Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Feb 21, 2021 at 7:29 AM
    #321
    TacoTaco-BurittoTaco
    TacoTaco-BurittoTaco Well-Known Member
    James
    Georgia
    2023 TRD Off-Road DCSB
    Stock
    The more and more I read about this it makes me think that something is going on here. I can understand manufacturers pricing for factory items and such. But I personally would like to get some real info to find out if aftermarket grille and accessories are all that much different and Toyota is just making stuff up to get people to pay more. Especially when it comes to this grille, garnish and mounting brackets.
  2. Feb 21, 2021 at 7:33 AM
    #322
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    The earlier question about the Pro Grille might shed some light. Is it subtly different and lowers the sensor mount?
  3. Feb 21, 2021 at 7:35 AM
    #323
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    The pro grill does lower the sensor an inch or 2, it's in the bottom of the grill as opposed to right in the center. I lifted my truck 2.5" and installed the pro grill knock off and I think my sensor is in about the same position. No recalibration by the way, still works fine.
  4. Feb 21, 2021 at 7:37 AM
    #324
    RushT
    North Texas
    Wasn’t fast enough to edit. Is the ‘new’ pro grille for this setup subtly different from the original OEM pro grille. I too swapped in a pro grille a few years back and the 2” drop hasn’t caused me any issue.
    DLRIII[QUOTED] likes this.
  5. Feb 21, 2021 at 7:58 AM
    #325
    James
    Georgia
    Stock
    I would like to know this as well. The issue I have regardless of the OEM camera is the difference in heights and if it "really matters" in the calibration and to what degree.
    Example:
    2020 Tacoma OR,
    Stock OR Tacoma, OR grille, no lift. Standard height for sensor for this vehicle.
    Stock OR Tacoma, changes to Pro grille. Certain height of new sensor.
    Stock OR Tacoma, factory lift installed w/Pro grille. Different height.
    Stock OR Tacoma, aftermarket lift, OR grille. Different height depending on lift height.
    Am I overthinking this? I am trying to understand why a "new" sensor would ever be needed to be added to the parts list for something that is usually calibrated for any and all lift/lower height differences. Maybe I'm wrong here but this doesn't seem to make any sense to me.
  6. Feb 21, 2021 at 8:26 AM
    #326
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    that’s why you need have taco friends, i got 5100 (8k mile) with stock spring for 150bucks since the taco friend upgraded to king’s. It probably take me 5,6 hours to install the shocks and rear block. If the shocks ever got damage I can just put the stock shocks back on.
    This still better than the spacer lift.
    71tattooguy likes this.
  7. Feb 21, 2021 at 8:32 AM
    #327
    tedusmc1345
    ted
    The lift will not effect the mpg, the tire will impact the mpg.
    Shades_Of_Red and 71tattooguy like this.
  8. Feb 21, 2021 at 8:36 AM
    #328
    DLRIII
    David
    Baton Rouge
    Me either. Seems unnecessary. The sensor must have a range of acceptable angles because I've rarely seen anyone have any issues when changing grills, lifting, etc..
    tedusmc1345 likes this.
  9. Feb 21, 2021 at 8:39 AM
    #329
    2020_TRD_OR
    2020_TRD_OR Well-Known Member
    Pennsylvania
    2020 Cement Tacoma TRD Off Road
    Bilstein 6100s & 5160s Wheeler's Super Bump Stops Wheeler's AAL SPC UCAs Sway Bar Relocation Kit RCI Front Skid Plate
    Grill Garnish: https://parts.toyota.com/p/Toyota_2...5-GLX/Grille-Molding/71694366/5314135060.html
    Part Drawing 1 for Pro Grill: https://parts.toyota.com/images/parts/toyotaOEM/fullsize/a1_535326B.jpg
    Part Drawing 2 for Pro Grill: https://parts.toyota.com/images/parts/toyotaOEM/fullsize/a1_535162C.jpg
    Part Drawing 3 for Pro Grill: https://parts.toyota.com/images/parts/toyotaOEM/fullsize/a1_536146.jpg
    Drawings one and two do not call out the part number for the Grill insert and drawing three has a note that N04 (the reference for the insert) is not available for service. (Whatever that means)
    There is nuance with the grill inserts and I can think of 4 possible Grill configurations.
    1. Pre TSS Pro Grill - with camera hole - comes with "dummy" garnish that goes in the TSS Garnish Spot - I've got this part in hand so I know it exists. When they ordered the grill part - the dummy garnish came inserted into the grill.
    2. Pre TSS Pro Grill - w/o camera hole - comes with "dummy" garnish that goes in the TSS Garnish Spot
    3. Post TSS Pro Grill - with camera hole - comes with legit garnish
    4. Post TSS Pro Grill - w/o camera hole - comes with legit garnish
    Thinking about that there are ultimately two grills (N04 from picture 3) - with and without the camera hole.
