their length. If you add a 1in lift block with the 5100s you lose 1in of travel vs without the block as they are using up an inch of extension when the axle is in the fully up position. The right model of 5125 shocks is 1in longer compressed and adds roughly that extra 5/8in of extra travel needed to use the full range of the leaf springs.
    I just wonder if it was a lazy choice or if they were trying to protect from brake line overextension or leaf spring longevity?
  10. Feb 27, 2025 at 2:01 PM
    #3230
    Taco dv
    I’m no expert, but I thought the 5100”s are spec”d for up to 1” of lift? And 5125 from 2-3.5” lift. If the TRD kit uses a 1” rear block, then the 5100 would match.
  11. Feb 27, 2025 at 2:19 PM
    #3231
    Mach
    My understanding is that those specs are kind of hogwash because there are lots of different ways to lift.
    From a technical standpoint you aren't likely to cause damage to any shock that has a compressed length of less than the compressed length of your shock mounts so they aren't wrong saying a shock works with a certain lift height but that doesn't mean it is optimal. A 1in lift block moves your lower shock mount down an inch so your suspensions compressed and extended lengths both go up by an inch. Your max extended length is limited by the shock so if using stock length shocks it is still the same but your max compressed length has gone up by an inch so you have an inch less of overall travel. So unless I am missing something a TRD lift kit lift would have 1in less suspension travel in the rear than a stock TRD off-road.
    5125 shocks aren't specd for any particular lift height as they arent marketed to any particular vehicle but are listed as universal shocks for custom applications. There are extended length 5100 series shocks specd for more lift but their compressed length is too short for use with a 1in lift block unless you add a bigger bump stop and give up up travel.
    It just seems weird to me that Toyota had their bilsteins for the lift kit be based on the 5100s and not the 5125s. They already include a bracket to reposition the e-brake cable but maybe they were afraid of wear and tear on the break lines without extension or repositioning and didn't want to get into that? Or maybe they were just copying the 5100 lifts others were offering and figured it didn't matter for a mall crawler......
    -Jess
  12. Feb 27, 2025 at 2:23 PM
    #3232
    Taco dv
    I’ve seen 2 good videos of the TRD kit off-road. One with stock tires, one with 1” taller tires (32”s). They both performed very well, and had plenty of flex. More than enough for the typical weekend warrior. The serious off-road enthusiasts would look at other kit options.
    https://youtu.be/5Pf6iLk5CSI?si=Ho77j8EIPCew-9NN
  13. Feb 27, 2025 at 2:30 PM
    #3233
    Taco dv
    I will be installing the TRD lift kit this weekend. I have the stock off-road shocks, a 5100, and the TRD lift kit shocks. I can measure and compare all 3 and report back.
    deusxanime and TacoTime55 like this.
  14. Feb 27, 2025 at 2:31 PM
    #3234
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I'm interested in this report.
    Thanks!
    Taco dv[QUOTED] likes this.
  15. Feb 27, 2025 at 2:32 PM
    #3235
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    After watching a bunch of portal axle videos, I’m revisiting the OEM lift kit. Again :) The money for the portals is outa sight. Then add wheels and tires, installation. I know it’s comparing apples to oranges but with a slight tire size increase (265/70/16 to 265/75/16) it’s all I want ATT.
    Taco dv likes this.
  16. Feb 27, 2025 at 2:34 PM
    #3236
    Mach
    The block gives you 1in less down travel than you had without it and the stock shocks. With an empty bed you are going to bo a lot closer to full extension and I could definitely see it topping out a lot more and being very rough. Longer shocks with the lift block would fix that problem.
  17. Feb 27, 2025 at 2:43 PM
    #3237
    Taco dv
    Aren’t the 5100’s 1” longer than stock shocks?
  18. Feb 27, 2025 at 2:46 PM
    #3238
    Taco dv
    Thats exactly what I have. 265/75/16 on stock off-road wheels. 2” lift . Looks perfect and performs good enough for me. I had 33’s and really liked them, but just not worth all the headaches associated with them.
    Cement_wheels[QUOTED] and RCrumb like this.
  19. Feb 27, 2025 at 2:53 PM
    #3239
    Mach
    It may depend on which stock shocks. In the rear I know they are the exact same extended length as the TRD Off-Road shocks but they may be longer than the base model shocks. I don't know how long those are.
    In the front I believe the 5100s are longer than the trd off-road front shocks but not certain.
  20. Mar 1, 2025 at 7:28 PM
    #3240
    Taco dv
    Ok, here’s the 3 rear shocks compared to each other. The 5100 and the stock TRD off-road shocks are the same length. To my surprise the TRD shocks are 3/4” -1” longer than both the others.
    Tocamo and RCrumb like this.
