Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Mar 5, 2021 at 12:32 PM
    #541
    TayTay Ankles
    TayTay Ankles Well-Known Member
    I called my local dealership and they told me they couldn't order and that I would have to go through toyota or something. I was trying to bypass the $25 shipping. So I was going to order from the website we discussed by it said it would come in the week I'm out of town. So I guess I'll have to order it next week sometime.
    Will you let me know how the install goes and if we need any other parts for some reason? Also, take before and afters if you have time.
  2. Mar 5, 2021 at 12:46 PM
    #542
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    That's odd because my 2021 Tacoma TRD OR had the "Taco lean" right off the show room floor.
  3. Mar 5, 2021 at 12:49 PM
    #543
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Just get the Bilstein 5100s.
    Burns and 71tattooguy like this.
  4. Mar 5, 2021 at 12:51 PM
    #544
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    So basically it's shocks and spacers?, forget the grill...got one already.
  5. Mar 5, 2021 at 1:07 PM
    #545
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    I bought just the shocks. I’ll be installing them next week myself with stock coils and Wheelers AAL
  6. Mar 5, 2021 at 1:13 PM
    #546
    TacoMan408
    CA
    How much lean do you have? I am currently 1/4” lower on the drivers side with OEM suspension, half tank of gas, and empty bed. Putting a 1/4” spacer would raise it a 1/2” (suspension geometry) and make 1/4” higher on drivers side.
    So for me, 1/4” lean is well within “good enough”. If you have at least 1/2” lean then it probably makes sense to add the spacer. Every truck will be slightly different.
  7. Mar 5, 2021 at 1:20 PM
    #547
    TacoMan408
    CA
    Or they can just get the TRD shocks, rather than the whole kit. 5100s are actually more expensive than these shocks when bought separately. I’m pretty sure the only thing 5100s include that these shocks don’t is new bushings, which are actually pretty cheap if you wanted to replace those as well
  8. Mar 5, 2021 at 1:47 PM
    #548
    Fast1
    Minneapolis, MN
    You could get a 1/8" spacer to solve the 1/4" lean.
    I was pointing out that stock Tacoma's have the lean which contradicts your statement that they don't.
    I removed the stock suspension 2 days after purchase and installed Bilstein 6612/5160, front coil-overs and rear remote resi shocks.
  9. Mar 5, 2021 at 1:48 PM
    #549
    VaToy
    Parts Unknown
    TRD are 3 perches to the Bilstein are 5.
  10. Mar 5, 2021 at 1:55 PM
    #550
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    i think that the big draw for these (which i believe bilstein makes) over the 5100s is the resale value and keeping things oem
    mainjet likes this.
  11. Mar 5, 2021 at 2:15 PM
    #551
    Rallyfocus
    Rallyfocus Member
    2020 TRD ORDC
    Has anyone from Canada been able to order this either online, or at the dealer? Playing with the idea of going this route only for warranty purposes.
    Bugeater and Canadian Caber like this.
  12. Mar 5, 2021 at 2:34 PM
    #552
    VaToy
    Parts Unknown
    OEM is one thing but it's not orginal standard equipment. Were not talking about a rare muscle car, it's just a Tacoma. I also don't the the next buyer of a used truck is too concerned about OEM shocks and struts. Just my thoughts as people are putting to much though into this kit. A 1/4 shim is not OEM, not the diff drops if needed, or the clamshell bushing replacement. Lots of non orginal equipment parts goi g on here.
    71tattooguy likes this.
  13. Mar 5, 2021 at 3:44 PM
    #553
    mainjet
    mainjet Well-Known Member
    Alberta
    2019 Tacoma off road
    Ray 10s Diode dynamics Hidden Light bar Toyo AT2s
    Spoke to my dealer they said it would be closer to the end of March for Canada
    Bugeater, travadol and Canadian Caber like this.
  14. Mar 5, 2021 at 6:12 PM
    #554
    Manny315
    Manny315 New Member
    Manny
    2021 Tacoma TRD Sport
    Tints, LED lights, running bars
    Same thing happened to me. The grille was all busted but they found one with the gray letters better matching my truck and put that one on.
    smuggiesrider[QUOTED] likes this.
  15. Mar 5, 2021 at 6:49 PM
    #555
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    I was told new grille was being overnighted on Wednesday. Still waiting....impatiently.....I bought a truck a week ago and haven't even driven it!
  16. Mar 5, 2021 at 7:04 PM
    #556
    Toyota_Eddy
    Toyota_Eddy Official trouble Maker
    Riverside County
    2021 MGM TRD OR 4X4
    TRD lift kit, Pro Grille, Bed lighting, Falken Wildpeak AT3, To be continued....
    Yep
    To clarify, Seperate parts or the complete kit? I installed the complete kit.
  17. Mar 5, 2021 at 11:07 PM
    #557
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    See post 58
  18. Mar 6, 2021 at 2:47 AM
    #558
    bolt_thrower77
    2021 DCLB trd or
    i disagree.... while not a classic, it is still a $40k ride.....and i may be wrong , but i believe that most people or dealerships seem to frown on heavily modded vehicles....the new buyer wants to take that journey....with these parts it has that "it came this way from the factory" vibe....not the "me an my buddy steve got drunk and put this lift kit on...it rides way better, i promise" vibe
    Paulndot, mainjet, Chris202OR and 2 others like this.
  19. Mar 6, 2021 at 2:50 AM
    #559
    bolt_thrower77
    2021 DCLB trd or
    that being said, i've never installed a lift or sold a truck with one on it... lmfao!
    so prolly like most things, im wrong af...XD
  20. Mar 6, 2021 at 7:07 AM
    #560
    abrams2112
    abrams2112 Active Member
    Mid-East Alabama
    2021 Cement Tacoma TRD Sport 4x4 w/XP Package
    TRD lift kit
    TacoOR20 likes this.
