Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Mar 2, 2021 at 10:18 AM
    #501
    BulldawgTaco
    BulldawgTaco Member
    Is this kit suitable for offroading at all, or is it just for mall crawlers?
    Eric2009Taco and Fast1 like this.
  2. Mar 2, 2021 at 11:04 AM
    #502
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Definitely think you could off road with it. You can off-road with stock truck. I wouldn’t go jumping your truck though
    :anonymous:
  3. Mar 3, 2021 at 11:29 AM
    #503
    Kovaci
    Kovaci Well-Known Member
    Josh
    SD / IN
    2021 Army Green DCSB TRD Off Road
  4. Mar 3, 2021 at 11:38 AM
    #504
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    Why would you need a new clamshell bushing? And axle seal?
    Fast1 likes this.
  5. Mar 3, 2021 at 12:22 PM
    #505
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    Is this related to the needle bearing on driver's side failing after lift, thus needed ECGS bushing replacement? I've wondered if this is also needed with this TRD lift.
  6. Mar 3, 2021 at 1:04 PM
    #506
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I would do it. The trd lift is nothing more than the Bilstein 5100s. Its not if but when. If you do it, then why bother with the oem lift and warranty issues. It won't be long and the warranty is over with. Skip the high over priced kit and do the 5100s.
    Burns likes this.
  7. Mar 3, 2021 at 1:11 PM
    #507
    YE2KA
    JB
    Yeah I'm curious now, if a Toyota tech suggested it maybe it's for certain it will fail with any sort of lift?
  8. Mar 3, 2021 at 1:21 PM
    #508
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    It is for certain that the dealer is making money off of warranty work billed to Toyota that may not be required.
    Brushog65 likes this.
  9. Mar 3, 2021 at 1:22 PM
    #509
    Steveko
    Steveko Member
    2021 TRD sport DCLB
    With the contradictory info out there, does anyone know if this will work with a TRD Sport DCLB?
  10. Mar 3, 2021 at 5:41 PM
    #510
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    then you realize SRs are 31k out the door
  11. Mar 3, 2021 at 7:13 PM
    #511
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    I didn’t see anywhere mention about adjusting the headlights as part of the installation. I presume it has to be done since the front is raised an inch in relation to the rear.
    Fast1 likes this.
  12. Mar 3, 2021 at 7:38 PM
    #512
    VaToy
    Parts Unknown
    If your lifting the front and rear it not an issue, it's not like your doing a 6 inch lift.
    71tattooguy likes this.
  13. Mar 3, 2021 at 7:50 PM
    #513
    Fast1
    Minneapolis, MN
    You are changing the factory rake with a 2"F and 1" R lift.
    It is an issue. I've done the same amount of lift (2"f/1"R) several months ago and the headlights shine high.. have received high beams back at me from oncoming traffic.
  14. Mar 3, 2021 at 8:20 PM
    #514
    cspcrx
    That’s my thinking, the rake change has a greater impact on the alignment than the lift. If the front and rear were lifted equally than aim would be impacted less than the rake change.
  15. Mar 3, 2021 at 8:46 PM
    #515
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I like our dealer mainly because of my SA. Not sure I’d trust the parts guy to find a specific part unless I did the work for him… finding the part number.
    I’d have to disagree, any change should require headlight adjustment. Even lifting both front/rear and even if only a couple inches- a little lift will still be more drastic at distance. IMO
    For instance, granted I only lifted the rear but that 1-1.5” rise led to almost a foot at distance that my headlights were pointing down. Vise versus for lifting the front only would point headlights up. Even both front/rear, although not as drastic will obviously raise the truck and headlights will likely cause some blinding (I would think a slight down adjustment necessary)
    Toyota_Eddy likes this.
  16. Mar 4, 2021 at 1:32 AM
    #516
    VaToy
    Parts Unknown
    Mine didnt need adjusting with 2 inch lift 1 inch rear.
    71tattooguy and N3FOLMike like this.
  17. Mar 4, 2021 at 2:09 AM
    #517
    baldbeardedtaco
    FL
    Ok.
    geometry says your lights are aimed up (saying your headlights were properly aimed stock)
    trevnologies likes this.
  18. Mar 4, 2021 at 6:32 AM
    #518
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    Screenshot_20210304-093022_Messages.jpg Screenshot_20210304-092844_Messages.jpgsalesmen took this pic to show me lift installed.
    Then tells me the grille insert came broken so they're sending a new one today.
    I guess the entire grille needs to be removed for install?
    I hope to take possession this week sometime.
    Maybe today, maybe tomorrow
    I'll get better pics up when I get it!
    TacoOggie and Canadian Caber like this.
  19. Mar 4, 2021 at 6:32 AM
    #519
    DatB0iiAeb
    DatB0iiAeb Member
    Aeb
    Tacoma, WA
    2023 MGM Tacoma TRD-OR
    Do you guys think it’s worth getting this lift kit? I’m 50/50 right now if I should do it or not
  20. Mar 4, 2021 at 6:41 AM
    #520
    smuggiesrider
    Vermont
    I was too
    I had a 2010 TRD sport DCSB
    After spending 2k + on Toytec ultimate lift kit 3" lift with LR UCAs and Dakar leafs then 500 for install I instantly had drive line vibe issues.
    Installed shims to solve that.
    Then the 3 CV axles I went through and the lower control arms wore out.
    I also did a complete bushing replacement on the UCAs and had to replace rear shocks and front shocks.
    Pretty sure the majority of this happened before or around 35k on the lift.
    I'm not doing any crazy offroading and really just like the look of a slightly lifted and level Tacoma.
    Oh yeah and you get a pro grille.
    I'm paying $1995 installed.
    So this seemed like a good move for me.
    NOT FOR EVERYONE!