    Specifically, my question is if there is a third grill piece now. I'm almost certain there isn't - and the bits about the grill are just a money grab backed by "legal/safety" concerns. I don't know the exact number in inches but the suspension lifts the truck 1" in the front. If they did not replace the grill, they should easily be able to re-calibrate the TSS. If their engineers have proof that the one inch makes it impossible to calibrate the TSS - then prove it - spoiler alert, they can't. (I called my local dealership explaining that I have 33" tires on my truck now (so it sits higher) and I'd like the TSS recalibrated - they said no problem).
    The TSS position on a stock TRD OR grill is in the center of the grill. The TSS position on the pro grill is lower by a couple inches. So when they replace it - the position of the sensor is still not "exactly" where it was pre-lift.
    It all smells too fishy to me to justify doing. I would only consider this if buying new - fuck doing this after purchase.
    TacoTaco-BurittoTaco likes this.
  10. Feb 21, 2021 at 8:46 AM
    #330
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The lift will most likely affect MPG's. By removing the vehicles rake, more air will travel under the truck, and there are a lot of obstacles to create drag down there.
  11. Feb 21, 2021 at 8:55 AM
    #331
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    Still haven't seen why this kit is not listed for use with earlier 3rd generation. Except for having extra unnecessary parts i don't know a valid reason. Anyone know a reason?
    schmack b likes this.
  12. Feb 21, 2021 at 8:58 AM
    #332
    tedusmc1345
    ted
    I being tracking my mod vs mpg for while.
    When I star tracing have wildpeak 265/70/17 with bed cover I will get about 21mpg.
    I have installed pro intake and pro exhaust it decrease my mpg by 1.
    And I have 2:1 lift for couple weeks now, I do not seen any effect about my mpg change.
    And I had Hooke roof rack for little bit, it decreased my mpg by 1.5 to 2 with too much wind noise for me when I’m doing above 60mph.
    Next mod I will install DV8 skid plate(about 80lb) we seen how it goes.
  13. Feb 21, 2021 at 8:59 AM
    #333
    2020_TRD_OR
    Pennsylvania
    They have an excess of those fucking $417 TSS grill garnishes and can't sell them. So they are limiting sales to the 2020 until they can reduce inventory. Then once they get that handled they will magically "listen to their customers" and open up sales to non TSS years/models
  14. Feb 21, 2021 at 9:02 AM
    #334
    mainjet
    mainjet Well-Known Member
    Alberta
    2019 Tacoma off road
    Ray 10s Diode dynamics Hidden Light bar Toyo AT2s
    The eBay Toyota dealer says it will and I can’t think of a valid reason why it wouldn’t
    Make/Model: 2018-2021 Toyota Tacoma (V6 4WD ACCESS CAB LONG BED OR DOUBLE CAB(4FULL DOORS) WITH SHORT BED ONLY)
    Fits Vehicle Codes Listed:7540,7542,7543,7544,7545,7552,7558,7559,7560,7562,7582,7593,7594, 7320, 7321, 7325, 7326, 7328, 7330, 7331, 7332
    SPECIFICATIONS: THIS KIT WILL NOT FIT Vehicles THAT ARE TRD PRO, 4 cyl, and/or 2WD, Or Double Cab Long Bed
    tedusmc1345 and rubiconjp like this.
  15. Feb 21, 2021 at 9:05 AM
    #335
    tedusmc1345
    ted
    If you buy from eBay and installed yourself, Do you get Toyota warranties?
    Like people mentioned 3 year warranty for 2020 truck is good deal.
  16. Feb 21, 2021 at 9:29 AM
    #336
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    Also cannot see any reason what so ever that it would not work on a 2WD. It is the same parts. I just got my shocks and struts yesterday so I guess I'll find out in a couple weeks if it works or not.
  17. Feb 21, 2021 at 9:37 AM
    #337
    James
    Georgia
    Stock
    I appreciate the write up on this and to me you have a lot of good point in here. For me, this kit was a way to get a Pro grille, factory installed, while keeping the warranty without questions from an unruly dealer. Some of the questions/answers on here leads me to think this "kit" isn't all its cracked up to be for some people. Especially since the aftermarket options are so vast. I have no problem with a company making money from their products but I do have issues with making it seem like certain parts won't work together when they will. Perhaps they have a lot of stock they are sitting on. Well, then stop asking for VIN's to get a Pro grille and the garnish will sell faster. Just seems like Toyota is making things harder than they need to in this regard. Rant over.
  18. Feb 21, 2021 at 9:43 AM
    #338
    Fire Arrow
    Jim
    MD
    So what about a 16 or 17?
  19. Feb 21, 2021 at 11:34 AM
    #339
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    My dealer told me they would sale me the kit but can't install it, because my truck is a 2019 and it was made for 2020+
  20. Feb 21, 2021 at 11:40 AM
    #340
    travadol
    travadol Well-Known Member
    Travis
    Prairies, Canada
    2020 Cement DCSB OffRoad Premium
    So there was a guy a while back who installed a 2020 TRD Pro grille onto his 2020 TRD OR with Multi-Terrain view camera and his 360° view got all wonky and didn't line up with the side images anymore.
    Has anyone had this issue with this kit? Or does the dealer recalibrate the camera? Would the new milliwave sensor have anything to do with the camera settings somehow?
    Pics of your 360° view post install would be great.
